Solder not reflowing - what am I doing wrong?
  • sircastor
    • Sep 2022
    • 10
    I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
    For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components (specifically a fuse) won't budge. I don't think I'm being impatient in expecting the solder to start liquifying after a couple of minutes.
    One thing that stands out that might be contributing is that I'm using a digital microscope - I don't have a good sense of depth when doing this - which maybe means I'm not perfectly pointed at the component. But I'm also not seeing success when I put aside the microscope.
    I don't know what I'm doing wrong. Is there some special trick to reflowing solder with hot air that I'm just not getting? Suggestions are welcome.
    • 31267
    try to remove something without the microscope just to get used to how close your putting the air nozzle
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8344
      I hardly use the microscope to take anything off using hot air. Hot air takes practice. At the beginning I went full bore and way too close so much I made a huge bubble underneath the traces. Basically the PCB separated. These days I use two settings on my hot air and don’t pay much of attention on exact airspeed and temperature values.
      The next thing becomes the nozzle. My bet is you use a too small of nozzle. I use only 2, basically one 1. A small nozzle for little simple SMT buggers, or none (I take the nozzle right off) if I need more spread out heat for an IC. I also only fan the hot air around the PCB at the beginning, then center that hot air over the IC or whatever get closer and then wait until it becomes floating and pick it off.
      Another Problem: under fill and glue. SMD or T components can either have an under fill or even glue underneath. Making it appear they do not come off. Be careful what you doing here, you can rip of traces or pads in no time. Same with using too much heat.
      Vague, eh? That’s why I said it needs practice. It’s kinda like riding a bike.
      Now let’s see what you are trying to do. Maybe it is as simple as adding a little flux and some new quality leaded solder and it should come off. I got spoiled and got some hot tweezers for my Weller WD-1.
      Crap: here is the next point… SOLDER. I use 3 different types. A very low melt solder paste, Kester leaded 60/40 solder wire and “silver solder”. Use good solder, not the Chinesium crap.
      • sircastor
        • Sep 2022
        • 10
        I tried again last night and it went a little better than it had previously. I switched to the big nozzle and tried to preheat the board a bit, and messed around bit more with the air speed and temperature. It was still tough and took more effort than I expected. I guess in a lot of ways this is a practice thing.
        I don't think anything is glued on (not that I'm dealing with anyway). FWIW, I'm using Weller silver solder, and I think the leaded stuff I have is kester (i'd have to pull it out). I think the MBA I'm working on would use lead-free, but it is a 2015 era, so I don't know how aggressive Apple was at the time for RoHS compliance.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8344
          I hardly use that silver solder. A spool of it lasts me many years. The 60/40 is use to 95%. I assume you are taking ICs off the board. Take the nozzle right off and blast the IC. Poke at it and once it moves pick it off with the tweezers.
            • 31267
            time for a solder talk.
            silver solder is only needed when soldering onto oxide deposited onto ceramic backing - like hybrid circuits or piezo transducers.
            it may melt faster and flow a little better, but once it's on it's harder to reflow or melt later.
            i use 60/40 solder to clean boards or lower the melting point of chinese leadfree solder joints,
            when i put stuff back i use leadfree solder with NiGe in it.
            thats not cheap btw.
            • Aliencomputres
              • Aug 2019
              • 218
              • România
              Mix lead solder with non lead.
              https://www.eptac.com/blog/leaded-vs...hich-is-better
              • Jeff'sTech
                Dell Latitude 7420 BIOS Unlock Gone Wrong
                by Jeff'sTech
                Hello everyone.
                I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make...
                11-08-2023, 03:30 PM
              • survivalbloke
                Am I using my microscope wrong?
                by survivalbloke
                I've got a nice microscope to use, but I'm sort of a noob with microsoldering. I've gotten MUCH better over the last 6 months(with the help of this forum) but one thing is that I have sometimes struggled to get the scope high enough. You'll see in this image that I have the arm at its highest position possible, and I've also got the entire thing sitting on an old laptop for an extra couple inches.
                So, there's that, which I just talked about, as well as the fact I hate the bulky base of this thing. I'd love to take it off the base and bolt it directly to my work surface. Maybe even...
                09-07-2023, 01:07 PM
              • corrize
                Best way to solder LVDS connector for beginner (and qfn) ?
                by corrize
                Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                See the test :
                https://youtu.be/bNAzC-EvqHs?t=1767
                With hot air from bellow the board, that's...
                03-09-2023, 02:57 AM
              • craig1410
                820-01700 (A2141) R7900 failed, power cycling after R7900 bridged
                by craig1410
                My wife's 2019 MBP died a couple of weeks ago and I have been trying to figure out what is wrong with it. I have an electronics background and equipment but never tried to diagnose a modern MBP before. I have the board view and schematics already and have been climbing the learning curve steadily!
                Initial fault was no power with USB ammeter showing 5.19V @ around 12 to 35ma. I won't go into all the initial debug I did because ultimately I found R7900 to be high resistance when it should have been a 0ohm link.
                So, going from the power sequence...
                04-28-2023, 09:14 AM
              • chegueva
                My Andonstar ADSM201 Microscope Review
                by chegueva
                Hi everyone. i'v started learning electronics before the corona hit so that's not very long time ago. but anyways i started with only a multi-meter then i started getting into micro-soldering and soldering in general, got myself hot air station a bench Power-supply and last but not least a microscope.
                About the microscope at first i just wanted to get those 15 usd USB digital microscopes to try but some people talked me outta of it and i decided to go for something better but not professional as i'm just starting out.
                So i had a choice between a binocular & camera , i wanted...
                08-14-2020, 11:08 AM
