I guess you all know that, as most speakers use simple transformer to get voltage down, a voltage spike occurs when you turn them on. That results into loud clunk when. Is there any simple way how to prevent this phenomenon? A thermistor maybe?
Any way how to simply prevent speakers from clunking?
Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Tags: None -
Re: Any way how to simply prevent speakers from clunking?
You can build delay-on speaker relay circuit to let the amp and power supply to be stable before the speaker is connected to the amp output.
Or you can buy the pre-assembled spekeaker protection that will have delay on and also DC detection to protect the speaker from damage due so failed output section that will dump DC to the speaker. Solid state amp does not use matching transformer like tube type amplifier.
Just Google "speaker protection circuits"
I.E.
http://sound.westhost.com/project33.htm
If you have separate pre-amp and power amp setup, the pre-amp should be powered up first, then the power amp. On turn off, the power amp should be turn off fist, then the pre-amp.Last edited by budm; 11-28-2013, 04:41 PM.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
go back to valve amps that don't klunk?!?Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.Comment
Just to get things straight, this only happens when you turn the power switch on. It is not really a functional problem but customer asked me if there is any simple improvement I can do on the main speaker with PSU to supress this.Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
Add a relay and a resistor + capacitor. Capacitor charges slowly due to current limited by the resistor ... when voltage goes above a threshold (usually 6-8v for 12v rated relays), the relay turns on and remains on.Comment
That is, the power supply and the amp is not quite stable yet when the it is first powered up so it produces the thumb at the turn on, that is why it needs to have speaker delay-on so the speaker is not connected to the amp terminal until the circuit is stabled first.
I.E.
http://www.the12volt.com/installbay/...42&DIR=N&FID=5Last edited by budm; 11-28-2013, 05:05 PM.Never stop learning
Yeah but you know the cheap and many of semi-decent speaker systems. This is some kidn of Genius I think. They quite often use few not-that-bad parts for their price but they have to lower the price somewhere
Yeah, slowly charging cap seems simple enough. Any suggestion for capacity and resistance? I have never really played with that and scope, have no idea how much can different resistance impact different capacitor chargingLess jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
I put a capacitor across the voltage regulators for the input stage (one for the positive side, another for the negative) to bring up its voltage gradually.Comment
One of those Genius cheap wooden things.Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Also, some IC amplifiers like the TA8216H will have a pin specifically dedicated for reducing speaker pop. On this pin you insert a capacitor, and the bigger the capacitor value, the longer it will take for main amplifier circuit in the IC to turn on, thus eliminating speaker popping noise.
Lastly, if the IC has a pin for mute, you can use that with an RC low-pass filter to slowly bring out the IC from mute to ON. This should also remove popping noises.
A relay circuit will do as well, as mariushm suggested, but you might need some really large capacitors and large, low-resistance resistors to accomplish this, depending on how much power the relay uses. You can avoid this, however, by adding 1 transistor to turn ON/OFF the relay and have a simple RC low-pass filter network in parallel with the bias resistor network on the transistor's base pin (essentially, what you have in an amplifier that turns on very slowly). By playing with the time constant of the RC low-pass filter, you can control how long it takes before the relay turns on. (let me know if you want me to draw you schematics)Last edited by momaka; 12-09-2013, 06:10 PM.Comment
Or increase ESR of caps behind rectifier (speaking of linear regulator), you will lower inrush current (less di/dt and that is /in audio/ always bad )...
Personally don't like relays (or mechanical switches - in general) in paths to speakers (they toggle few times (or tenth times) before settling)...Comment
That ain't no solution, that's just healing the symptoms!Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
That is exactly what I was referring to--Supply Voltage Rejection capacitor.Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700Comment
One of the methods I used for a headphone amp with a maximum output power of 100mW was a series-connected pair of back-to-back FETs. These are driven to short the output as the amp first powers on and when it powers off. They are biased to -6V when operational. This was for a "hi fi" audiophile thing (as spec'd by customer), so we had to have as little as possible in the path from the amplifier IC to the output.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
by momakaMore Lo-Fi speakers and another DIY surround repair.
The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
by nomoresonysCurrently trying to connect pc speakers to 2015 vizio tv, tv has no 3.5 headphone jack. Does have rca audio out, tried connecting thru a Y rca to 3.5 cable but getting odd results(probably just need a dac for decent audio, not sure?) not too educated on audio. With that hookup I'm getting 2 problems, can't get the speakers to increase in volume so it's very low even when turned up and when using both tv and pc speakers the pc speakers only put out the music part of the broadcast and not the vocals/talk of the program. Have you run into this before or know what it might be, Thanks.
by WidgetHi guys,
I have a set of Logitech R20 speakers, one of the speakers wasn't working, so I took it apart & there was no continuity or Resistance when probing the Tinsel Wires. Plus looks like the speaker was exposed to liquid as there's rust on the metal speaker frame.
Just in case, I removed the other speaker and installed it in place of the damaged speaker to make sure the PCB of the damaged speaker was ok & it seemed to work fine, so it looks like it's just the speaker for now.
Printed on the back of the Logitech speaker is;
LOGITECH...4 Photos-
05-29-2024, 07:07 AM -
I've had a set of speakers come in with the fault of not powering on.
I could hear something wrattling around in the speakers so we played a game called Guess What's In The Speakers! and this is what we found:
1 random loose nut and part of a BIC Biro pen.
After removing these foreign objects I plugged in the speaker and powered it on and found the volume to be quite low. On plugging in the other speaker it was very loud, but only out of the other speaker, this side was still very low.
by piipoHi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much1 Photo
09-18-2024, 01:55 AM -
- Loading...
