bent neck CRT pins...
    • 31198
    Re: bent neck CRT pins...
    if one of the diodes or caps in the HV ladder circuit breaks down under load it will pull the input to ground.
    can you lift the ground at pin10 and put a lamp inline.
    • redwire
      • Dec 2010
      • 3912
      If the CRT is biased-on hard, it could overload the HV after it warms up?
      I would be tempted to run it with the cathode (-1,900V) pin 2 disconnected, but anode connected. I think that would not allow the CRT to conduct, but the HV should come up, unless some short internal to the CRT.
      Assuming the CRT end-connector on, for filaments etc. in all this.
      Mildly interesting, note 8 minute ramp on U1890A/Q1980 from R1991.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        That would be a neat experiment, alas I would end up having to remove the whole multiplier from the board (or cut a hole into the board) to disconnect pin 10 as it's underneath the module :-(
        The module has 7 pins underneath: 4 are the corners (pin 13 and 15 are two of the four) and the other three (9, 10, and 12) are sprinkled in the middle. Don't ask me why pin 14 is along the sides of the module however, the pin numbering makes no sense
        I was staring at my junk box a bit. I have 66 megohm resistor. If I had 20KV across it, it would dissipate about 6 watts of power... not sure where this resistor came from but I figure it was from the CRT days, and no wonder why this resistor is physically so large... I think it was for bleeding HV.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          New observation: I think this thing is frying my LM1458's ... It's coming up dead short once again even without the anode connected... I have a feeling perhaps the initial guess was right: HV is arcing internally against cathode/grid circuitry and leaking out killing the LM1458?
          Hmm... sigh. I wonder if it's worth to fix this. The short period of time I had this thing seemingly working, it did detect and showed a trace when in1 was connected to the calibration output, but it did seemed sinusoidal instead of square. I just wonder how much I should sink into this thing before giving up on this... are these really reliable scopes and will I just run into issue after issue? (Then again what can one expect from a 30 year old scope... for it to work as well as my digital-less ~40 year old Vu-Data ~20MHz scope?)
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Hmm..Suppose I buy a working PSU. What can I do to it to protect it from a bad CRT if in case the CRT did damage the PSU? I know the grid and cathode are not shorted (else the protection neon lights won't come on) but is there any other protections?
            Still wondering if I should get HVPS + CRT or just HVPS by itself...
            Dang these unfinished projects... must get this completed...
            • redwire
              • Dec 2010
              • 3912
              Fixing a Tek scope is no walk in the park. Don't let the beast defeat you!
              I would say the HV is overloaded.
              The error amp U1956 (LM1458) can't really fry, it has series output and input resistors for protection. Even an arc internal to the HV module would just hit R1944 and the 1458 has internal clamp diodes.
              U1956A is an integrator (no DC feedback) part of the main oscillator I think. Waveform #70 shows it's a 40kHz sine-wave oscillator for the flyback, low EMI and noise, so not a flyback circuit really.
              You might have a loose connection somewhere or an intermittent part, sometimes that throws me off when things change.
              Gently check the ferrite on the flyback T1970 and make sure there are no cracks or loose clamps. Any extra air gap would cause Q1981 to get hot.
              The CRT (rear) socket look for any arcing or carbon tracking, on its PCB and inside the socket between pins, with a magnifier. This can resemble a shorted CRT.
              Does the HV come up with the CRT socket unplugged? It should regulate at -1.9kV with no load and crackle on the 2nd anode (+14kV).
              Does the HV go down as the CRT warms up? Then the CRT could be biased wrong and drawing too much current.
              Next I would be disconnecting rails, like the -300V etc to try narrow down where the overload is. Just offering some ideas here.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Thanks, yeah, I think pretty much everything these days are difficult, though mostly is my fault (though I did not bend the pin to begin with!). I think I did crack the tube, but now I just wonder how powering up a gassy tube would cause the psu to fry if it really did. As far as I can tell it's something between the "flyback" (yeah, this thing definitely isn't a true flyback as there's no horizontal retrace that's activating it, but it does depend on the switching of the transistor... as it's not heatsinked it better be saturating.)
                The ferrite looks OK. The only thing that's loose is the external winding for the filament.
                I can't seem to find any forms of arcing but I did hear something as the device failed. But no more as the PSU is completely overloaded now and blows fuses.
                I think I've come to the end of the road on this. I think the unbent pins likely caused the demise of the CRT and it dominoed to the HVPSU.
                • redwire
                  • Dec 2010
                  • 3912
                  I've only seen CRT's fail shorted or leaky on the aquadag. Usually arc/carbon track on the inside.
                  The tube will hiss for a long time if you trashed the pins and started a leak. Like a can of pop but vacuum. I'm not sure what the mystery noise was.
                  Maybe air got in and the aquadag died?
                  You could try a megger or hipot tester on some of the CRT's pins, but not heater/cathode/control grid, they are all low voltage compared to 1st, 2nd anode, focus and deflection etc.
                    • 31198
                    i already pointed out that if you lose the vac, the phospor will look bad on the front.
                    • R_J
                      • Jun 2012
                      • 9588
                      You will only lose the phospher if the air rushes in fast, ie break the neck off, if its a slow leak the phospher will remain untouched. I would connect the heater to a filiment transformer with a 6.3 volt secondary and see if it lights and most of all stays lit. if there's air in the tube the heater will most likely burn out.
                      during crt rebuilding air is let into the tube slowly and then the old gun assembly is cut off and a new one is installed and the tube evacuated, if the vacuum is released to fast it can damage the phospher and the tube is no longer useable.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        I don't know how fast the air leaked in, it must have been really slow because I did not hear any hissing. I just heard glass cracking, I assume it was glass by the pin cracking.
                        I mainly am coming to this conclusion because the getters look bad right now, starting to clear up which is a telltale sign
                        I was wondering whether I should have coated the interface between the wire and the glass with either epoxy or cyanoacrylate before trying to bend it back so that if it leaks it would suck in the glue first, if it's a minor leak... But I did not...
                        • R_J
                          • Jun 2012
                          • 9588
                          Where did you come up with the getter being able to show that there is air in the tube?
                          Here I found this:
                          In vacuum or gas-filled tubes, it is a small, ring or cup-shaped device containing a powdered metal that reacts strongly to oxygen. When the tube is sealed, the getter is fired (heated) to further evacuate a vacuum tube or to remove impurities from the gas. Firing causes the getter material to oxidize and absorb any free oxygen in the tube, which would otherwise oxidize the active electrodes and decrease the tube's life. Tubes with graphite-based electrodes do not use getters, because the graphite itself absorbs oxygen. In a vacuum tube, the location of the getter is sometimes identified by a shiny silver deposit behind the glass, which is residue from the firing. The metal used in the getter depends on tube manufacturer, type and composition. Barium is an excellent oxygen absorber and is used in tubes with a fired getter. Zirconium and titanium, also used as getter material, oxidize from the tube's self-generated heat and do not require firing.
                          The only real way to check the condition of the tube is electronically.
                          I have seen bent crt pins where the the glass around them cracks a bit but did not cause the tube to be bad. the glass can crack a bit when the pin is stressed but usually only only at the surface where the glass meets the pin.
                          Here is some additional information reguarding tubes http://www.vacuumtubes.net/How_Vacuum_Tubes_Work.htm
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            Hmm... I was still staring at the getter spots along the side of the neck and am seeing a bit of whiteness in it where it should be silvery - which seems to imply that the seal has failed. I'm looking into removing the tube now to confirm (need to remove from the shield to look at the spots straight on) but currently I have to look into the shield from a very steep angle (say, 5 degrees from parallel to the spot) with a flashlight and apparently seeing the not so healthy getter spots.)
                            • R_J
                              • Jun 2012
                              • 9588
                              I give up
                              • Sparkey55
                                • Jan 2010
                                • 1523
                                Like someone else suggested here, you need to test the crt heater filament. The safest method would be to connect four 1.5 volt batteries in series, D cells would work to give you 6 VDC. If the heater does not light up a dull red or bright orange then it is dead. IF the filament checks good then leave the HV anode cable off but connect the focus lead to the crt then watch the tube in the dark for any corona or purple flashes.
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  How long would it normally take to "kill" it, assuming the vacuum is gone? I guess I do have a variable PSU that I can connect to it, but at least right now the filament is intact based on resistance. Oddly enough I can't see the glow of the filament due to the shield and the socket covering the back end so I have to infer by resistance.
                                  • Sparkey55
                                    • Jan 2010
                                    • 1523
                                    If the crt vacume is lost the heater will burn to an open circuit when power is supplied to it, just like when a light bulb is cracked. Disconnect the socket from the crt neck so you can see the filament glow when applying external 5 to 6 volts to the heater pins on the crt. DO NOT go over 7 volts on the heater at any time. If you can not see the filament then try to measure the current draw with a meter. Do not have the scope powered on while doing this test.
                                    • Sparkey55
                                      • Jan 2010
                                      • 1523
                                      If the crt can not pass this simple heater filament test then it makes no sense to go any further on testing the tube or HVPS. Will you perform the test as suggested?
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8701
                                        I tried passing 5.6VDC with a LM317T regulator. Current started around 134mA but went down to 125mA and is still slowly going down, then again regular light bulbs do this too. I tested for 2 minutes....
                                          master hoarder
                                          • May 2008
                                          • 12175
                                          #100
                                          +1
                                          Unless you somehow plan on evacuating the tube again.
                                          I've been actually wanting to try that with my dead GDM-FW900. But for CRTs, you need a really good vacuum pump: usually dual diaphragm and capable of evacuating down to less than 100 microns. Also, even if you had the equipment for that, you'd have to get creative with where to make a hole on the tube to pull the vacuum from and then stop air into coming back in (unless you plan to run the pump continuously with the CRT). Something like this experiment:
                                          https://www.youtube.com/watch?v=jlV-2gcO0_0
                                          • magneh
                                            Asus Z370-F Strix Gaming - Bent pins - Not powering up
                                            by magneh
                                            Hi guys,
                                            I've got this nice mobo with some CPU bent pins.
                                            Made it to put them back to their position, but one of them was too twisted and broke down.
                                            Anyways none of them are shorting together now.
                                            I had a i3-8100, a DDR4 2400mhz 8GB stick and a power supply, so gave it a try. Power led of the mobo is orange, but when shorting PWR pins, no joy
                                            Made some quick random measurements, 3.3V is present in the PWR button pins, I can see 5V also present.
                                            Measured around SIO chip and 3v are present in some caps.
                                            Im not sure if...
                                            03-13-2020, 08:04 AM
                                          • DCJack
                                            B&K 707 tube tester. I need help.
                                            by DCJack
                                            Hi everyone!
                                            I managed to get my hands on a rough condition B&K 707 for "the best price" because it was not working. It's my first tube tester and I'm really wanting to get it up and running. I downloaded that manual that has the schematics and tested every resistor and capacitor and replaced the ones that failed. I replaced the missing 83 rectifier tube with a used but tested-good one. I also have a number 80 rectifier tube that I have used in tests before I found the 83 tube.
                                            Initially I noticed that I was not getting the red on-light to turn on, but it...
                                            03-05-2024, 05:05 PM
                                          • tiagooliveira95
                                            My first attempt at board repair - Asus Prime X670-P
                                            by tiagooliveira95
                                            Hey everyone
                                            I decided to dive headfirst into board repair. I'm a computer engineering student, and I'm attempting to fix my first board.
                                            I have made some progress, and I feel super excited. Still haven't fixed the board tho, but I decided to make a post here to share my progress.
                                            This is an X670-P, seller stated bent pins and no power on, the socket has 2 bent pins, the pins are slightly bent upwards (VSS and a Channel A pin), so it's an easy fix, don't even need to replace the socket, tested all power rails on the CPU and found no shorts, the bent pins...
                                            08-22-2025, 08:20 PM
                                          • corrize
                                            Where to find a very small fpc connector 0.3mm between 2 pins ?
                                            by corrize
                                            Hello, I search this connector (oxydated).
                                            It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                                            I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                                            I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                                            Do you know how to find this connector please ? What is the exact name for find it ?
                                            08-06-2024, 05:25 PM
                                          • SS454
                                            vizio e650i-a2 backlight flashes then turns off
                                            by SS454
                                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                            panel: au optronics T650HVN05.4
                                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                            08-20-2020, 03:57 PM
