B&K 707 tube tester. I need help.
  • DCJack
    • Apr 2013
    • 26
    Hi everyone!
    I managed to get my hands on a rough condition B&K 707 for "the best price" because it was not working. It's my first tube tester and I'm really wanting to get it up and running. I downloaded that manual that has the schematics and tested every resistor and capacitor and replaced the ones that failed. I replaced the missing 83 rectifier tube with a used but tested-good one. I also have a number 80 rectifier tube that I have used in tests before I found the 83 tube.
    Initially I noticed that I was not getting the red on-light to turn on, but it would work when I applied pressure to the bulb behind it. I soldered component legs to the ground from the bulb brass and everything lights up now.
    Here is the problem I am dealing with now:
    Every calibration goes well and by the book, until it comes to calibrate the last and most important function. The Balance Control Adjustment. The needle in the gauge is vibrating. I don't think is should be doing that, right? I calibrated it anyway, with the 6M 10w resistor in pin 2 and 5 of socket 1, and adjusting the needle position using the pot closest to the transformer until the needle reads Zero while the Test 1 button is being pushed down.
    When I test my one known bad tube, a 10DE7, the needle, on both Test 1 and Test 2, reads well into the Good range, with differences between the two readings. I have two NOS 12BA6 tubes and they peg the needle when tested. The needle is still vibrating on both tubes.
    I just found another problem while writing this and checking things on the 707. I got a little tingle while lifting the chassis to double check the location of the Balance Control pot for this post. I took a measurement between the aluminum panel and Earth. It's reading almost 70V AC. That can't be normal.
    Any advice?
    https://www.youtube.com/shorts/wrVkbFtc_y8
    https://www.youtube.com/shorts/1OGce5OGRDs​
  • redwire
    • 3912
    Did you test any of the four electrolytic capacitors? I'd expect them to be dried out and would outright replace them.
    It would cause AC hum to be present and vibrate the meter needle.
    C1 200uF 4V across panel meter
    C4 20uF 250V screen supply
    C5 20uF 250V -ve grid bias supply
    C101 10uF 35V for -19.5V grid bias supply under tube socket 27.
    Some leakage current is normal and expected from the chassis to earth ground. The power transformer has many windings so I would expect high capacitance there.
    I don't see a "death cap" but it might have one? Flip the polarity on the mains cord, or change over to a grounded one.
    You can measure Ohms between mains and the chassis or capacitance to see if it is a problem.
    Careful the plate cap wire will have 200VDC, these are from a manly era where techs did not do silly things when operating them.
    It is possible to replace the 83 mercury vape rectifier with solid state diodes and a few mods.
    • redwire
      • 3912
      If the caps are truly good and the meter is still shaking then I would look for an open diode in the 83 or 6BN8 giving 1/2 wave rectified AC to the panel meter. You can check the glow on the 83 should look the same for both sections. The 83 can be replaced by 1N4007 and a 100Ω 1W series resistor. There should be a 15V 5W zener added to cover the tube's voltage drop but later models like 747 didn't bother. I guess it can cal out. The -19.5V should be regulated though.
      Mr. Carlson did a very good repair video: B&K Dyna-Jet 707 Tube Tester RESTORATION and ALIGNMENT!
      • howardc64
        Don't probe Samsung LED conector with LED tester, connect may not make contact afterwards
        by howardc64
        Samsung have been using this style LED connector for few years now
        Usually good idea to test the LEDs before opening the panel to change them. I do this without the PSU stil connected. With this connector (white one) have to jam the LED tester probes in the very narrow thin slot where the PSU blade style male prong inserts into. I've done this on many Samsungs without problem until today...
        The female terminal inside the white connector has fragile fingers that grabs onto the male blades on the PSU's black connector. If the LED tester probe spreads open...
        10-12-2025, 08:13 PM
      • Lifeisfun
        Trying to troubleshoot DDR4 SODIMM slot with slot tester
        by Lifeisfun
        Hi folks!
        I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
        Eventually I discovered that it was related to moving the laptop.
        Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
        If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
        I removed the board got one of those memory slot testers...
        06-04-2025, 02:26 PM
      • spleenharvester
        Reverse engineering of 18650 4-channel tester
        by spleenharvester
        Hi friends
        I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
        05-04-2025, 02:43 AM
        FNIRSI HRM-10 Internal Resistance Detector AC Lead Acid Lithium Battery Tester Review on some testing of device
        by sam_sam_sam
        https://www.ebay.com/itm/405035016711
        I got this device yesterday and did some testing on some tabbing and some incandescent light bulbs and it seems to work very well from what I can tell but how do I know how accurate the m-ohms section is what can I use to verify it accurately I also tested some li-ion battery cells and this seems to be fairly accurate because I have another tester and they seem to agree with each other
        I also checked some capacitors with it that were brand new and seem to show about what I expected to see with my blue capacitor tester so I think it...
        04-13-2025, 08:17 PM
      • eccerr0r
        [emission only] vacuum tube tester safety
        by eccerr0r
        Well, I was able to acquire a vacuum tube tester. It's a cheap crappy emission only (i.e., no transconductance/mutual resistance) tester - but I realized it was even crappier than I thought. The power supply is an autotransformer, and the "floating wire" top cap lead has an electrical path to line power! Touch the cap wire, get electrocuted!
        I would suspect all those old console tube testers were isolated especially if it had one of those flying top cap leads... or at least I hope it would. This one is indeed cheap cheap cheap, alas it does get the job done...
        02-17-2019, 06:51 PM
