bent neck CRT pins...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Ugh... I think I may have broke a CRT in a 'scope.
    I have one of those CRTs with pins on the neck for the deflection plates... they were bent really badly. Had to bend them back at risk of cracking the tube... and may well have...
    What kind of characteristics do leaked CRTs have? how does a slow leaking tube behave as the tube fills?
    Might have to buy a new CRT And hope it does not come with bent pins...
    • 31024
    Re: bent neck CRT pins...
    internal arcing between the anode & internals.
    and *maybe* the heater will be brighter or burn-up in the presence of oxygen.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      How about when it's a slow leak... I'm sure at first it will still work somewhat? What characteristics would it have before it degrades to death?
        • 31024
        it will probably work until the heater or anode act up.
        once you lose the vac the phosphor will start to fall off the face and leave a mottled effect btw - a good way to spot stuff with broken tubes at a car-boot sale.
        • keeney123
          Lauren
          • Sep 2014
          • 2536
          For future reference always use two long nose pliers. One to hold up near the tube and the other to bend the pin back.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            I was lazy and I guess I'm paying for it now. I would have to remove the tube to do that.
            Now the other question, can a cracked tube instantaneously destroy the anode power supply? It looks like a fuse blew... not a good sign...
              • 31024
              no, never.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Interesting... Maybe something different happened? I didn't hear any loud sucking sound when it seemed something cracked but perhaps it was just the outside layer... I hope.
                But the strangest problem is that now my HV supply is instantly blowing fuses now. Was thinking the cracked tube could have caused this... hmm.
                It's a 15 volt supply, and I tried sticking in 40 ohms of resistance instead of using the original fuse and almost 400 mA flowed - so the supply is virtually a dead short... The switching transistor (the circuit looks like a Joule Thief type oscillator) didn't short out. So something on one of the secondaries apparently shorted out.
                Hmm. I wonder if I should fix the HV PSU or still look into buying a new CRT with the PSU...
                BTW, before the phosphors flake off, is there any other way to tell without a working HV PSU if the vacuum leaked out ..err... air leaked in?
                Last edited by eccerr0r; 03-30-2016, 11:11 PM. Reason: Posing another question....
                  • 31024
                  the HT is very low current, and it is not reliant on a vac-tube.
                  i know of people how test high-voltage supply's by putting the anode-cap in a glass jar to insulate it for safety.
                  if your HT is blowing, it may be a shorted focus signal.
                  that is connected through the base.
                    • 31024
                    i dont think so.
                    or maybe there is - but it's dangerous to your test gear.
                    a crt is a giant capacitor - but i wouldnt put my meter across one!!
                      • 31024
                      try isolating the HV unit from the tube, and then power it up.
                      • Sparkey55
                        • Jan 2010
                        • 1523
                        Was the scope working before you bent the crt pins? We need photos of the pins now. If the tube has a vacume leak then the cathode heater will be burnt and not light. You can test for High voltage coming from the power supply using a small neon bulb, should light up by just holding it near the flyback transformer.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          I did not know whether the scope was totally working before I bent the pins back to where I could reconnect the pins - I acquired it as "nonfunctional". After reconnecting them, it actually worked - I saw traces show up ... but then after a few minutes the focus got really bad and eventually the HV PSU apparently burned out. It's now apparently shorted (it's burning fuses now). What I'm wondering is if I need a new tube and PSU or perhaps I can get away with just getting or fixing the PSU - which might not be easy in itself...
                          It'll take quite a bit of effort to take the thing apart to take a picture (it's really embedded in there) so I'm going to try to avoid doing it until I can do it electrically or visually
                          (Hmm... I found a 66 megohm resistor... and a few 10M ohm resistors... Might be able to make a high voltage probe and electrocute myself )
                          • Sparkey55
                            • Jan 2010
                            • 1523
                            INFO needed: Make and Model of Oscilloscope. Analog or digital. All tube or solid-state. Were the pins bent before or after you received it? Does the neck of the crt stick out past the rear of the chassis? Did it have a cover over the neck to protect it? In what manor did you try to striaghten the bent pins?
                            • Sparkey55
                              • Jan 2010
                              • 1523
                              It is difficult to say the least to be able to help you without the proper information on the scope. You can check to see if the heater is open or shorted to the cathode with an ohm meter. Pics are needed also.
                                • 31024
                                if it slowly lost focus, check every diode and resistor in the HT circuit.
                                disconnect the anode from the tube first!
                                  • 31024
                                  btw, what scope is it, do we have available schems?
                                  • Sparkey55
                                    • Jan 2010
                                    • 1523
                                    It seems that we would have better luck pulling hens teeth than getting any info.
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      It's a Tek 2465 analog. I found the service manual and schematics, but I'd thought a CRT is a CRT and all of them have similar behavior, hoping things would be as generic as possible and not specific to a certain device.
                                      The pins on the tube were badly bent before I got it, almost 90 degress off. The issue was that the pins were not pointing into the aperture in the shield where the wires need to connect to them, there's no way that the wires could be reconnected without bending them back. As I was too lazy to take the whole thing apart I propped the pin with a plastic stick, pushing the base away from the direction I wanted to bend the pin, and used a hook to pull the pin the way it needed to unbend. I heard a glassy tick sound and that's when it sounded bad. But I did not hear a sucking sound, so hoping that it didn't leak.
                                      The behavior of the HV circuit depends on the circuit of course, but I'd imagine most of them would work similarly to each other. The worry is that the HV circuit has an epoxy potted multiplier module which is one of those "replace whole thing" types of deal. Boo. However now that I know that the HV module is now bad or at least it's frying fuses. I suppose I've seen many people leaving the HT lead flying causing long sparks with no damage to the PSU. Just wondering if it's typical to all HV PSUs?
                                      I don't see any burned areas other than discovering the burnt fuse. And it looks like the CRT heater is still a good 6 or so ohms after having it powered on for a few minutes after the unbending... The heater is apparently like most CRTs and is another winding on the secondary of the HV "flyback" (but it's not a true flyback like in TVs...)
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8701
                                        hmm...Waited a day of waiting, measured the resistance of the heater with my Fluke (instead of the inaccurate Radio Shack)... 14.5 ohms.
                                        Connected a somewhat discharged 6V NiMH battery to the heater for 5 seconds (more because it's annoying to hold the wires to the heater pins)... Saw voltage go down...
                                        Measured resistance of the heater again... 14.4 ohms.
                                        Hmm... Should have measured it accurately yesterday ...
                                        14.4 ohms seems a bit high does it? Not sure...
                                        And guess what. The HV PSU is a different rev compared to the schematics I have. I guess I still have to trace some of those components not on the schematics.
                                        Last edited by eccerr0r; 04-01-2016, 01:37 AM. Reason: ugh. different schematic rev compared to board...
                                        • magneh
                                          Asus Z370-F Strix Gaming - Bent pins - Not powering up
                                          by magneh
                                          Hi guys,
                                          I've got this nice mobo with some CPU bent pins.
                                          Made it to put them back to their position, but one of them was too twisted and broke down.
                                          Anyways none of them are shorting together now.
                                          I had a i3-8100, a DDR4 2400mhz 8GB stick and a power supply, so gave it a try. Power led of the mobo is orange, but when shorting PWR pins, no joy
                                          Made some quick random measurements, 3.3V is present in the PWR button pins, I can see 5V also present.
                                          Measured around SIO chip and 3v are present in some caps.
                                          Im not sure if...
                                          03-13-2020, 08:04 AM
                                        • DCJack
                                          B&K 707 tube tester. I need help.
                                          by DCJack
                                          Hi everyone!
                                          I managed to get my hands on a rough condition B&K 707 for "the best price" because it was not working. It's my first tube tester and I'm really wanting to get it up and running. I downloaded that manual that has the schematics and tested every resistor and capacitor and replaced the ones that failed. I replaced the missing 83 rectifier tube with a used but tested-good one. I also have a number 80 rectifier tube that I have used in tests before I found the 83 tube.
                                          Initially I noticed that I was not getting the red on-light to turn on, but it...
                                          03-05-2024, 05:05 PM
                                        • corrize
                                          Where to find a very small fpc connector 0.3mm between 2 pins ?
                                          by corrize
                                          Hello, I search this connector (oxydated).
                                          It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                                          I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                                          I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                                          Do you know how to find this connector please ? What is the exact name for find it ?
                                          08-06-2024, 05:25 PM
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • DominanceINC
                                          MSI Pro Z790-P Wifi 1missing CPU pins
                                          by DominanceINC
                                          I am a new forum member. I found a broken MSI motherboard with lot of problems. The other problems need schematic. Because, the missing parts what were breaking down with screwdriver and pliers at a standoff.
                                          So, its actual problem is a missing Vcore and Gnd pins in the CPU socket. My question is that, can it be used safely without these two pins? Only for testing at first, while the other problems will be solved. I would wish repair them later.
                                          The other spots are thermal phaste, because, the under educated installer of the CPU did wipe the contacts of the...
                                          07-21-2025, 05:38 AM
