ESR meter upgrades
This is a sticky topic.
+ More Options
Posts
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    #941
    Re: ESR meter upgrades
    I have uploaded the firmware from one on eevblog.
    Yes it has a menu where you can select the basic modes of operation, including only ESR.
    If anything's missing just compile your own
    • Dutch52
      Retired
      • Aug 2016
      • 9
      • Netherlands
      #942
      @STJ,
      Did you investigate the AY-AT firmware further? (See message 928)
        • 31040
        no.
        and that machine is sketchy as fuck - i think a harddrive is failing.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          #944
          Hi i was going to arder AY-AT tester with case but seen a post where it says this one maybe a better choice and is newer https://www.aliexpress.com/item/M644...ceBeautifyAB=0
          can this tester be upgraded with later firmware etc if needed and has anyone found a case too fit them thanks
            • 31040
            ask here:
            http://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/5025/
            it looks o.k. but a colour display would have been better.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #946
              Originally posted by stj
              ask here:
              Yes true no colour screen on these, so a ay-at it is then as aliexpress has a sale on and these can come with a case etc, too save me reading loads of pages in the eevblog thread lol, do you know what if any parts are recommend to swop out? before i update the firmware, i will also keep too a 9v battery as fits in case nice.
                • 31040
                only the voltage reference really, like last time - i think you have spares of the lm4040
                beware of the case, if it's the acrylic ones they crack.
                  • 31040
                  btw, i ordered one of these in the sale.
                  https://www.aliexpress.com/item/New-...814430302.html
                  i'm thinking with a mask on the end to reduce the aperature, i can check how hot chips are without using the "finger test"
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    #949
                    yes got spares of the lm4040 so thats ok what crystal does the ay-at come with is it worth upgrading? and yes that looks like a good ir thermometer i will have a good look through there site whilst the sales on, i was going too make a post asking if anyone had spotted anygood bargains etc we all like too build our test equipment/parts stock up.
                      • 31040
                      upgrade to a 16MHz crystal too.
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        #951
                        GM328R firmware attached containing latest SVN version 798 of Karl-Heinz firmware.
                        This time 16Mhz and 20Mhz builds are included, I have tested both.
                        • Dutch52
                          Retired
                          • Aug 2016
                          • 9
                          • Netherlands
                          #952
                          @STJ
                          Is your old machine still sketchy ?
                            • 31040
                            worse,
                            drive is dead
                            i know why - the motor driver ic is shorted (ST smooth series) - i'm looking for a donor drive to get another chip.
                              • 31040
                              component testers
                              just did a fresh build
                              not tested yet.
                              GM328 - every option on, low bat @7.2v
                              AY-AT no BJT / PUT testing - i tried real hard but there is simply not enough flash.
                                • Jul 2011
                                • 6039
                                Re: component testers
                                Are you going to show any pictures of the unit that you are building
                                  • 31040
                                  i did, nothing has been added since.
                                  the way i see it, there is no point building one if it costs over twice as much in parts as buying one from china and upgrading the crystal.
                                  i will buy a new one when i see one with an atmega664 or 1284 and a colour display that i like.
                                  i wont buy or recomend any atmega328 based stuff now, they just dont have enough memory for all the features.
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8701
                                    Anyone have a PUT or UJT to play with on these testers?
                                    SCS?
                                    I suppose DIACs are more available but testing such on these things are going to be tough?
                                      • 31040
                                      maybe a diac works - i dont have one to try.
                                      not even seen one for decades.
                                      in theory it may be detected as 2 diodes.
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8701
                                        I have a few UJTs in my junk pile, but not PUTs or SCSs. Yeah probably should show up as two diodes or something to that extent. (Incidentally, how could SCS be tested? has more than 3 pins...)
                                        DIACs I have a couple and they're still being made/used, but I don't think they could be properly tested. They might detect as a funky high ohm resistor or something? Not sure. I don't have one of these testers to try.
                                          • 31040
                                          a diac would probably show as a pair of zeners.
                                          i think i may have one on an old switching psu for halogen lamps - maybe i will be able to test that theory.
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                            12-31-2023, 06:04 AM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • irepair559
                                            ps4 1215 model Changed port and encoder still no video?
                                            by irepair559
                                            hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
                                            Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
                                            ps4 seems to boot fine blue light then solid...
                                            01-01-2023, 12:41 AM
