ESR meter upgrades
	This is a sticky topic.
Re: ESR meter upgrades
I'm still trying to figure out how to compile my own custom build. I have a windows 7 computer with WinAVR installed. I have the following files-
TransistorTester.eep
TransistorTester.hex
make_frequency.c
Makefile (16MHz)
Transistortester.h
I understand all the options in the makefile, I just have no clue as to where to go after I make the changes I want.
I'm using the build that stj made for me with the lipo battery warning settings but it only uses half of the screen for some reason. I really want to learn this stuff. I have a second AY-AT kit and the display seems a little different, I want o make a build for that too.Comment
You must download the source code.
It's at this URL: https://www.mikrocontroller.net/svnb...ster/Software/
Here would be the example command on a Linux machine with SVN installed:
Code:svn checkout svn://mikrocontroller.net/transistortester/Software/trunk
"The one who says it cannot be done should never interrupt the one who is doing it."Comment
STJ could you compile a version for the AY AT color kit with a 20 MHZ clock and a precision reference upgraded? Many thanks in advance! When I tried to compile 1.30m earlier it bricked my tester.Comment
wait a while - the option you need is NOT in any makefile.I'm still trying to figure out how to compile my own custom build. I have a windows 7 computer with WinAVR installed. I have the following files-
make_frequency.c
Makefile (16MHz)
Transistortester.h
i was discussing this with karl the other day - there are options in the code that got left out of the makefile-mess.
btw, i'm now using a 6x8 font - it looks better than it sounds!Comment
AH I wondered why your output file was named transistortester.hex!!
....and why the makefile looked similar but not the same. Let me do some more reading and see if I can dig up a 16 mhz crystal then I should be able to use your previously uploaded hex file.
Thanks for the prompt reply!Comment
This is the firmware that has given me the vext screen.
LCR_T4StripGrid_Ver736Ru_8x16t_Vext_Encoder_16MHz.zip\
If I could get the english version I think it may work on my LCR-T4-H.
JohnComment
Is there a way of changing the language easily as I would like to give this firmware a go unfortunately it has Russian text.
JohnComment
Have just received encoder and fitted to my LCR_T4_H along with two 10k & two 1k resistors, also changed 8mhz crystal to 16mhz but seem to be unable to find any firmware that will work the \LCR-T3,4_v1.12k_r660_ENC13.zip\LCR-T3,4_v1.12k_r660_ENC13\ works of sorts showing capacity at double the value
and locks up as soon as you move the encoder to blank screen you then have to disconnect the battery to reset it. any help will be appreciated.
JohnComment
Did you try this one?Have just received encoder and fitted to my LCR_T4_H along with two 10k & two 1k resistors, also changed 8mhz crystal to 16mhz but seem to be unable to find any firmware that will work the \LCR-T3,4_v1.12k_r660_ENC13.zip\LCR-T3,4_v1.12k_r660_ENC13\ works of sorts showing capacity at double the value
John
https://www.badcaps.net/forum/showpo...&postcount=896
When I reach to PC I can upload version for 16MHz since there is for 8MHz and display double value for capacitors.Comment
Thank you all for your input.
I have now found firmware for my LCR_T_4_H as stj has suggested it uses T4 stripgrid, every thing seems correct as far as component diagnostics with the 16mhz crystal and encoder fitted.
The problem I have is I can select items from the menu with the encoder but can not open them, with any amount of pressing the button, any ideas.?
Thanks Gabiz I have tried that one with no luck. Sorry thumb nails are bright and poor focus unable to reduce contrast.
JohnLast edited by TEDDIBEAR; 12-16-2017, 04:40 PM.Comment
so long-press does not select?
what i'm looking into is a new makefile that auto-calculates some settings.
for example the number of menu lines can be derived from the display "y" size divided by the vertical size of the selected font.
so no need to change it manually for different hardware or font settings.Comment
Have tried many combinations holding button down from a quick click to 30 seconds, I was wondering if there is an enable contact on the chip that could be switched.so long-press does not select?
JohnComment
			by chth96I read EBOOK of Testing Electronic Component and found that
Is it really possible to test small ceramic disc capacitor with analogue...-
			by sam_sam_samI have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery... -
			by jorpecHi
Thnaks -
			by sam_sam_samAbout a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer... -
			by irepair559hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
ps4 seems to boot fine blue light then solid... - Loading...
