ESR meter upgrades
This is a sticky topic.
+ More Options
Posts
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    #881
    Re: ESR meter upgrades
    If you are building on CentOS7 or RHEL7 I made a small writeup here.
    If not the version of GCC should still be relevant no matter what build OS you have.
    https://www.badcaps.net/forum/showpo...&postcount=773
    • TEDDIBEAR
      • Oct 2014
      • 45
      • england
      #882
      I have just received a couple of 16mhz crystals and fitted one to my T4 tester
      with the old program which is v1.12 all the capactors read double there value where as resistors and transistors seem to read within tolerence, I have tried several 16mhz firmware upgrades with no luck just a blank screen, any suggestions ? if all else fails I can always revert to the 8mhz crystal. the original firmware was V2.68 which I lost due to corruption and damage to the original chip, (my fault) did not discharge capacitor.
      John
        • 31269
        post foto's of the board
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8706
          Piece of s*$#(%t...
          I remember having so much trouble making sure that gcc fit everything in flash and got so pissed off when gcc version bumps caused bloat, and it's still a problem...
            • 31269
            i think the good one is 4.8
            need to fire up the other box & check.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8706
              I was pissed off that I kept 3.3.something for a long time because it produced the smallest code...
              Alas had OS compatibility issues as it was kept back for so long and forced to delete it.
              • TEDDIBEAR
                • Oct 2014
                • 45
                • england
                #887
                Picture of the board is shown in #825.
                John
                  • 31269
                  test these - let me know which gives you a display.
                  that's all its for btw, determining how the display is wired.
                  • TEDDIBEAR
                    • Oct 2014
                    • 45
                    • england
                    #889
                    Hi stj;Have downloaded your firmware the strip grid16 is the one that gives a display see thumbnails the other (16mz) is blank.
                    John
                      • 31269
                      good, now go into the contrast menu if you can, and find the best setting
                      • TEDDIBEAR
                        • Oct 2014
                        • 45
                        • england
                        #891
                        Hi stj; do not seem to be able to get the contrast menu up only having one button to press.
                        John
                          • 31269
                          long press / short press combinations should work - sort of.
                          • TEDDIBEAR
                            • Oct 2014
                            • 45
                            • england
                            #893
                            Tried a combination of long short presses with link in and out all to no avail.
                            john
                            • TEDDIBEAR
                              • Oct 2014
                              • 45
                              • england
                              #894
                              If I press the button once it goes into test and then this screen with no component connected and stays like this until battery is disconnected.
                              John
                                • 31269
                                when it's off, hold the button down.
                                you will get a menu, or it's not enabled - i didnt check.
                                • gabiz_ro
                                  • Mar 2011
                                  • 171
                                  #896
                                  Same board as TEDDIBEAR have.Except crystal at 16MHz.
                                  Replaced push button with encoder.
                                  Tested few versions,some no display,some display OK but only push button works no encoder.
                                  Finally found this one
                                  https://www.mikrocontroller.net/svnb..._T3_T4_st7565/
                                  But crystal on board was already 16MHz so display double value.
                                  Change value in makefile and works fine.
                                  • TEDDIBEAR
                                    • Oct 2014
                                    • 45
                                    • england
                                    #897
                                    No unable to get any menu by holding button down. only test which if you do not insert component reads 54.62pf then if you insert 3 pin link it will run through some information as pictured in previous thread this is the only way to get it to switch off automatically, if you do not insert link it just sits at 54.62pf.
                                    John
                                      • 31269
                                      the test i posted is 16MHz, it was to see how the display was wired.
                                        • 31269
                                        John
                                        ignore that firmware - it's done it's job.
                                        now i know how your display is wired, i can make a "real" firmware later.
                                        • TEDDIBEAR
                                          • Oct 2014
                                          • 45
                                          • england
                                          #900
                                          Hi have never worked on makefile so would not know how to change any values
                                          any help would be appreciated.
                                          John
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                            12-31-2023, 06:04 AM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • irepair559
                                            ps4 1215 model Changed port and encoder still no video?
                                            by irepair559
                                            hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
                                            Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
                                            ps4 seems to boot fine blue light then solid...
                                            01-01-2023, 12:41 AM
