ESR meter upgrades
This is a sticky topic.
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: ESR meter upgrades
    Good to know. Thank you. I am happy with the project.
      • 31246
      i'm wondering if an adapter could be made for testing optocouplers.
      after one gave me some agrivation yesterday!
        • 31246
        update
        • SteveNielsen
          Retired Tech
          • Jun 2012
          • 2327
          That oughta be doable but I think you'd need a 4th test lead configured so you can flash the led side with two leads and check the conductivity of the phototrans side with two in order to preserve isolation. If you weren't concerned about complete isolation I think you could do a basic test with three leads using one common for both sides of the coupler.
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            update
            Do you have the makefiles for these updates?
              • 31246
              obviously, i had to make them up.
              it's not just the makefile,
              the source is here:
              https://www.mikrocontroller.net/svnb...ster/Software/
              the files i'm changing are:
              the makefile,
              Transistortester.h < to change the version string,
              function_menu.c < to make the rotary encoder work better in the menu.
              • SteveNielsen
                Retired Tech
                • Jun 2012
                • 2327
                Well, I figured you did but what I mean is I want to know more about what you've changed because I'm more curious than can be satisfied with "something vague" as a change description.
                  • 31246
                  update
                  this one fixes a bug wih BJT transistors.
                  put the makefile in now
                    • 31246
                    on the makefile i had to change the lcd contrast, the battery sense voltdrop, the rotary & serial settings.
                    maybe the pullup resistors - cant remember - you can diff it now.
                    on the menu code, i just commented-out all the code that tried to interpret the button duration to do menu up/down so it just does "select" now.
                    **which is why i say not to use this on a unit without the rotary encoder - you wont be able to navigate the menu!
                    • SteveNielsen
                      Retired Tech
                      • Jun 2012
                      • 2327
                      Very cool, thanks much. I haven't updated since I got mine going, been dealing with other non-tech matters lately. I really appreciate the time and energy you put into this project. I know you dig doing it anyway but you've certainly got my gratitude. Thanks buddy
                        • 31246
                        wow!
                        read this:
                        https://github.com/svn2github/transi...32dbf07841d6a8
                        time to upgrade the crystal from 8 to 16Mhz
                        and fresh from the compiler
                        8 and 16MHz versions
                        • SteveNielsen
                          Retired Tech
                          • Jun 2012
                          • 2327
                          Trippy. This project goes on and on... cool. Any particular spec on the 16MHz xtal or will any do that fits?
                            • 31246
                            same size as the original
                              • 31246
                              new update.
                              cleaning up the new crystal tester function.
                              Last edited by Per Hansson; 02-10-2016, 07:29 AM. Reason: Removed rev632 due to post below
                                • 31246
                                dont download 632 - i made a slip wih the menu code!
                                • SteveNielsen
                                  Retired Tech
                                  • Jun 2012
                                  • 2327
                                  Is there any advantage to using a 16MHz over the 8MHz other than for crystal/resonator testing?
                                    • 31246
                                    probably not, although it may increase the range of the frequency generator function.
                                    it will also flatten the battery a little faster.
                                      • 31246
                                      another update.
                                        • 31246
                                        quick warning, dont upgrade to a 16MHz crystal if you didnt already.
                                        i'm looking into if the atmel can be run as nature intended - at 20MHz
                                        • SteveNielsen
                                          Retired Tech
                                          • Jun 2012
                                          • 2327
                                          Ok. I'm not going for the xtal upgrade yet and I'm at SVN630 for now. I haven't had any need to test xtals or resonators but it'd be fun anyway I suppose.
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                            12-31-2023, 06:04 AM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • irepair559
                                            ps4 1215 model Changed port and encoder still no video?
                                            by irepair559
                                            hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
                                            Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
                                            ps4 seems to boot fine blue light then solid...
                                            01-01-2023, 12:41 AM
