ESR meter upgrades
This is a sticky topic.
Re: ESR meter upgrades
cheers stj i will have ago tomorrow at building this kit and post the results.Comment
next time i place a rs order i will add those too it stj what will i need too do regarding software upgrades ive got to admit ive never dealt with this side of things ie re programing chips etc so i guess i will need a chip re programmer?Comment
cheers stj i have already got a pack of 100nf polyester caps here so willl use one of these if its ok just to clarify something each time you remove the 9volt battery do you have too re calabrate these units? (i always do but wasnt sure if needed too)Comment
update for stj ive built the kit up as per your list bad news does not power up on pin 7 and 22 of the empty ic socket i get about 1.46v should be 5v i think? the screen does flash very quickly with the ic installed, now i dont want to start swopping resistors around etc as its really hard to remove them and leave a clear hole in the pcb the good news is the ebay seller of the kit has refunded me fully so ive just ordered a pre built kit from a diffrent store but exactly the same board revision etc so when it comes i will check all resistor values as per good working tester and the one ive built as a kit and see where ive gone wrong i did double check all the resistor values today using the hobby-hour calculator and all seems spot on with your list so will update this thread as soon as the pre built kit arrives.Last edited by vinceroger69; 06-20-2016, 07:26 AM.Comment
it's saved in the eeprom.Comment
short the emitter and collector on the 4673 transistor and try again - not sure what the hell a 4673 is anyway!update for stj ive built the kit up as per your list bad news does not power up on pin 7 and 22 of the empty ic socket i get about 1.46v should be 5v i think? the screen does flash very quickly with the ic installed, now i dont want to start swopping resistors around etc as its really hard to remove them and leave a clear hole in the pcb the good news is the ebay seller of the kit has refunded me fully so ive just ordered a pre built kit from a diffrent store but exactly the same board revision etc so when it comes i will check all resistor values as per good working tester and the one ive built as a kit and see where ive gone wrong i did double check all the resistor values today using the hobby-hour calculator and all seems spot on with your list so will update this thread as soon as the pre built kit arrives.Comment
im not sure what it is either no data sheet that i can see and the numbers rite as just checked wasnt sure wich pins to link but tried all combinatons no change hopefully pre built tester will be here soon last kit only took 9 days to arrive.
ive emailed all the sellers selling this version of the kit none come with part location/values etc, instructions and none will send me a picture so we can see resistor colour bands clearly i think thats why i got a refund so fast too as maybe other people buying these kits are having trouble too.Last edited by vinceroger69; 06-20-2016, 08:44 AM.Comment
short the center pin to the pin nearest the battery + lead.
then you should see 9v on the rightmost pin of the surface-mount 1117 regulator, and 5v coming out of the tab.
if you dont, check the electrolytics arent reversed and check between those points and ground for a short.
because frankly - there is nothing else involved in generating the 5v.Comment
bear with me stj im going over each part ive fitted just too double check my parts ive fitted are in the correct locations etc and just nipping to get my multi meter back as was using a cheap one (neighbours borrowing my good one)Comment
So a update with my good meter and new battery pins 7 and 22 5.01 v when hold rotary switch down bad news screen will only stay lit with no writing on screen just backlight? when rotary switch is held down no led on board lit when testing voltage or when switch held down.Comment
when encoder held down have 5v on the socket pins ok re install ic press encoder button backlight very quick flash then off.Comment
by chth96I read EBOOK of Testing Electronic Component and found that
Is it really possible to test small ceramic disc capacitor with analogue...-
by sam_sam_samI have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery... -
by jorpecHi
Thnaks -
by sam_sam_samAbout a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer... -
by irepair559hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
ps4 seems to boot fine blue light then solid... - Loading...
