ESR meter upgrades
This is a sticky topic.
    • 31300
    Re: ESR meter upgrades
    Originally posted by socketa
    Yeah, the penny dropped just dropped a few minutes ago.
    The GM328 on that website works good but no rotary encoder/option.
    post a foto or link of your unit.
    • socketa
      Asbelowsoabove
      • Jun 2014
      • 663
      • samsara
      #742
      the frequency code that you can allegedly input any frequency is very difficult to use
      Before i bricked the chip, and got another one, after few minutes of practice, i found it easy to get any frequency between 1hz and 999khz - it's was just a matter of holding the button in a bit longer, and getting the knack of it (put the last number in first). And all of the frequencies displayed correctly on my multimeter, which was connected to the output
      I found it easy as pie.
      Easier to learn than the pentatonic scale.
      Took me about 15 seconds to set a frequency of 456.789Khz
      If it's easy enough to recomple it to include this feature again, that would be appreciated.
      Now, all of that programming stuff is what i'd call "very difficult".
      OK, photo coming soon (just need to charge camera batteries)
      Your last update GM328x ESR tester (SVN700)(inverted encoder) worked perfectly, except i would have preferred to have the option to 'punch in' any frequency that i wanted.
      Here's the pic
      With the wrong software on the chip (just to show that the frequency generator works good)
      Probably a bit off because i couldn't be bothered calibrating it - but still, pretty good.
      645.321khz
      https://www.badcaps.net/forum/attach...1&d=1482044324
      • socketa
        Asbelowsoabove
        • Jun 2014
        • 663
        • samsara
        #743
        Here's a better Pic, the meter possibly loses accuracy on the higher ranges.
        https://www.badcaps.net/forum/attach...1&d=1482045580
        6789Hz - Spot on!
          • 31300
          o.k. just wanted to check the version - it's a GM328r
          • jondoe
            • Nov 2016
            • 547
            stj - I compiled the firmware using your makefile and I get an oversized program;
            Code:
            AVR Memory Usage
            Device: atmega328p
            Program:  35092 bytes (107.1% Full)
            (.text + .data + .bootloader)
            Data:    454 bytes (22.2% Full)
            (.data + .bss + .noinit)
            EEPROM:   879 bytes (85.8% Full)
            (.eeprom)
            I had a similar problem with my own firmware at first until I tinkered with the Makefile. I'm assuming it won't work if it's too large! Which tool chain do you normally use? I'm using the default one with winavr.
            I also noted that the supplied precompiled st7565_kit versions do not work at all (device won't power up), nor do the make files create working firmware .
              • 31300
              you need an older version of gcc, i use the one that is in the arduino ide.
              • jondoe
                • Nov 2016
                • 547
                Ahh yes, so I did, thank you. I tried 3.4.5.30 and the compiled firmware is coming in at a more suitable size.
                Attached is the 8mhz compile, latest version, hope that solves your display problem socketa.
                • socketa
                  Asbelowsoabove
                  • Jun 2014
                  • 663
                  • samsara
                  #748
                  Thanks, that's better, but the makefile needs to have the rotary direction reversed.
                  Opened it in WinAVR Programmers notepad, and tried Tools> Make All
                  But it returned this output:
                  > "make.exe" all
                  makefile:381: ../setup.mk: No such file or directory
                  makefile:428: ../finish.mk: No such file or directory
                  make.exe: *** No rule to make target `../finish.mk'. Stop.
                  • jondoe
                    • Nov 2016
                    • 547
                    I've commented out the following in the make file;
                    CFLAGS += -DCHANGE_ROTARY_DIRECTION
                    I assume this will now swap the direction
                    (forgot to update the Makefile in the zip, sorry!)
                    • jondoe
                      • Nov 2016
                      • 547
                      > "make.exe" all
                      I just have Winavr, the complete source code package for the transistor tester (all of it, every sub directory) and the older tool chain copied over the top of the winavr one. That seems to do the trick.
                      • socketa
                        Asbelowsoabove
                        • Jun 2014
                        • 663
                        • samsara
                        #751
                        Downloaded transistor-tester-master.zip and extracted it into a folder
                        Downloaded avr-toolchain-installer-3.2.3.579-win32.win32.x86.exe, and that installed Amtel folder (not "over the top of the winavr one")
                        Opened up the makefile (from the extracted folder) with WinAVR Programmers notepad and then Tools> Make All.
                        No surprise, same errors as before
                        Obviously i've got no idea what i'm doing.
                        • socketa
                          Asbelowsoabove
                          • Jun 2014
                          • 663
                          • samsara
                          #752
                          Thanks for that, guys.
                          Tests OK
                          • jondoe
                            • Nov 2016
                            • 547
                            I only started playing with these chips two weeks ago so it's been an uphill struggle getting to this point Winavr should compile without the other tool chain, but you will need to copy the contents of that folder Amtel folder over into the winavr folder if you want it to be 100%
                            The Makefile you're opening, is it in the mega328_GM328 folder? If not, i.e. you're opening it from the zip file, that won't work. Put the updated/custom Makefile in the mega328_GM328 folder, over writing the one in there. Then open that Makefile with winavr.
                            Glad the one I compiled is working for you
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #754
                              another new style cheap esr tester
                              https://youtu.be/K-5zZfc1XkE
                              http://www.ebay.com/itm/LCR-TN-Multi...UAAOSw4A5YqGjb
                              • gino_09
                                • Apr 2017
                                • italy
                                #755
                                Hi, I'm new. I bought the gm328 with tft and i saw someone displaying the colored symbols. As firmware I have to load for the color to be able to? Thanks and compliments for the great work.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  #756
                                  all the latest firmware is in this thread you just need to make sure it matches your tester and tft used
                                  https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    #757
                                    Hey stj, tried to compile the latest SVN version using your makefile for GM328x
                                    But the file becomes too big in the latest SVN.
                                    I'm using CentOS7 and avr-gcc v4.8.2
                                    Is there something not so useful that I can remove from the Makefile to get the size down a bit?
                                    SVN700 build:
                                    Code:
                                    16 MHz operation configured.
                                    AVR Memory Usage
                                    Device: atmega328p
                                    Program:  32592 bytes (99.5% Full)
                                    Data:    206 bytes (10.1% Full)
                                    EEPROM:   922 bytes (90.0% Full)
                                    (.eeprom)
                                    SVN740 Build:
                                    Code:
                                    AVR Memory Usage
                                    Device: atmega328p
                                    Program:  32892 bytes (100.4% Full)
                                    EEPROM:   916 bytes (89.5% Full)
                                    (.eeprom)
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      #758
                                      SVN700 build:
                                      Code:
                                      AVR Memory Usage
                                      Device: atmega328p
                                      (.eeprom)
                                      SVN740 Build:
                                      Code:
                                      AVR Memory Usage
                                      Device: atmega328p
                                      (.eeprom)
                                      will this be the latest firmware for the testers we built earlier in this thread? if so if possible do you mind sharing the 8 and 16 mhz versions so i can upgrade my testers as im still using the firmware from earlier in the thread thanks .
                                        • 31300
                                        i'll see if i can get that machine up & running at the weekend,
                                        i was going to set it up this week, but a visual inspection (as you do) showed bad psu caps - so i had to pull it apart.
                                        post the makefile.
                                        • Per Hansson
                                          • Jul 2005
                                          • 5895
                                          • Sweden
                                          #760
                                          It's your makefile from the last ZIP: "GM328x ESR tester (SVN700).zip" that you posted here:
                                          https://www.badcaps.net/forum/showpo...&postcount=730
                                          And I did use your "make_frequency.c" file too, otherwise the file becomes even larger.
                                          (My aim was not not use it, and switch back to the "standard" frequency input way too...)
                                          Of course, but need to know what I can remove from the firmware as the latest build results in a too large firmware...
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                            12-31-2023, 06:04 AM
                                          • Ryan Wurtz
                                            Lenovo Yoga C740-15IML 5V on usb meter.
                                            by Ryan Wurtz
                                            Hello. So I searched and didn't find any posts on this specific problem.
                                            When plugged in USB power meter reads 5v
                                            Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
                                            Original mobo had a shorted cpu it seems.
                                            So I decided I need a new motherboard.
                                            Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
                                            5v on the meter. Still won't charge. Can still charge the battery...
                                            11-24-2025, 01:08 AM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
