ESR meter upgrades
This is a sticky topic.
    • 31296
    ESR meter upgrades
    so - rotary encoder time.
    get your rotary encoder and bend and trim the center pin so it sits on the top of the board - like this:
    • 31296
    Re: ESR meter upgrades
    next, take the original switch off, and scrape some laq off the top of the pcb for the center pin like this:
    (only for this model of meter)
      • 31296
      next, solder the encoder in,
        • 31296
        next you need a pair of 1k resistors and a pair of 10k resistors and some thin wire.
        just to be clear, the place the 10k resistors join the wire is NOT connected to the pcb!
          • 31296
          next you need to link the 2 cpu pins to the resistors.
          WARNING - this is pro-soldering!
            • 31296
            if you do it clean, it should look like this:
              • 31296
              back to the top of the pcb,
              solder the center tab of the encoder to the ground-point you remembered to scrape-clean on the pcb.
                • 31296
                2 foto's i had left.
                  • 31296
                  and does it work?
                  NO - i have to compile new firmware first.
                  still, the hardware is done now.
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    Thank you for the walk through!
                      • 31296
                      AND - IT'S HERE!
                      latest firmware compiled for this model by me.
                      with rotary encoder, new fonts/gfx, serial-port etc.
                      • elval
                        • Nov 2015
                        • Hrvatska
                        Thank you
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          what extra functions does this firmware/encoder mod gain?
                            • 31296
                            depends.
                            if your tester is pretty new and id's as 1.12k then nothing really, just a lot easier to use the menu function.
                            if your tester is old and running 1.11k or older then probably lots of new stuff.
                              • 31296
                              i am going to be making some updates to that file.
                              just saying.
                                • 31296
                                update:
                                btw, i'm willing to compile this for the T3 / T4 boards if asked.
                                • SteveNielsen
                                  Retired Tech
                                  • Jun 2012
                                  • 2327
                                  Thank you man. You're sure to be on Santa's nice list for this
                                    • 31296
                                    bugfix.
                                      • 31296
                                      config fix.
                                      previous builds wont read inductors properly.
                                      • japlytic
                                        • Oct 2005
                                        • 2086
                                        There is one thing ESR meters should have, which is Kelvin sensing (4-wire measurement capability), which keeps measurement errors to a minimum.
                                        • chth96
                                          by chth96
                                          03-09-2024, 10:03 PM
                                          12-31-2023, 06:04 AM
                                        • Ryan Wurtz
                                          Lenovo Yoga C740-15IML 5V on usb meter.
                                          by Ryan Wurtz
                                          Hello. So I searched and didn't find any posts on this specific problem.
                                          When plugged in USB power meter reads 5v
                                          Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
                                          Original mobo had a shorted cpu it seems.
                                          So I decided I need a new motherboard.
                                          Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
                                          5v on the meter. Still won't charge. Can still charge the battery...
                                          Yesterday, 01:08 AM
                                        • jorpec
                                          by jorpec
                                          Hi
                                          Thnaks
                                          01-23-2023, 10:37 AM
                                          Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                          12-14-2023, 07:45 PM
