ESR meter upgrades
This is a sticky topic.
  • TEDDIBEAR
    • Oct 2014
    • 45
    • england
    #921
    Re: ESR meter upgrades
    Originally posted by stj
    well i'm confused.
    there is only one button input, and i assume it works because you can power the unit on.
    maybe that assumption is a mistake - let me check the schems.
    There is only S1 start button on this device.apart from the addition of the encoder.
    could it be the 16mhz crystal causing the problem of selection.?
    I have checked the voltage on the start button which shows 9 volts collapsing to .7 volt on press on then returning to 2.7v on the live side powering the display, returning to .7volt every press, voltage on PD 7 drops from +5 volt to .7 and returns to 5+ on release of the button.The encoders center pin is to chassis
    each leg is supplied from 5+ rail via 10k resistor and PD1 & PD3 is fed via 1k resistors. The firmware I am using is your TEST 16mhz stripboard. which seems to tick all of the boxes except select from the menu.
    John
      • 31301
      that firmware is totally unconfigured.
      i'll post something better later.
        • 31301
        some quick builds:
        GM328 and AY-AT for 16MHz
        both using compact font with more menu lines.
        and a T4(strip-grid) 16MHz testbuild for TEDDIBEAR.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          #924
          stj you know that 2016 tester you helped me build etc is there a case available for them? ive had a quick look on aliexpress etc and cant seem too find one.
            • 31301
            no idea.
            there are probably 3d printed ones if you ask over at eevblog
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #926
              Thanks i will ask in the thread and see what they suggest i might also update to a AY AT at tester as there are cases/firmware already available.
                • 31301
                can one of the people who downloaded the AY-AT code please post a screenshot of the menu screen.
                i'm ajusting the number of lines to fill the screen.
                • Dutch52
                  Retired
                  • Aug 2016
                  • 9
                  • Netherlands
                  #928
                  Here some screenshots of the "AY-AT" with SVN749 (STJ V2) firmware.
                    • 31301
                    fuck, i set that for 16lines.
                    must be more shit hidden away.
                    • TEDDIBEAR
                      • Oct 2014
                      • 45
                      • england
                      #930
                      some quick builds:
                      Hi stj
                      thank you for your update I am afraid I am still unable to select from menu
                      here are the results. + when a test is made it stays on the screen for a split second too quick to read
                        • 31301
                        the russian one didnt have these problems??
                        • TEDDIBEAR
                          • Oct 2014
                          • 45
                          • england
                          #932
                          I think the problems with the menu side were the same, having said that I can not read Russian but the menu did not seem to change when a selected item was pressed. Your first T4 worked perfectly as did the second T4 as far as diagnosis were required the second one had smaller fonts and very fast, the problem seems to be selection from the menu pressing button.
                          John
                          • turbochris
                            • Sep 2017
                            • 9
                            Hi STJ, I like your avatar, I've been in facebook jail 5 times already. Can you please compile another lipo version of the AY-AT like you did for me before on post 855 but with the modifications that fill up the display? the 3.2 volt cutoff version worked best, the 3.6 cutoff version gave me a low battery warning when the lipo was at 3.9. BTW the rechargeable mod I made in post 873 works great.
                              • 31301
                              the build box is out of action for a couple of days - i'l take a look after.
                              • turbochris
                                • Sep 2017
                                • 9
                                Do you have a paypal account? I would like to give you something for your buildbox fund. You've been very helpful. private message me your account address.
                                • Dutch52
                                  Retired
                                  • Aug 2016
                                  • 9
                                  • Netherlands
                                  #936
                                  @STJ,
                                  Did you get any further investigating the AY-AT firmware?
                                  (See message 928)
                                    • 31301
                                    no, i need to get back to that.
                                    • Harah
                                      • May 2018
                                      Hopfully this isn't too off topic. Is there a concensus on a good prebuilt variant of these component testers? I'm particularly interested in using one for manual ESR testing.
                                      • Per Hansson
                                        • Jul 2005
                                        • 5895
                                        • Sweden
                                        #939
                                        https://www.aliexpress.com/item/BSID...832292103.html
                                        • Harah
                                          • May 2018
                                          Thanks for the recommendation. I like that it has a case and probe ports. But I'm wondering if it has menu access like the GM325. Does this allow for manual settings for component testing? I mean can it be set specifically for testing ESR, without the firware trying to guess what the component type is? Also, I have read that it does have a flashable firmware. Can you confirm this?
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                            12-31-2023, 06:04 AM
                                          • Ryan Wurtz
                                            Lenovo Yoga C740-15IML 5V on usb meter.
                                            by Ryan Wurtz
                                            Hello. So I searched and didn't find any posts on this specific problem.
                                            When plugged in USB power meter reads 5v
                                            Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
                                            Original mobo had a shorted cpu it seems.
                                            So I decided I need a new motherboard.
                                            Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
                                            5v on the meter. Still won't charge. Can still charge the battery...
                                            11-24-2025, 01:08 AM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
