ESR meter upgrades
	This is a sticky topic.
 Re: ESR meter upgrades
 no the other one for my 2016 tester just in case is faulty in anyway the smd ic still not come as yet.Comment
 43 contrast is good, the default 40 is also fine tbh
 and fans?Comment
 standard 16mhz just a blank screen then powers off
 strip grid blank screen tester stays on untill powerd offLast edited by vinceroger69; 07-21-2016, 06:28 AM.Comment
 Thanks for the files for my old tester will update you when the smd ic comes and i forgot to pick up the right angled header so just ordered one.
 My 2016 tester works great now so far i have just added the 16 mhz crystal changed the voltage regulator and used the new atmega 328p ic and updated firmware too your small font 16 mhz one and calibrated the unit seems to work ok now so thanks for your help with this tester i will continue with the old tester asap.Comment
 just a thought stj i wasnt going to change the power button on this spare tester so no rotary encoder will your files still work ok?Thanks for the files for my old tester will update you when the smd ic comes and i forgot to pick up the right angled header so just ordered one.
 another question im thinking of fitting the blue led screen i have spare here for this tester you mentioned i may have to alter the resistors? as blue uses diffrent voltages anyidea what size smd resitors and ohms value i may need so i can add some to rs order thanks.Comment
 Yes, i added the molex connector, I didn't like the soldered wires and i have plenty of spares, it felt a bit flimsy and I changed the battery connector to one of the hard plastic types.
 Thanks for the info on the 10 bit PWM setting. I don't think it's a feature i'll need to use.
 Impressive bit of kit for £11.Comment
 everything from china is impressive, i suspect it's just that we have been ripped-off for so long that the real cost of stuff is a shock to us.
 i just picked 2 these up:
 http://www.ebay.co.uk/itm/321454659128
 i remember paying £8 for one in maplin over 20years ago!
 and some of these to go with it.
 http://www.ebay.co.uk/itm/141666306520Comment
 Back when Maplins was good and the staff could suggest alternative components for your projects.everything from china is impressive, i suspect it's just that we have been ripped-off for so long that the real cost of stuff is a shock to us.
 lol - dont get me started on that.
 last time i was in one, the woman gave me the wrong resistors.
 she said they were in the right drawer and thought i was messing her about - she had no idea the coloured bands actually meant anything!!!!!!!!!!!!!!!!!!!Comment
 The colours mean something ?? I thought they were just to pretty those thingys up !!
 I nipped in as I was on a job and needed a 1m patch cable.
 "£13 for a Cat6e, is the cheapest we have mate"
 "Thanks, I'll be going to the pound shop over the road then"Comment
 Hello All
 This is my first post in here and I was referred by another member since sadly I bough a tester from
 http://www.ebay.com/itm/191869802386...%3AMEBIDX%3AIT and it came bad.
 The tester doesn't turn not. When I press the rotary button the LCD lits and as soon as I release the button it turns off.
 I tried to reprogram the chip using the files from mega328_st7565_kit (the last ones on the site).
 TransistorTester.eep dated 4/21/2016
 TransistorTester.hex dated 7/9/2016
 but I do not know it it was success or not
 I got a spare blank chip. do you think I should try with that one? In case it doesn't work will I be able to reprogram my spare for use with arduino?Code:C:\AVR>avrdude -c usbasp -p m328p -F -B 4.0 -e -U flash:w:"TransistorTester.hex" :i -U eeprom:w:"TransistorTester.eep":i -U lfuse:w:0xF7:m -U hfuse:w:0xD9:m -U e fuse:w:0x04:m avrdude: set SCK frequency to 187500 Hz avrdude: warning: cannot set sck period. please check for usbasp firmware update . avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.01s avrdude: Device signature = 0x1e950f avrdude: erasing chip avrdude: set SCK frequency to 187500 Hz avrdude: warning: cannot set sck period. please check for usbasp firmware update . avrdude: reading input file "TransistorTester.hex" avrdude: writing flash (29952 bytes): Writing | ################################################## | 100% 20.10s avrdude: 29952 bytes of flash written avrdude: verifying flash memory against TransistorTester.hex: avrdude: load data flash data from input file TransistorTester.hex: avrdude: input file TransistorTester.hex contains 29952 bytes avrdude: reading on-chip flash data: Reading | ################################################## | 100% 15.55s avrdude: verifying ... avrdude: verification error, first mismatch at byte 0x0000 0x00 != 0x2d avrdude: verification error; content mismatch avrdude: safemode: lfuse changed! Was f7, and is now 8c Would you like this fuse to be changed back? [y/n] n avrdude: safemode: hfuse changed! Was df, and is now 0 Would you like this fuse to be changed back? [y/n] n avrdude: safemode: efuse changed! Was 1, and is now 6 Would you like this fuse to be changed back? [y/n] n avrdude: safemode: Fuses OK (E:01, H:DF, L:F7) avrdude done. Thank you.
 I'm sorry to be this cheap but where I live those chips are not easy to come by and bringing them in here is expensive.
 Thank you all for your help
 BelenComment
 I saw your post on eevblog are you programming the chip on the esr pcb? though a fitted header?Last edited by vinceroger69; 07-23-2016, 06:42 AM.Comment
 i dont know where you got the command for USBasp from,
 try this:
 and try these files:avrdude -c USBasp -P usb -p m328p -U flash:w:Code.HEX \-U eeprom:w ata.HEX \-U lfuse:w:0xf7:m \-U hfuse:w:0xd9:m \-U efuse:w:0xfc:m
		Attached FilesLast edited by stj; 07-23-2016, 06:45 AM. ata.HEX \-U lfuse:w:0xf7:m \-U hfuse:w:0xd9:m \-U efuse:w:0xfc:m
		Attached FilesLast edited by stj; 07-23-2016, 06:45 AM.Comment
			by chth96I read EBOOK of Testing Electronic Component and found that
 Is it really possible to test small ceramic disc capacitor with analogue...-
			by sam_sam_samI have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
			by jorpecHi
 Thnaks
			by sam_sam_samAbout a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
 Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
			by irepair559hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
 Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
 ps4 seems to boot fine blue light then solid...
- Loading...
