ESR meter upgrades
This is a sticky topic.
Re: ESR meter upgrades
i dont know how that programmer works.
but you only need the hex and eep files.
try this one.Attached FilesComment
mine was not a kit, it was the older version - 100% surface-mount and no rotary encoder.
it was copy protected and i had to draw up a schematic and patch the code to match it.
i also had to change the default contrast because initially the display looked blank!Comment
sorry stj i meant Per Hannson regarding the same kit he brought as me, its a good job stj you have experience in programing i have no idea but i am learning slowly i will try the above file and let you know thanks again.Comment
dave from eeblog has a good you tubevideo on this programmer minipro tl866cs
https://www.youtube.com/watch?v=FLG03f_ua5g
i will take a picture of the screen now about the fuses etcLast edited by vinceroger69; 07-12-2016, 08:52 AM.Comment
fuses was easy too set up as per your guide still scrolling display with one of your zip files and just a blank display with the other zip file
just a thought stj when adding your files i can add them as code memo or data memo which one is correct?Last edited by vinceroger69; 07-12-2016, 09:24 AM.Comment
Have not even received mine yet
"The one who says it cannot be done should never interrupt the one who is doing it."Comment
with all the settings as your instructions and tried the two diffrent zip files still no good one zip just blank screen other zip slightly diffrent scrolling data on screen in my picture of the fuses screen theres one section lock bit byte? ive got nothing ticked there.Last edited by vinceroger69; 07-12-2016, 09:50 AM.Comment
ok will give it one more try if it dosnt work it may find its way in the post too you.
well that didnt work either just the backlight on untill auto switch off.Last edited by vinceroger69; 07-12-2016, 10:32 AM.Comment
yes top two rows lit very small symbols/writing scrolling left to right at the moment with the second zip files just back light on and stays on for about a minute.
i would of thought with this programmer its the same really but your just removing the ic from the holder i have set the fuses as you have said thats easy to do im just looking at videos now to make sure im using the programmer rite.Comment
Finally mine arrived too!
I've got the same as vinceroger69, with the firmware from this post I get scrolling characters on the screen when I power on.
With the other firmware from this post it is blank.
The chip did contain a few bytes of code when I got it but for sure it was not a complete program.
The programmer acted like it was empty; like vinceroger69 explained in this post. (I attached what was there in the rar file).
With the scrolling text I can't do anything, if I press the encoder nothing happens, I need to remove the battery to power off.
The LCD is marked LCM_12864_V1.30 2015.09.01
I attached pictures showing the scrolling text and of the LCD backside.
I used a Willem GQ-4X USB Programmer to program the chip and set the fuses.
(I had to do a "Erase" first which I did not at first realize, took many attempts until I found out that was the problem because the program never got written properly, I did the programming in circuit.)Last edited by Per Hansson; 07-13-2016, 04:40 PM."The one who says it cannot be done should never interrupt the one who is doing it."Comment
o.k. i'l go look at the code.
i think the pinout is o.k. or the display wouldnt be on.
so probably a different chip in it.
try thisAttached FilesComment
by chth96I read EBOOK of Testing Electronic Component and found that
Is it really possible to test small ceramic disc capacitor with analogue...-
by sam_sam_samI have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery... -
by jorpecHi
Thnaks -
by sam_sam_samAbout a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer... -
by irepair559hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
ps4 seems to boot fine blue light then solid... - Loading...
