Isolation Transformer - Use One!
  • Longbow
    • Jun 2011
    • 623
    I'm sure it has been mentioned elsewhere, but it never hurts to remind techs to invest in an isolation transformer before they begin work on mains connected circuitry. Some variacs are isolated, some are not. But a nice isolated variac costs plenty. So does a differential scope probe. It is worth the money to invest in a 1:1 isolation transformer to prevent ugly electrical shorts between the mains and your scope, your soldering station, and other grounded test equipment.
    Technically the test equipment should remain grounded through a 3 conductor plug. We've all cut that ground plug at some point for lack of a transformer, but you give up an important safety factor by doing so.
    It is true that an electrical ground on all test gear can show up already existing sources of common mode noise, cause ground loops, etc. But in the end, these problems can be solved or improved without cutting the grounds. Working on the primary of a switching power supply means connecting your scope ground to one wire of the mains. Lots of computer supplies have "hot" heat sinks. Give it some thought - an isolation transformer is the right way to go.
    Is it plugged in?
  • Joe Black
    eager to learn
    • Sep 2015
    • 173
    • southeastern europe
    Re: Isolation Transformer - Use One!
    I have one (not sure if we mean the same thing though).
    Transformer (EU) 220V-220V? I've been told it can't kill.
    Also, you recommend plugging equipment after transformer, right?
    stay classy
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      A big isolation transformer is too expensive for me - whenever i need to probe the primary of something, i use an inverter and battery as i already had those lying around.
      A working TV? How boring!
      • japlytic
        • Oct 2005
        • 2086
        I've read about a dangerous practice mentioned in older Pace satellite receiver manuals, which is floating the oscilloscope ground while the probe is attached to the primary side (no mention of an isolation transformer!) and not touching anything on the oscilloscope.
        Many test equipment manuals have notices about grounding, such as "intentional interruption is prohibited".
        Even with an isolation transformer, I still prefer to use a differential oscilloscope probe on the primary side, since I remember when taking waveforms on the primary side of an online UPS (even when isolated from the mains with an isolation transformer), the connected probe was inducing noise (most likely common mode noise), which fortunately was not enough to cause damage).
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8703
          It would be nice if scopes didn't ground the shield... alas it hasn't been a problem for me as I've never had to scope out line voltages.
          I think the only time I wanted to see line level voltages is on a generator. But in this case I stuck in a (FILAMENT!) transformer on the generator side and looked at the waveform that way. I suspect I'll need to do the same to look at UPS outputs... but I haven't needed to look at that yet.
          I use my isolation transformer mostly for paranoia, just in case I accidentally touch those heatsinks...
            • 31250
            get a pair of gloves!
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              Speaking of UPS units - you can also use an UPS running off batteries in place of an isolation transformer - just remember to unplug it from the mains.
              • fzabkar
                • Mar 2009
                • 772
                I have 5kVA transformers which I've salvaged from some very, very old mainframes. They're heavy enough to anchor a battleship.
                • Joe Black
                  eager to learn
                  • Sep 2015
                  • 173
                  Here is mine.
                  Obviously not using it
                  stay classy
                  • SteveNielsen
                    Retired Tech
                    • 2327
                    I have this one, unused, bought new for $20 back in 2000. A dog chewed off the output cord before I ever got the chance to use it.
                      That is a good isolation transformer.
                      https://cdn.badcaps-static.com/pdfs/...2f49c61139.pdf
                      • SteveNielsen
                        Retired Tech
                        • 2327
                        Thanks for the pdf Bud. Yeah, I knew it to be a good quality unit when I bought it and when was fiddling with tube amps. I've got to get it wired up to an outlet or power strip. I don't like molded in-line ac jacks that much so the dog picked the right wire to chew off
                        It seems heavier than 16# though.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8703
                          Yeah these things are heavy...
                          Mine is a B&K Precision TR-110, it can only deal with 350VA continuous.
                          Nice thing about it is that if I need to muck with the voltage slightly, I don't need my variac... though my variac can handle more current...
                          • R_J
                            • 9607
                            I have a Hammond E 77033 transformer rated at 1500va, everything on the bench is connected through it. that way anything I work on is isolated.
                            • SteveNielsen
                              Retired Tech
                              • 2327
                              I've got an older Trippe-Lite LC-1200b line-conditioner with a big fat transformer in it. I don't know if it is isolating or not. Can't find enough tech info about it. It's switching with relays between different transformer taps.
                              There's a 1K trimpot on the board but no indication of what it adjusts. Last time it was used the output was 110vac when connected to 120vac.
                              • SteveNielsen
                                Retired Tech
                                • 2327
                                Nope, not an isolation transformer but I adjusted the trimpot to switch to the 120v tap with 120v input.
                                  It is AC Voltage regulator (switching taps on the transformer using relays to maintain AC output) and Line conditioner.
                                  http://www.tripplite.com/1200w-120v-...ection~LC1200/
                                  • SteveNielsen
                                    Retired Tech
                                    • 2327
                                    I do know what it is, just not sure of exactly how it is doing it.
                                    Measuring the transformer disconnected there is isolation between one winding and the other but I don't know which is pri or sec. I know in operation there is continuity between input neutral and output neutral and that is not an isolation. I can't find a schematic for the board so I guess I'll just have to get the board out and trace it out to see how it's being used if I really want to know. If I can. If I care enough to.
                                      I used to have one, same principle as used the UPS with AVR. The relay clicking is very annoying when input live Voltage varies a lot.
                                      Example of more complicated one (not using auto-transformer) than the one in yours, but same idea.
                                      Lots of newer regulators us TRAIAC instead of relays.
                                      • Topcat
                                        The Boss Stooge
                                        • Oct 2003
                                        • 16959
                                        Sencore PR570 variac & isolation transformer. Bought it new back in the early 90's, never had a single issue with it. Probably not too expensive on ebay.
                                        <--- Badcaps.net Founder
                                        Badcaps.net Services:
                                        Motherboard Repair Services
                                        http://folding.stanford.edu/
                                        Team : 49813
                                        Join in!!
                                        Team Stats
                                        • repair-it
                                          Need advice testing a samsung power supply board with scope
                                          by repair-it
                                          I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                                          07-12-2025, 11:00 AM
                                        • harp
                                          isolation transformer from two 240/12, wiring?
                                          by harp
                                          When is talk about making isolation transformer on poor-man way, always I see schematic 240/12-12/240.
                                          So, I wonder, is this wiring from my attachment it work, bringing some good feature or it is bad idea and why?...
                                          11-25-2022, 05:11 PM
                                        • ohren
                                          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                          by ohren
                                          Hello!
                                          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                          Measured voltages with no load:
                                          After rectifier diodes
                                          12V: 6.17 V
                                          5V: 5.67 V
                                          Secondary transformer pins AC measurement (really don't know if this says anything)
                                          12V: 2-2.5 V
                                          5V: 1.04 V
                                          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                          03-18-2023, 10:33 AM
                                        • mikey5791
                                          Is it possible for transformer substitution?
                                          by mikey5791
                                          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                          My questions are
                                          1. How do i test to see if the transformer is in good working condition?
                                          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                          Hope you guys understand what i was asking. My intention is...
                                          11-03-2022, 02:11 AM
                                        • dennis_elx33
                                          3PHASE STEP-DOWN Transformer in Check
                                          by dennis_elx33
                                          Hello All,
                                          i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                          Problem statement: Power tripped Off
                                          Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                          Action Done:
                                          1) Replaced the faulty parts with good spare.
                                          2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                          12-02-2024, 06:52 AM
