Yet another ESR meter!
  • Bob Parker
    Technician
    • Feb 2007
    • 182
    Anatek Corp in the USA has just started selling a variation of the Dick Smith ESR meter kit. It's in a nice professional semi-transparent case which has its own battery compartment, and it's got really eye-catching blue displays. The high-quality test leads are soldered to the board and terminate in 4mm in-line jacks so you can swap between probes and clips.
    If you're in the USA, you should give this kit serious consideration. See it at http://www.anatekcorp.com/blueesr.htm
    It is a good shrubbery. I like the laurels particularly...
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Yet another ESR meter!
    Damn.
    I just bought a MK-II yesterday.
    Mann-Made Global Warming.
    - Dr Seuss
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Nice, is anything different hardware wise or does it just have a nicer PCB, casing and LED?
      • Bob Parker
        Technician
        • Feb 2007
        • 182
        Originally posted by PCBONEZ
        Damn.
        Don't worry - it's functionally identical to the Mk 2 DSE meter but not as compact.
        Hardware-wise, the board's completely different. A few capacitor values have been reduced because they didn't need to be so big, and it's got a lower dropout voltage regulator to squeeze the last bit of energy out of the 9V battery.
        In terms of accuracy, the Mk1 and Mk 2 DSE meters and now the Anatek one are all the same. Don't feel you're missing out if you've got an older one!
        • davmax
          • Dec 2005
          • 899
          The new Kit looks great and the minor design tweaks just improve it's utility even more.
          Gigabyte EP45-DS3L Ultra Reliable (Power saver)
          Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
          160Gb WD SATAII Server grade
          Nvidia 8500GT 256Mb
          160Gb WD eSATAII Server grade for backup.
          Samsung 18x DVD writer
          Pioneer 16x DVD writer + 6x Dual layer
          33 way card reader
          Windows XP Pro SP3
          Thermaltake Matrix case with 430W Silent Power
          17" Benq FP737s LCD monitor
          HP Officejet Pro K5300 with refillable tanks
          • Spacedye69
            • Nov 2005
            • 698
            • US
            Someone build a ringing tester kit!!! I dont want to have to try my hand at circuit board etching.
            • starfury1
              • May 2006
              • 1256
              really nice....I like it.
              Soldering the test leads isn't such a bad idea I think
              (as has been discussed)
              Quick sqizz at the construction manual (i'll read it later) looks like its got all you need info wise to build
              Silk screened overlay should go a long way here in helping put the components in the right place
              Didn't notice a full "How it works"...
              (refs given to SC and Bobs site anyway if you really need to know)
              or an overlay against PCB pattern
              (SS overlay negates that really anyway)
              Wish them good luck with sales and thanks Bob (good luck too) for the update on the meter.
              Now, do I really need a blue one
              Cheers
              You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
              • Bob Parker
                Technician
                • Feb 2007
                • 182
                If you've already got an ESR meter, you don't need a blue one!
                But if you don't have an ESR meter and you have to fix stuff which has problems with failing electrolytic caps, the blue Anatek meter would be worth seriously considering.
                This time I've attached a photo I took of the evaluation unit I built (I think!). The displays don't look quite that bright in real life ... the lighting and camera made them look like that.
                Regarding the ringer tester, is that for phones, doorbells, flyback transformers or something else?
                • Bob Parker
                  Technician
                  • Feb 2007
                  • 182
                  I suspected that the photo didn't attach to my post before this one. I really hope it attached OK this time.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    But BLUE is so purdy!
                    I actually have a schematic for a 3 digit version I haven't had time to build and try it out.
                    - Can't share though. I don't own the copyright.
                    It's not based on Bob's design. There is no firmware chip and like 5x(+) more parts.
                    From what I can tell some one tried to market it as a kit 6,7,8? years ago and it 'died'.
                    - Didn't market it very well?
                    - Didn't work?
                    - Maybe Bob's was just easier and cheaper and no one thought they'd ever need 3 digits.
                    That project is on the back burner. Too many others are more urgent.
                    - Dr Seuss
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      I supposed before I build it I could just get blue LED's instead of red..
                      - Dr Seuss
                      • Spacedye69
                        • Nov 2005
                        • 698
                        • US
                        Sorry, LOPT tester!
                        I was going to change the case on my MKII(I don't like unscrewing the case to change the batteries, screws are getting worn), but it still won't be that pretty blue!!!!
                        • Bob Parker
                          Technician
                          • Feb 2007
                          • 182
                          If you went for blue displays, you wouldn't see them through the red plastic window. You could probably find a bit of blue acrylic material for the window without too many problems.
                          • Bob Parker
                            Technician
                            • Feb 2007
                            • 182
                            Originally posted by Spacedye69
                            Sorry, LOPT tester!
                            There are still a few of the Dick Smith LOPT/FBT tester kits around. I've got about 3 I bought just before they became unavailable. Problem is it's not real cheap to post them outside down-under Australia.
                            • zeus
                              • Dec 2007
                              • 16
                              I love my little Blu; it's measuring a 0.27ohm 1watt WW resistor, not bad for a 28 year old resistor.
                              There was one very small problem with the kit. In order to use those 4 pin headers to install the
                              two LED displays you had to solder the pin headers to the board and then solder the displays to
                              the pin headers, not an easy task. Instead, I just soldered the displays to the board, much, much
                              quicker.
                              This ESR meter kit is well worth the $79.99
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Congrats!
                                I'm about completed with my 1st MK-2.
                                PCB built/tested/working fine but final assembly delayed for some mods and to rectify some el-cheapo issues I don't like with the battery holder provided.
                                No reflection on the meter itself.
                                It's the kit manufacturer's misgivings that are pissin' me off.
                                I want to do the mod in the assembly manual that lets me burn the batteries down to 5.7v before they need changed. (Or rather the battery low-light activates).
                                If they've known that since 1998 like the manual says then why didn't they just include the needed transistor and resistor in the kit. Transistor isn't a problem but I haven't found 27k 1% resistors in qty less than 1000 pieces.
                                [I will set it at 6v for a margin for error. Not the 5.7v suggested.
                                They (kit maker) cheaped-out on the battery holder by providing a 4-cell through hole PCB mount that you are supposed to bend the PCB leads around and and solder to the terminals on a 2-cell solder terminal holder. Now that's annoying. They are just being cheap/stupid/lazy by using the quickest available part from their own cataloge.
                                They should have sourced holders that are appropriate for the kit.
                                It would not have taken a great deal of reworking to allow the use of 9v batteries. (AAA's leak acid a lot more often than 9v and you have to use 6 AAA's with this particular kit.)
                                A different arrangement for the display window and shorter stand-offs would add enough clearance.
                                Add an insulator (sheet of plastic) to the solder side of the PCB with some 2 or 3mm thick washers as stand-offs (from the solder) and some longer screws to prevent the batt from grounding the PCB and it's good to go.
                                The plastic cover that is discarded from the box-kit provided could easily serve as this insulator panel with some trimming and 4 holes drilled.
                                Could even hard mount a 9v holder to the back side of the PCB so the batt isn't dangling from wires when it's time to change it. The batt, face-plate, and ckt board would come out of the case as one unit and dropping the battery isn't going to yank wires out. [I may do this mod later on.]
                                I thought the pin mounts for terminal and switch wires was rather stupid. Extra work. Not necessary. The wires can go straight the the PCB and save space right there by all the terminals.
                                I used slightly larger gauge wire than came in the kit and made them a little longer so I can work on the PCB without the front panel getting in the way or having to detach it.
                                I'm considering a mod to use rechargeable batteries where I can just plug it in to charge them up. That would also allow me to use AC power when I'm in the middle of something, the batteries are dead, and I don't have spares handy.
                                Question for the meter Gurus.
                                The manual suggests putting an inverse parallel pair of 1N5404 or similar high-power diodes across the test lead sockets to prevent damage if I forget to discharge a cap.
                                Aren't diodes in parallel with the CUT going to screw up the meter's accuracy?
                                - Dr Seuss
                                • kc8adu
                                  • Nov 2003
                                  • 8832
                                  • U.S.A!
                                  i put 6 aa nimh in mine with a jack to charge them.
                                  and the output of the meter will not forward bias the diodes as it is too low.
                                  however this presents a problem when testing batteries.yes i can spot a sick nimh cell easily with this meter.
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    Thanks kc8adu.
                                    That's what I figured for the diodes but I thought I'd ask first to be sure.
                                    That's about what I have in mind for a charger too but I haven't decided between NiMH and Li. Is all pending working out what I'm going to use for a holder and what size batteries I end up needing. They have 9 Volt Lithium Polymer batteries now with 500mAh (and more) capacity but the true full charge volts is only 8.4v. Still, with that many mAh they might last longer.
                                    Maybe a normally closed double throw momentary push button to open the diodes path for checking NiMH batts? - Momentary so a brain fart doesn't leave the switch in the wrong position measuring caps. - Or build the Diodes into the leads with some heat shrink and a jumper and have a different set of leads for batteries.
                                    - Dr Seuss
                                    • willawake
                                      Super Modulator
                                      • Nov 2003
                                      • 8457
                                      • Greece
                                      more info
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        Yeah me too:
                                        More info on checking NiHM with an ESR meter please.
                                        - Dr Seuss
                                        • chth96
                                          Is it possible to test small ceramic disc capacitor with analogue meter?
                                          by chth96
                                          I read EBOOK of Testing Electronic Component and found that
                                          "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                          Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                          It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                          Is it really possible to test small ceramic disc capacitor with analogue...
                                          03-09-2024, 10:03 PM
                                          Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                          by sam_sam_sam
                                          I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                          I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                          12-31-2023, 06:04 AM
                                        • jorpec
                                          Changing the scale of an analog meter
                                          by jorpec
                                          Hi
                                          I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                          I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                          Thnaks
                                          01-23-2023, 10:37 AM
                                          How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                          by sam_sam_sam
                                          About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                          Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                          Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                          12-14-2023, 07:45 PM
                                        • Stephan Mathers
                                          EDMI ATLAS MK10 Electronic Meter Discussion
                                          by Stephan Mathers
                                          Greetings, new guy here but always interested in the crazy universe of modding
                                          We just finished construction of around 25 vacation houses, all inside the same private area.
                                          Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
                                          The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
                                          Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
                                          05-20-2025, 09:09 AM
