This is why you don't buy cheap multimeters.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    As you know i own a number of meters for different purposes. The Uni-T UT60E and UT70A do the heavy lifting, but i often need a couple extra basic meters. One of them is a DT838 i bought this summer IIRC. I mainly bought it for the temperature and buzzer, as i already had two 830Bs.
    Well, since a couple weeks ago it started working erratically on resistance. More specifically, on the low ranges it reads in the hundreds of ohms even if there's a short, then it slowly counts down to the real value...
    I thought it was the battery so i replaced it today. Surprise surprise - exact same behavior. To make matters worse, the temperature range is busted too. It still measures voltages fine, but that's what i didn't need it for. On the other hand my two 830Bs still work great even though i've had them for years... but those two are both brand name (one Uni-T, one Mastech), while the 838 was the HongKongFlyApart, LLC version. But hey, it's only five bucks.
    A working TV? How boring!
  • KeriJane
    Mac Enthusiast
    • Sep 2008
    • 681
    Re: This is why you don't buy cheap multimeters.
    Did you open it up and check for BAD CAPS?
    Sounds like a great opportunity expand your skills into multimeter repair or at least to expand your parts collection....
    The More You Learn The Less You Know!
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      Yes i did open it up, it only has a few SMD ceramic caps and a MKT 100 nF and that's it. They test good. Sounds more like a resistor that has shifted value, and they can't be measured in-circuit. For a $5 meter it isn't worth my time. I'll buy a $20 meter from Uni-T to replace it, as i currently have an extra temperature probe which i can't use on anything. To make matters worse the ICL7106 is in epoxied blob form, and it doesn't even respect the standard pinout. Too many cut corners to bother with it.
      • b700029
        Banned
        • Sep 2010
        • 640
        ICL7106 may be damaged by static electricity, transplant procedure is possible:
        http://www.crystalradio.cn/bbs/thread-109673-1-3.html
        http://www.crystalradio.cn/bbs/attac...UB9PB5bP14.jpg
          master hoarder
          • May 2008
          • 12175
          I have a cheap HongKongFlyApart, LLC 830B variant (that's actually my only multimeter, lol), and when I short-circuit the probes on the 2000 Ohm setting, it shows 3 Ohms . New batteries will bring it down to 1 or 2 Ohms, but it's not worth it. So when I get 3 Ohms in a circuit on that setting, I know it's a short-circuit .
          On the 200 Ohm scale, it shows 0.9 to 2.7 Ohms, depending on how it feels. Most of the time, it's over 2 Ohms.
          Continuity/diode test shows pretty much the same numbers as the 2000 Ohm scale when the numbers get low.
          That multimeter has served me well for many repairs, though, so I will dismiss its flaws for now .
          • SparkeyJim
            • Oct 2011
            Hello. My name is Jim and I go by the user name SparkeyJim. I am new to the forum. I am currently working on LCD and plasma televisions and would like some input. What cap meter or LCR meters would you recommend for smd and mini alum caps on these sets.
            Many thanks to those that respond. I will respond in kind.
            Thank you, Jim G
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              i noticed the accuracy slides on the cheap hf meters just before the low batt indicator comes on.they are still fine for the shop help kid,ect.he blows it up i toss it and pull another from the backstock.critical stuff i use the old beckman manual range unit that we got rechargeable 9v's for as it does not even have auto off.or my fluke 77.
              • lti
                • May 2011
                • 2553
                My Harbor Freight $3 multimeter is more accurate in the resistance ranges than the old Danameter I normally use. That Danameter thinks a 220Ω resistor that measures at exactly 220 ohms on every other multimeter is actually only 170 ohms.
                Also, the battery that came with the Harbor Freight meter sucked. The battery drained itself with no load on it at all. I can connect it to a 15V power supply and it will draw almost no current. It can not even power an LED placed directly across its terminals.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  Someone had way too much time on their hands.
                  This is normal for the 830B and part of it is due to the crummy probes it comes with. With good probes it should read 0.6 to 0.9 ohms when shorted. I like my UT70A. It shows 0.0.
                  • Krankshaft
                    • Jan 2007
                    • 2328
                    Geez the least they could do was use insulated wire instead of what I hope is enameled wrapping wire.
                    • c_hegge
                      • Sep 2009
                      • 5219
                      The TaiwanBreakDownComponents company version I used to have did 5 ohms. It only lasted about a year before the pins at the end of the probes broke off.
                        master hoarder
                        • May 2008
                        • 12175
                        Oh yeah, the probes on mine broke as well long time ago. Basically the wires pulled out of the probes' handles. Since these are the cheap type of probes that have the tips heat-pressed into the plastic, there really was no easy way of opening them and getting them fixed - or so you'd think. Of course, me being the cheap ass I am, I did fix them; just cut the plastic on the handles just a few mm from the tip, run the wire through the handle again, solder it back on the tip, and then finally hot glue everything back together.
                        Almost CAT IV compliant .
                        • larrymoencurly
                          • Oct 2004
                          • 960
                          I switched to needle-sharp stainless steel probes because chrome plated brass probes kept telling me that 120VAC outlets had 0V, even though I thought I had scraped the probes hard enough to supposedly clean the oxide and make good contact.
                          BTW the test probes sold by the company behind www.TestLeads.com may not look like they're stainless any more because they're now chrome plated stainless.
                            My DT830B blew up, rather spectacular. Hole in the plastic case, charred PCB, not quite sure what went up!
                            Still, I keep one or two cheap meters, for testing low voltage circuits. Wouldn't even go near it with anything higher than 50V, the wire feels so flimsy and the probes are crap.
                            I have a BK 2709B but that stays mostly at home, not always around me when repairing things.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              Originally posted by tom66
                              My DT830B blew up,
                              Mine thankfully, in retrospect, didn't work.
                              https://www.badcaps.net/forum/showpo...4&postcount=25
                              I have totally changed my mind since that post and now have an used Fluke 75, Fluke 12, Amprobe AM60, and gave away an Amprobe 15XP.
                              I almost had 2 RMS multimeters for less than $10, but someone sniped me at the end when I wasn't home.
                              PS. I saw your thread on eevblog regarding this subject matter.
                              --- begin sig file ---
                              --- end sig file ---
                                I was fairly impressed with one of my Mastech cheapies I owned for about two years. It even survived being set on ohms on 230V; the display readout was nonsense but it wasn't damaged. Unfortunately, when changing it's battery, I shorted an LDO and fried the main ASIC . Ah well, it was only £20...
                                • Krankshaft
                                  • Jan 2007
                                  • 2328
                                  Ahh the hFE function reserved for only the bottom of the barrel models .
                                  It's such a dead giveaway of a cheapie I don't know why they don't just ditch that useless function.
                                  I'll admit my first meter was a tiny one like that (no hFE though ) branded by Radioshack but the probes were integral with the meter and the whole thing had an integral case.
                                  Eventually from the probes being crammed into the case they too broke where they entered the probe handles. It used an annoying proprietary battery too.
                                  Can't recall the battery designation code it's the type where if you cut it open you'll get a bunch of LR44 button batteries in series from it.
                                  I'm all for using these on DC and unpowered circuits if you can't afford a decent and safe one. But I want a good meter in my hand I can trust. With HRC fuses, input protection, and a thick case with blast shields inside in case something goes wrong when I'm measuring live AC.
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    ...while the 838 was the HongKongFlyApart, LLC version.
                                    sigpic
                                    (Insert witty quote here)
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      Did it look like this? I got this one free, but not working.
                                      The fuse was blown, but changing the fuse did nothing. I found Q1 shorted in circuit and desoldered it only to find the IC good.
                                      I wouldn't mind fixing it just for educational purposes and using it to measure nimh batteries.
                                      Even though this was made in year 2000 with through hole components, I think it is much higher quality than the cheap 830B that I originally got off ebay. The soldering quality seems better and it is one solid pcb (not the patch job on the input jacks).
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        What were you trying to measure? The explosion does look pretty spectacular.
                                        Reason I ask is because I have a 830D (a variant of the 830B). I regularly use it to measure high voltages on the primary of PSUs and whatnot and never had anything bad happen. A few times I tried to measure DC on the AC mains - again, no explosions. Perhaps I've been lucky?
                                        In terms of quality, mine IS pretty much a HongKongFlyAppart LLC production.
                                        • asdas09
                                          Temperature to remove chips from motherboard
                                          by asdas09
                                          What temperature with the heat gun should be use to remove large and small chips from the laptop and mobilephones motherboard? My problem is that the chips not easily remove from the motherboard, example 380°C degrees. I don't know if there is a difference with the devices that the temperature is not stable with them even it shows the right temperature, what should it be? I don't know if I should use higher temperature but the risk of destroying other components?
                                          I have device Sugon 202. I'm used also normal flux and rosin flux.
                                          09-12-2023, 12:44 AM
                                        • Dreigas
                                          ISL95880HRTZ desoldering temperature
                                          by Dreigas
                                          I bought from China ISL95880HRTZ (3+1+1 Voltage Regulator with Expanded ICCMAX Register Range Supporting IMVP8 CFL/CNL CPUs) chip, which I think is not the original one, but anyway, I tried to resoldering it with a 380C hot air station. Seems soldering is pretty good, but the laptop doesn't work (it worked before, but still had some problems with power delivery).
                                          Is there any big chance, that they sent me two fake ISL95880HRTZ chips or did I just use too big temperature for desoldering? I will try with another chip, but I can't find any info about the maximum desoldering...
                                          09-13-2024, 10:59 PM
                                        • Rayblaster
                                          HP RP7 RP7800 from 2012/2013 worst fault - has "character"
                                          by Rayblaster
                                          Hello friends, I've got a nice toy to play with - it is an HP RP7800 All-in-one POS system. I got it for free and it has one problem - it turns on very rarely, and just for a few seconds. After that it dies and doesn't come on if I don't leave it unplugged for at least 2 hours. I've repaired motherboards before, this is not my first one, but problem with these types of faults is that everything you check on the board will usually be fine. This is the case for me here.
                                          I dissassembled it completely, and got my hands on the motherboard. Model No. is PIQ67H/Higgins 11047-I 48.3GD02.011....
                                          12-30-2024, 06:28 PM
                                        • jm1234
                                          9V relay temperature 40C
                                          by jm1234
                                          Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                          I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                          05-09-2024, 03:03 AM
                                        • Windows8RTMUser
                                          Repair knowledge for -55c CPU temperature on AMD Ryzen CPUs in bios, the AMD Sideband temperature sensor interface (SB-TSI)
                                          by Windows8RTMUser
                                          Recently I came across an x570 Aorus Elite where the temperature in bios was reporting -55c, i had checked the CPU_TEMP line connected to the IT8688
                                          In my particular case, the SIC line going to the X570 chipset (PM_SIC) was shorted to ground, so far disconnecting the 0 ohm resistors connecting APU_SID and APU_SIC to the chipset has fixed my -55c issue, it seems like -55c is the fallback reading for CPU_TEMP which is just pulled up to VREF on most gigabyte motherboards
                                          I wanted to post this as even the ever-reliable vlab forum was stumped on this issue
                                          tags:...
                                          07-28-2025, 07:26 PM
