What to test with???
  • stretch0069
    Screwed Up Super Moderator
    • Oct 2003
    • 2658
    • oooo ess aaaaaaaaa
    Heya Topcat.......
    I'm going to do a little test to see if there is a difference between 1500µf and 2200µf caps. What program would you recommend to use for testing the mobo for basic OCability? How long to run it??
    "Its all about the boom....."
    Guns kill people like spoons made Rosie O'Donnell fat.
    We now return you to your regularly scheduled drinking.
    "Fear accompanies the possibility of death.....calm shepherds its certainty"
    Originally posted by Topcat
    AWD is just training wheels for RWD.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    I use SiSoft Sandra Professional 2004. If you need it, let me know! Their burn-in utility is brutal!! that will tell you if there;s gonna be any problems!! On a board I recap, I usually let it run for 72 hours, although, if there are going to be any problems, the system will usually hurl within the first hour....
    I definitely want the results of your experiment, I tried it on a couple, but didn't do any extensive overclocking experiments!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • stretch0069
      • Oct 2003
      • 2658
      Yeah....I have SiSoft Sandra 2003 installed right now. Is the burn in test part of the registered (paid for) part of the apps?
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        i would look at vcore with a scope while sandra is flogging the system.
        going up in value usually has positive results.less ripple/noise.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          The burn-in is only included in the 'Professional' version (the paid for one). I've got Pro 2004, and it's really nice!! Zipped up it is about 7mb, if u need it, i'll post it somewhere for you.
          Team : 49813
          Join in!!
          Team Stats
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            i can use it.
            had 2003 but i busted the business card cd i have in my wallet.
            btw i have the latest troubleshooter and spin.
            • Mechtaz
              • Jun 2004
              • 16
              :?: I am recapping 2 boards soon, do you still recommend SiSoft Sandra Professional 2004???
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                definately.
                i also use knoppix .
                since it is a cd based distro and needs no hd it is great for beating up a board.
                it is very memory and cpu intensive.
                • Mechtaz
                  • Jun 2004
                  • 16
                  Program??
                  :| where can I find knoppix?
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    www.linuxiso.org
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16958
                      Good find! :P I always did it the hard way with HDD's and installs.... I'm posting this message from KNOPPIX now... Only took 2 hours to DL it...
                      Team : 49813
                      Join in!!
                      Team Stats
                      • noorman
                        • Jul 2004
                        • 10
                        original KNOPPIX link here
                        http://www.knoppix.org/
                        just click on the UK/US flag to change to the English language
                        • Kako
                          • Jul 2004
                          • 18
                          Re: What to test with???
                          A favorite of mine is Super PI:
                          http://www.pcekspert.com/download/get-32.html
                          Select 32million, and come back after lunch. Prime95 is also a good choice, but it has a habit of being over sensitive and crashing when their seems to be no stability problems, or the opposite, it'll run even on an unstable comp.
                          http://mersenne.org/gimps/p95v238.zip
                          • chth96
                            How Can I test PWM DM0365R?
                            by chth96
                            Hello
                            I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                            So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                            I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                            I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                            06-18-2025, 04:14 PM
                          • bauto601
                            KDM 480W PSU upgrade succes! (opinions?)
                            by bauto601
                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                            A "nice" YoungYear unit? - Badcaps
                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                            12-26-2023, 03:05 PM
                          • khelane
                            test active pfc power with lamp test
                            by khelane
                            Hello
                            I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                            Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                            Is there a way...
                            06-03-2025, 01:00 AM
                          • chronic519
                            Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                            by chronic519
                            Hello.
                            GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                            Found issue with a RAM block
                            Replaced, green lines gone.
                            Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                            Used a good card to test and same results low errors 32+.
                            I am just search for some form of command to do a full test on the GPU.
                            I just ran the mats command with my good GPU and passed after roughly 40 min.
                            The repaired one, ran...
                            05-20-2025, 07:56 PM
                          • alltvrepairs
                            Lg TCon test pins for screen test
                            by alltvrepairs
                            i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                            Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                            Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                            Appreciate your help....
                            06-13-2025, 06:33 AM
