E701i-A3 issue(s)
  • vbrad511
    • Feb 2015
    • 70
    E701i-A3 issue(s)
    This belongs to a coworker that thought I might be able to do it some good. He bought it new, and a while back they had a lightning strike that took out some of their electronics. Killed his router, his gaming system, and the HDMI ports on this tv. Insurance replaced everything, and they still used the tv, but recently things changed. When powered on the backlights come on for a few seconds, then start going off and on. There's no menu viewable, and the remote doesn't seem to change or alter anything. I'm no tech, but folks here have helped me through repairs on a few other sets in the last few years. Was hoping to get some insight on this one.
    Thoughts?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8324
    Re: E701i-A3 issue(s)
    Can we see some high resolution, straight shot pictures of all your boards and one of the back side of the TV? What kind of troubleshooting tools do you have available?
    The history of this TV is a bit vague, can you explain that a bit better? Was the TV fixed with a new main board after the lightning strike or did they just keep running the TV without fixing it?
    Question is: Is the main board working and you don't see anything because the Tcon is bad
    or : I there a main board problem and maybe even an LED issue?
    • vbrad511
      • Feb 2015
      • 70
      I just took a few pics, not sure they'll show what you're needing. I've got a few multimeters, that's about it. I've changed caps on a few tv's, and a handful of boards, but that's the extent of my "experience.
      The lightning strike must've hit the coax line for the internet. It fried his modem/router, his gaming system, and the HDMI ports on the tv wouldn't work after that. The gaming system was connected with an HDMI cable. Nothing has been done to it, other than them still occasionally watching tv on it.
      The screen , amidst the flickering backlights, shows dark. Maybe a blue/gray, slightly illuminated screen, but no picture, no menu, no static. The tv turns on as soon as it's plugged in, and neither the remote or the buttons on the tv make any changes, and will not turn the tv off.
      • budwich
        • Jul 2015
        • 3097
        A lot of posters here don't have much more (ie. meter) or even nothing. :-)
        The fact that the hdmi is no longer working is likely inidcation that the main board is in trouble since the inputs travel thru that board.
        There are usually printed labels on the boards that indicate some of the voltages that need to be present for the system to work to some degree. You could ttry verifying that those exist. A lightning strike in / near a house in usually not a good thing for most electronics.
        You are saying they continued to use the set via some other non-hmdi inputs until this latest failure. That was probably just "lucky" if you think lightning strikes are a sign of luck. :-).
        You can try disconnecting the tcon to panel cables, one at a time to see if anything changes.. JUST in case some other failure more related to the panel happened. IF nothing happens, you should probably focus on the main card.
        As another suggestion, check the fuse on the tcon card.
        • vbrad511
          • Feb 2015
          • 70
          I've pulled the tcon cables, together, then one at a time. No change. I'm "watching" a main board on Ebay from a broken panel tv. We'll give it a go. Thank you.
          I will check voltages too.
          • DXseekerMO
            • Feb 2018
            • 1119
            • US
            Does this model have an HDMI receiver IC like LG's?
            They call me......."threadkiller"
            • budwich
              • Jul 2015
              • 3097
              hmmm.... "no change"... there should have been a "white screen" on the half that had the cable disconnected.
              • vbrad511
                • Feb 2015
                • 70
                Nope. Just fired it up again after reading your comment. Backlights continue to flash, that's it. New main board should be here Monday. I'm hoping there isn't some deeper issue.
                • budwich
                  • Jul 2015
                  • 3097
                  hmmmm.... which cables are you referring to? black ones or white ones?
                  • vbrad511
                    • Feb 2015
                    • 70
                    The ones coming out of the tcon, heading to the panel. However, the "new" board got here today. Installed, fired up, got a batch of vertical lines from the left side all the way to the right side, in pattern, and the Vizio "V", off to the right of the screen a bit. Then it all goes off, then back on without the V a few times, then back to a dark screen. I've also realized this is a 60", and not a 70", but the board numbers are the same. I've seen Samsung use the same boards on a few different models, so I'm hoping that's not the issue here.
                    • nomoresonys
                      • 12269
                      • U.S.
                      • budwich
                        • Jul 2015
                        • 3097
                        hmmm... you should note that IF there is a panel problem, on vizio's, this type of fault may / usually cause a tcon failure so throwing another tcon at the set is potentially fruitless. Check your cards to see if the "FET" on the board are not shorted / blown. Lots of threads on these large vizios whereby people replace the blown component and do some other testing to determine whether the panel is at fault. IF you get a "good" card, try first having no cables going to the panel connected, power up the set and check voltages at the tcon along with the "known fet". then only plug in one cable, power up and quickly look to see what happens on the display. IF nothing happens (is no display) is less than a few second, pwoer down and potentially save your card from dying. Do the same test, this time with the other only plugged in. Check the display... if you get a good display, then the other side was likely bad. Read some more thread on this type of failure and see if you can save the set.
                          Which board P/N did you use? The one on the barcode or the white silkscreen printed on the board?
                          • vbrad511
                            • Feb 2015
                            • 70
                            Looks like I'll have to do a little more self-educating to be able to do all this.
                            • vbrad511
                              • Feb 2015
                              • 70
                              I went off the one in white letters printed on the board. The only bar code is on a sticker on the wifi card.
                              Edit, now I'm seeing another scan-able tag. The numbers are different from mine.
                              • nomoresonys
                                • 12269
                                • U.S.
                                Example, notice how it says 242 can be found on a sticker, it's on the sticker right under the MBVZ. https://www.shopjimmy.com/vizio-y838...r-e701i-a3.htm
                                • vbrad511
                                  • Feb 2015
                                  • 70
                                  So it's not just the board number, it's some sort of software ID on the sticker I need to match up?
                                  • nomoresonys
                                    • 12269
                                    • U.S.
                                    The board numbers in white silkscreen are generic board numbers, you want to match up the sticker numbers.
                                    • vbrad511
                                      • Feb 2015
                                      • 70
                                      I've found the correct board (216). The seller of this first, incorrect board has offered to take it back, providing it's undamaged. Is there a chance that me installing and powering up the tv with this "wrong" board have hurt this board?
                                      • nomoresonys
                                        • 12269
                                        • U.S.
                                        Always a chance but I'd say it's small, better chance a bad panel knocks out a good tcon replacement, if the seller has a good reputation, they should treat you fairly, I always check buyer feedback if I'm dealing with ebay.
                                        • Bardou Kari
                                          HP EliteBook 840 G6 – no power after lightning strike
                                          by Bardou Kari
                                          I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
                                          – Charger is OK and 19V is present at the motherboard.
                                          – No charging LED, no fan, no reaction.
                                          – I don’t see any 3.3V or 5V near the coils.
                                          – Battery is unplugged.
                                          – I’m new to board repair but can use a multimeter.
                                          I added a clear photo of the board.
                                          Any idea where to start or what to check next?
                                          Thanks a lot for your help!...
                                          07-01-2025, 10:45 AM
                                        • SluggerB
                                          Panasonic TH-50PX80 killed by lightning strike, help me save her!
                                          by SluggerB
                                          Yes it's a 17 year old Panasonic plasma!
                                          I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
                                          06-04-2025, 07:02 PM
                                        • karthur
                                          Samsung UN60EH6000 wont come on after lightning strike.
                                          by karthur
                                          We had a lightning strike a few days ago really close to my house. My Samsung UN60EH6000 was on when it hit. Afterwards, the TV would not come back on.
                                          I had repaired this TV a few years back by replacing the T-Con board. (The post I had on this is repair is here.)
                                          When I turn on the TV, I don't get any start-up melody. The screen just dimly flickers around the edges.
                                          Here is what I have checked.
                                          On the power supply board, 14pin connector:
                                          1 :12.7 Vdc
                                          3 :12.7
                                          5 :12.7
                                          7 :12.7
                                          9 :0
                                          11 :5.
                                          13 :5....
                                          11-01-2023, 06:18 PM
                                        • double_DD
                                          Why does my ISP router hate my "homemade" power supply??
                                          by double_DD
                                          It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                                          So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                                          For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                                          07-12-2025, 03:09 AM
                                        • MrCreosote
                                          Lightning Strike: 55" TV dead: is display panel OK?
                                          by MrCreosote
                                          THE LIGHTNING:
                                          This was a very close strike, blew a 15 amp breaker for all ceiling lights in home AND could smell ozone for a few minutes after strike.
                                          Very close and probably a very strong EMP.
                                          THE TV:
                                          No standby LED. Some voltage from PSB (not totally dead).
                                          But found a kit of ALL 4 circuit boards for $55.
                                          At first thought, this will fix my TV.
                                          But then lightning has the ability to totally fry semiconductors. Which would include any or all of the PCBs. However, the display is one big semiconductor and given...
                                          08-16-2021, 10:27 PM
