Samsung UN60EH6000 wont come on after lightning strike.
This topic has been answered.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4456
    • Italy - Milan
    #61
    OK, watching the circuit it's a reset chip, but top right pin is strange at around 0v, if you are able to remove this chip without damaging it you can after it power the set and with a scissor or wire perform a reset between the pads of the switch solder place..
    • karthur
      • Nov 2015
      • 150
      Just a follow-up. I replaced the main video board from a different supplier. The TV works again.πŸ˜…πŸ˜…πŸ˜…
      Many thanks everyone for the help on this.
        • 12274
        • U.S.
        #63
        Good job, glad you concentrated on getting another mainboard, SO many times people let a bad replacement board allow them wander off in the wrong direction.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4456
          • Italy - Milan
          #64
          Same end as always.. no technical actions done.. unfortunately for us..
          • Bardou Kari
            HP EliteBook 840 G6 – no power after lightning strike
            by Bardou Kari
            I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
            – Charger is OK and 19V is present at the motherboard.
            – No charging LED, no fan, no reaction.
            – I don’t see any 3.3V or 5V near the coils.
            – Battery is unplugged.
            – I’m new to board repair but can use a multimeter.
            I added a clear photo of the board.
            Any idea where to start or what to check next?
            Thanks a lot for your help!...
            07-01-2025, 10:45 AM
          • SluggerB
            Panasonic TH-50PX80 killed by lightning strike, help me save her!
            by SluggerB
            Yes it's a 17 year old Panasonic plasma!
            I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
            06-04-2025, 07:02 PM
          • MrCreosote
            Lightning Strike: 55" TV dead: is display panel OK?
            by MrCreosote
            THE LIGHTNING:
            This was a very close strike, blew a 15 amp breaker for all ceiling lights in home AND could smell ozone for a few minutes after strike.
            Very close and probably a very strong EMP.
            THE TV:
            No standby LED. Some voltage from PSB (not totally dead).
            But found a kit of ALL 4 circuit boards for $55.
            At first thought, this will fix my TV.
            But then lightning has the ability to totally fry semiconductors. Which would include any or all of the PCBs. However, the display is one big semiconductor and given...
            08-16-2021, 10:27 PM
          • pbig
            advices for repairing Sony Bravia 32EX600 after lightning strike
            by pbig
            hi everyone,
            my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
            On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
            - the 450V/150uF capacitor voltage when plugged is normal at 394V
            - from connector CN6150 (15 poles)
            STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged...
            06-28-2023, 02:43 AM
          • pfl
            ElectroVoice ETX-18SP (powered Subwoofer) damaged after lightning strike
            by pfl
            Hello Everyone.
            This powerful amplified subwoofer doesn't make any sound after lightning striked near the house were it was plugged in.
            It consists in :
            • a power board were the full H bridge class D amplifier and main power rails are located
            • a preamp board (ref. F.01U.299.771) receiving 2 symetrical inputs(IN1, IN2), a digital chain (A-D converter -> Digital Signal Processor -> D-A converter) and a micro controler in charge (at least) of the human interface (lcd display and 1 rotating button)
            Power rails are ok.
            human interface is working fine
            Input levels are...
            01-23-2024, 10:21 AM
