Advice on decent GP Electrolytic sought..
  • Zeroexpo
    • Jun 2014
    • 14
    Hi Guys,
    I'm about to buy a PLL Transmitter kit, but the kit comes minus various components including Electrolytic Capacitors.
    I've done some reading around, and I'm led to believe that Rubycon, Panasonic, Nichicon, and a couple of others are the best brands - but there are that many different part #s, type codes, and impedance values that things have got a little muddy.
    Here is an image of the PLL circuit that the Capacitors are to be used in, and I guess what I'm asking is; What's a decent long life general purpose Capacitor for the job?
    As previously said, I can get hold of Rubycon, Panasonic, and Nichicon, but I'm confused as to which model of these is the best to buy.
    The circuit works off 12-15VDC by the way.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Advice on decent GP Electrolytic sought..
    A consideration may be what physical size you need, but I would just go for
    panasonic FM or FR ( usually have longer life)
    cpc.co.uk have post free offer on all orders but have some minimum orders
    of 5 . probably safer not to buy off ebay - many fakes about.
    • Zeroexpo
      • Jun 2014
      • 14
      Thanks, Selldoor.
      I was considering using RS or Farnell anyway, and that way the components would be legit'.
      I'm open to other suggestions, but if there are no other replies I'll go for ones you suggest.
      • linuxguru
        • Apr 2005
        • 1564
        Rubycon ZL, ZLG, ZLH, ZLJ, etc.
        Nichicon PM, PL, PS, PJ, PW, etc.
        Elna RJH, RJJ
        Nippon Chemicon LXV, LXY, LXZ, KY, KZE
          • 31052
          none of the ones listed so-far are "general purpose", they are all low-impedance.
          for general replacements,
          rubycon YXA
          • Clutchbox
            Cap Clutcher
            • Sep 2011
            • 41
            • The Netherlands
            rubycon YXA
            And with Panasonic it is 'NHG' or 'FC' for GP-usage. Those are the one's with the stable non-aqueous Electrolyte formula's.
            Not 'FM' or 'FR', those are better for longlife 'high frequency' low ESR usage.
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              rubycon YXA
              Maybe , but I believe production of that series was stopped in 2011
              The panasonic FM FR are not particularly low ie not extra low and are
              usually listed as general purpose on digikey and mouser plus the FRs have
              5000 lifetime.(at least some of them do)
              • lti
                • May 2011
                • 2548
                These are the series I know of that are not low ESR:
                Nichicon: VR (85°C), VZ (105°C)
                Panasonic: M (85°C), NHG (105°C), EB (105°C, long life, low ripple current)
                I think Nichicon has some more series. I don't know the series names for the other manufacturers.
                • mariushm
                  • May 2011
                  • 3799
                  Rubycon :
                  Nichicon :
                  http://www.nichicon.co.jp/english/pr...ini/pict_f.htm
                  United/Nippon Chemi Con :
                  (scroll down a few pages, have tables and charts inside)
                  Panasonic : http://www.panasonic.com/industrial/...BA0000_AM.html (page may load slow, be patient)
                  Above you have charts with the series and the recommended usage (well, all except panasonic which is basically a list of what they have now)
                  Try to avoid very low esr, extra low impedance etc etc, some "low impedance" may be good enough for your needs.
                  See Standard, Standard, Miniature , High Reliability etc etc
                  PS. Don't exclude surface mount electrolytic capacitors, if you can't find regular electrolytics you can bend the tabs and remove the bottom brown support easily.. the only issue may be that the tabs are not perfectly round to fit inside holes in pcbs:
                  • lexwalker
                    • Feb 2011
                    • 307
                    • Malaysia
                    Very much depends where the capacitor is going to used. Usually for supply rails and decoupling purposes, ANY capacitor will do even low ESR ones. If the purpose is for filtering in a switching section then you may need to check the original capacitor specifications first to find a similar replacement.
                    Generally I would prefer long life capacitors, and most of these are low ESR types like Nichicon HE series, Nichicon PW series, Panasonic FR series, Panasonic FM series, Rubycon ZLH series, Rubycon ZLJ series, Nippon Chemicon KZE, etc. Most of my current stock are these, good for all purposes...
                    As for non-low ESR types, there are plenty to choose from though I would usually prefer those with at least 105C or higher temperature operation, and with good ripple current handling specifications (and preferably long life also!). Excellent examples would be Panasonic ED series and Panasonic EE series...
                    • c_hegge
                      • Sep 2009
                      • 5219
                      I often use Panny NHG when I don't need Low ESR parts.
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        http://i.stack.imgur.com/jKurk.jpg
                        I know it's late to reply to this thread, but just in case anyone reads this...
                        No, don't unbend the leads on SMD capacitors. Once you do, they become very weak and easy to snap off. Also, more often than not, the leads won't fit in through-hole boards.
                        If you really must use an SMD capacitor, then solder new leads (a piece of staple works well, among other things) to the existing leads of the SMD capacitor without unbending them. I've done this several times now, and the joints are secure.
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          fc is the lowest grade of cap i stock.they do fine for gp.
                          as for those smd caps i would skip those.much shorter life.
                          • lexwalker
                            • Feb 2011
                            • 307
                            • Malaysia
                            Panasonic FC and FK series would be the equivalent to the usual crappy CapXon GL and KF series (seen boatloads of them going bad). Well, nowadays for Panasonic I stopped buying FC and FK series for standby/stock. Nowadays for Panasonic, I would go for FM and FR series. In the past, very often I got caught out with ultra low impedance capacitors such as Ltec LXY, Samwha WB, Samyoung NXB, Samxon GK, Su'scon SG, Su'scon MG, etc. Even the widely used Elite EJ series is actually equivalent to Nichicon HE series (which is higher than Panasonic FC series). Thus Nichicon HE series would be the "lowest grade" I would buy nowadays. For general purpose capacitors, I tend to go for Nichicon HE or PW series...
                            • RetroComputingGrotto
                              Opinions/Advice on Do/Should I replace ALL Electrolytic Capacitors on old equipment?
                              by RetroComputingGrotto
                              I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
                              As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
                              What is your advice/opinion on whether or not on old(er)...
                              04-03-2024, 08:30 AM
                            • Andre Gilbert
                              by Andre Gilbert
                              Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                              Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                              11-20-2024, 08:52 PM
                            • beogeek
                              Need replacement advice for surface mount electrolytic capacitor
                              by beogeek
                              I have a faulty monitor, the surface mount electrolytic capacitor 33uF 100V needs to be replaced, now I can't seem to source them locally, so my question is can I replace it with a through-hole electrolytic capacitor of the same value? Or has someone got a better suggestion?
                              Cheerio...
                              03-17-2022, 01:43 PM
                            • AquaMan Ua
                              Problem with PANASONIC CF53 laptop after changing BIOS settings
                              by AquaMan Ua
                              Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                              05-17-2025, 09:40 AM
                            • proxneo
                              Recapping Sony ICF-SW55 - verifying cap values
                              by proxneo
                              Dear reader
                              I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                              At the moment, I have selected replacements based on the following list of values:
                              3 x 470uF 10VDC
                              3 x 4.7uF 35VDC
                              4 x 47uF 50VDC
                              8 x 22uF 6.3 VDC
                              1 x 220uF 6.3VDC
                              5 x 100uF 6.3VDC
                              Which...
                              06-21-2023, 12:38 AM
