vizio amber light E321VL
  • richpart
    • May 2012
    • 42
    Re: vizio amber light E321VL
    These eeproms are not corrupting themselves. It's happening due to data stream loss.
    Believe what you want to believe but my boards, repaired as described are holding up perfectly and it's not by chance.
    You can lead the horse to the water but, you can't make him drink!
    • miguelon69
      • May 2012
      • 10
      • usa
      #62
      This question is to rich part
      Did you reprogrammed the eprom?
      Or only resolder the board?
      Thanks in advance
      • studle65
        • May 2012
        • 2
        • U.S.A.
        #63
        Is it possible that the mx chip is defective causing the currupt eeprom ? I have noticed that most of these baords having this problem have the mx chip AmTran also used a winbond chip on location u18 does any one know if they are having the corrupt eeprom problem ? My main question would be whats causing the corrupt eeprom as a hobbiest or reseller I can spend a couple hours resoldering but as a repairshop is it cost effective unless your rates are less than $35 hour because both boards (power supply&main) can be purchased as a kit for $69.95 with free shipping over the internet. Thankyou to Richparts,Miguelon69 and everyone that contibuted to this thread as I am only a hobbiest so my knowlege is limited
        • bigdozer
          • Jan 2011
          • 46
          Has anyone found a service manual for these models yet?
          • masessum
            • May 2012
            • 8
            Hello ppl...just joined the forum after reading this thread, just fixed an E421VO with the same problem as the 32 and 37 inch models. I used a heat gun and slowly raised the temp of U48 which looks like a ram chip, with the pins underneath the ic...this is where the solder paste and ir reflow equipment is a must, as you cannot access the pins with standard equipment...if you get the ic hot enough (not too hot!) the ic will reflow itself. So far it works, but will time test it before I reassemble.
            • miguelon69
              • May 2012
              • 10
              • usa
              #66
              Hello everybody , I had 4 of this vizio with amber light and no power after pressing power button.
              I had one board good so i swap the eprom and found that eprom was causing this problem , I order 10 blank eeprom to experiment also an eeprom programmer and read good eeprom save the info and burn (write info to new eprom)
              AND now i am happy to say that all four board are working perfect.
              I checked the regulators for crack solders and re-solder the points where something look suspicious and everything is good now.
              I am happy to get this vizio that gave me a headache but finally they working
              By the way I have a TV repair shop in Grand prairie TX.
              if any body need help let me know ....
              My Name is
              Miguel Garcia I will be glad to help
              web site is : itvrepair.com
              • searley2
                • Jun 2012
                • 1
                Where can the emprom and the eprom reader be purchased for the VIZIO Mx
                • NorCal715
                  • Jun 2012
                  • 1
                  I am a Tech and have replaced many of these boards under Vizio Warranty and all of the new boards have a sticker that says "u18 update" if that helps anyone out. Also just for info, LG (lucky Goldstar) the new 42 and 47 LV4400 series have the same Amtran boards and as well are having eeprom failures and LG will sell you just the new eeprom instead of replacing the whole board.
                  • ecking767
                    • Oct 2009
                    • 492
                    Do you know which chip they are using for this upgrade? I have seen three difference chips on this main board:
                    MX25L6445E W25Q64BV and MX25L6406E
                    And do you know the firmware revision number? if you access the menu on the E321VL and the go to help, then system infor, this will tell you.
                    I had two main board with MX25L6406E that just when blank, then I get no response from the power button, I just order MX25L6445E and W25Q64BV
                    thanks
                    ecking767
                    • miguelon69
                      • May 2012
                      • 10
                      • usa
                      #70
                      Hi ecking767 i am using the chip Mx25l6445e and it worked good for me .
                      you will need to have a good eeprom data loaded to the eeprom in order to make it work
                      • ecking767
                        • Oct 2009
                        • 492
                        I was leaning toward MX25L6445E Just wanted to confirm this. I do have a good copy of the eeprom for the failing main board.
                        Thanks for the infor
                        ecking767
                          Since this is becoming common failure in the Vzio, may be some one can come up with the instruction and the resource on how to go about replacing or just reprogrammimng the IC with pictures.
                          • ecking767
                            • Oct 2009
                            • 492
                            Yes its a common problem for the following models: E321VL, E371VL,E421VL and E420VO. There maybe more models that uses this main board. Also I have found bad solder joints and the need to re-flow the main processor on these main board.
                            I'm able to read the eeprom U18 with my programmer and to find the eeprom simply when blank. why? I don't know.
                            Im testing the MX25L6445E on the same board now after having the
                            MX25L6406E going blank after 24 hours
                            ecking767
                            • johnz
                              • Jan 2012
                              • 66
                              I was thinking the same thing... now whos kind enough to do that??
                              • rock44
                                • Jun 2012
                                • 1
                                • us
                                #75
                                Would like to see in full what others have done. Tried swapping U18 from a good board to a bad one, didn't fix the issue. Any other ideas? Touched up the solder on the main processor and video processor, no help.
                                  So it looks like at least the E series are bad.
                                  Well, I hope someone that have done a lot will step up and help us out.
                                  I still like to know also if you load the firmware into the new IC first and then install it or install the IC and then install the firmware.
                                  Thanks in advance to whom ever will post the details info.
                                  • miguelon69
                                    • May 2012
                                    • 10
                                    • usa
                                    #77
                                    Hi here are some pictures of the eeprom programmer and program that came with it. this is an entry level programmer
                                    i bougth this at this website:
                                    www.mcumall.com
                                    is good enough for me but the professional programmers are like 1000.00 or more.
                                    here are the pictures
                                    Miguel Garcia
                                    www.itvrepair.com
                                    • miguelon69
                                      • May 2012
                                      • 10
                                      • usa
                                      #78
                                      here is a youtube video on how to take the eeprom out.
                                      http://youtu.be/0TJQ9-fRs0M
                                        Thanks Miguel, so the chip is just a 8-pin chip?
                                        • miguelon69
                                          • May 2012
                                          • 10
                                          • usa
                                          #80
                                          if you have the same problem and want to buy an eeprom from me ready to go pm me for a link I got it for sale on eBay for $25.00 free shipping
                                          • huzo
                                            HP 470 G5 blinking amber light no power
                                            by huzo
                                            The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
                                            So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
                                            I've tried flashing the bios...
                                            interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
                                            06-08-2023, 04:08 PM
                                          • What?
                                            Vizio SV422XVT blinking amber/white power light
                                            by What?
                                            Good day, hope all are healthy and cozy. I could use some help with my malfunctioning Vizio with a blinking power light. I have narrowed the problem to the main board but not sure what to do next. I guess it would be good to start with what I have done.
                                            Problem:
                                            I have no image, no sound, blinking power light. (left it plugged in overnight and it was still blinking the following morning). I tried the Vizio recommendations (hold power button for 30 seconds, press reset button, check the outlet is live)
                                            Power Board:
                                            I am getting 5v only. I have unplugged...
                                            04-27-2020, 06:21 PM
                                          • stevenallauca
                                            HP laptop does not charge the battery, the light turns amber and then changes to white.
                                            by stevenallauca
                                            Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
                                            - ACN (BQACN) 19.6v
                                            - ACP (BQACP) 19.6v
                                            - CMSRC (BQCMSRC) 19.6v
                                            - ACDRV...
                                            09-23-2024, 11:30 AM
                                          • x_orange90_x
                                            Vizio E550i-A0 no power, no standby light
                                            by x_orange90_x
                                            I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                                            11-20-2023, 09:49 AM
                                          • zwect
                                            Dell Latitude 5420 / GDF40 LA-K491P REV 3.0 / Amber / Orange light when power button is pressed
                                            by zwect
                                            I have this Dell Latitude 5420 with ST: CMF62F3, board GDF40 LA-K491P REV 3.0 that does not power on, i already searched for some clues about this problem that happens on mine but no BIOS i downloaded and flashed did anything.
                                            Only when the power brick is connected, when pressing the power button an amber light lights up at the front and slight decreases its brightness, the RAM and the CPU seem to heat up if the laptop is left connected but nothing else, other than USB devices getting powered.
                                            Here is the original BIOS dump from the 25R256JVEN chip.
                                            09-11-2024, 05:54 PM
