HP laptop does not charge the battery, the light turns amber and then changes to white.
  • stevenallauca
    • Sep 2024
    • 5
    • Ecuador
    Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
    - ACN (BQACN) 19.6v
    - ACP (BQACP) 19.6v
    - CMSRC (BQCMSRC) 19.6v
    - ACDRV (BQACDRV) 26v
    - ACPRES (ACIN) 3v
    - ACDET 3v
    - IOUT (BQIOUT) 0v
    - SDA (BQDATA) 3.6v
    - SCL (BQCLK) 3.6v
    - ILIM 1v
    - BATDRV (BQBATDRV) 3v
    - SRN (BQSRN) 3v
    - SRP (BQSRP) 3v
    - GND 0v
    - LODRV (BQLODRV) 0v
    - REGN (REGN6V) 6v
    - BTST 6v
    - HIDRV (BQHIDRV) 3v
    - PHASE (BQPHASE) 3v
    - VCC (BQVCC) 19.6v
    The battery is healthy, I even tried with a new battery.
    If someone can help me by telling me which are the important components for charging and I can check them again, if possible to know the voltage that must cross in a healthy charging system without problems. Attached schematic is page 27.
    https://www.badcaps.net/forum/troubl...atic-boardview
  • mon2
    • 14724
    Review the sticky above by piernov on charger circuits.
    Each mosfet in the power path is a suspect. The battery srn/srp should not be at 3v. Something is wrong here. Too many 3v.
    Remove all power. Meter in resistance mode. Test the resistance across each mosfet:
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    Post each measurement. Test the usual dc-in mosfets and also the battery charger mosfets.
    • stevenallauca
      • Sep 2024
      • 5
      • Ecuador
      Hi, thank you very much for your reply, the error was pq13, I replaced it and now it charges.
      But now I have the beep problem, it gives me 2 short beeps in 5 series, can you tell me what is the cause?
      I did some research but I can't find any information.
      Thank you for your help.​
      • mon2
        • 14724
        May be defective ram.
        https://h30434.www3.hp.com/t5/Notebo...0the%20modules.
        • stevenallauca
          • Sep 2024
          • 5
          • Ecuador
          Hello, I have already changed the RAM but the problem continues, it does not give an image to the screen.
          The sound is 2 short beeps (sb) with 3 seconds, it does it like this:
          2 (sb) - 3 sec - 2 (sb) - 3 sec - 2 (sb) - 3 sec - 2 (sb) - 3 sec - 2 (sb)
          After this it does not beep anymore. The Caps Lock light stays on with 2 short blinks every 3 seconds, it does this indefinitely, the fan also stays on only until I remove the power from the power supply.
          I tested what happens if I turn it on without RAM, the beep is 3 short times.
          I also tested putting in a new CR2032 battery.
          I don't know if it has anything to do with changing the mosfet, but I doubt it. The change I made was from a 6414A to a 6428. I couldn't find the 6414A, but I investigated the 6428 and it could be adapted to the 6414A work system. I changed it and it works without any problem regarding charging.​
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Give us the voltage on all coils after pressing power switch. There may be a missing rail.
            Observe the mb under microscope/magnifier for corrossion etc.
            • reessi
              HP 14-CE0523SA (14-CE0000 Series) - DC / Charge LED Flashing 5 Times White!
              by reessi
              DA0G7AMB6D1 REV.D Board:
              A strange fault occured while I was calibrating the battery. This battery had not been used for a while.
              Previously to calibrating the DC/Charge LED operated normally:
              Off when no charger,
              Solid Orange while charging with Charger,
              Solid White when 100% Full with charger.
              I charged to 100% then left it playing a long youtube video,
              as expected the guage was wrong and it just cut off before reaching the low percent where it would sleep.
              It wouldn't power on so I plugged charger expecting to...
              07-06-2023, 09:59 AM
            • m041633n
              GDM50 LA-L241P Rev 1.0 - 2 Amber and 7 White Led Fix Needed
              by m041633n
              Hello Everyone!
              I would like to know the Jumper location for the 2 Amber 7 White Led Blink Code error. According to Dell 2,7 Led codes are for display or the Display cable failure. I didn't changed the display nor the cable. The issue happens only when restarting the machine from windows and from the BIOS. And when opening and closing the lid the display turns off and never turns back on. But the machine is working! I confirmed it by pressing the CAPS Lock key. Does anybody has this issue and fixed it by jumpering some fet near the display connector on the motherboard. If So Please Help...
              03-31-2025, 08:35 AM
            • Themi
              Dell XPS 13 9310 2 amber 4 white memory failure
              by Themi
              I have this laptop a dell XPS 13 9310
              Power on is ok, stuck at dell logo flashing 2 amber and 4 white (link dell service manual) 2,4 Memory or RAM (Random-Access Memory) failure​
              I believe this is the spec from using micron tool to decode marking
              Images of the ram
              I am thinking to replace but wondering if there is a possibility to test while in circuit to find the faulty module? I am doubting there is any reasonable test possible while in circuit as most ram ICs I have tested previously, I have done while off board / removed.
              Another...
              11-24-2024, 09:06 AM
            • s_henya
              Dell Inspiron 3593 3 amber 1 white
              by s_henya
              Got this in today,
              no signs of life.
              found a broken charging port- after replacing it, the laptop turns on and charges the battery.
              Trying to turn it on, laptop powers up, capslock is on and not responding, no image on the screen. Indicator led is flashing with 3 amber 1 white.
              CPU and GPU are very hot, so laptop has all the required voltages.
              Cmos battery is okay ~2.9v which supposed to be okay.
              Could it be a bios problem?...
              10-14-2024, 03:10 AM
            • Amirnsrti
              Dell Inspiron 5567 2 amber 6 white error
              by Amirnsrti
              Hi everyone
              I have this Dell Inspiron 5567 laptop that shows 2 amber 6 white error when I try to turn it on it's fan starts to work at very high speed even though I just turned it on and laptop is cold, screen is black but it shows very dim lines for less than a second when I click on power button. I used it like 4 years and I got this error so I didn't used it for last 3 years.
              The error it gives is for motherboard chipset issue.
              I Read some topics that something is wrong with bios but I don't really know how to flash the bios using another bios file. So I really appreciate...
              07-08-2024, 10:40 PM
