Panasonic TX-48CX400B low LED volts
  • finntricky
    • Jan 2014
    • 449
    • uk
    Hi guys
    hav'nt been around for a little while, but just got this panny/vestal in.
    tv turns on and can see pic with torch, and it did have a brief led flash, but no longer,
    17IPS20 power board
    now longer flashes the LEDS on boot, checked volts, and LED voltage is steady at 79v, it did max at 180v once while testing, is it possible the the driver chip has give up ? how can i test it, all other voltages seem to be correct,
    Re: Panasonic TX-48CX400B low LED volts
    So if the TV is off, put the LED connector back in place, and then you attach the meter probes to the negtive leg and positive leg of either one of the two 56uF 160DC cap and then turn on the TV, you do not see the Voltage jumps up 10 180V any more?
    If you did have the LED connector in place when you get that reading of 180V, it is telling me that you have open circuit in the LED string some where.
    When the LED power supply does not see the load the output will go up to the max which will then trip the over Voltage shut down then all you get will be the feeding Voltage that feed the boost converter circuit, in this case, it is around 80VDC.
    It can also be that the BL-ON is not present to turn on the backlights driver circuit.
    So lets verify for sure if the boost converter is working or not.
    There are many threads about this power supply board but there are many version of this 17IPS20 PCB which can be stuffed in may ways to make a bunch of different PCBA's.
    That barcode is the number of the PCBA.
    Is it 23253638? or 23253538? I have a hard time reading all the numbers on that barcode.
    • finntricky
      • Jan 2014
      • 449
      • uk
      thank you, i did'nt even think about getting BL ON from main board, so i will check that.
      the LED plug was in while testing, but still remained at 79v with no increase of volts,
      had a read of the threads on here and also watched a few vid's on you tube,
      before asking here for some inspiration, but i think something has sorted and can't find it at the moment, but i'll see if i have the signal from the main board when i get home tonight so i can rule that out.
      i can't believe i did'nt think of checking it.
      • finntricky
        • Jan 2014
        • 449
        • uk
        23253538 is the correct one
        • finntricky
          • Jan 2014
          • 449
          • uk
          checked what i think is the BL_ON off pin 5 and get 3.28v when i turn the set on, still only get 79v at LED plug, but im getting 390v on the 3 main caps, 47uf 450v
          • finntricky
            • Jan 2014
            • 449
            • uk
            checked what i think is the BL_ON/OFF on pin 5 power board to main board connector and get 3.28 volts on turn on, and holds steady,
            the 3 big caps rated 450v gives me 390v, so if i have the right pin, and the 3.28v is right, then the LED circuit is being told to turn on, but still only get 79v at LED plug, even when plug connected,
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              It would appear that you have faulty LED/s backlight strips.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                sorry ignore as wrong psu number
                  So far the PFC Voltage booster is working because you are getting 390VDC on the main filter caps which also means the PS-ON is present.
                  The key point right now is that we are not 100% sure if pin 5 of the connector is BL-ON/OFF or not.
                  Can you identify the PS-ON pin.
                  And If I remember correctly, some of these VESTEL boards use ACTIVE LOW for the control signals, but no matter what it uses, you should see the signal toggles from one state to another state when TV is toggle on and off.
                  • finntricky
                    • Jan 2014
                    • 449
                    • uk
                    i used this sch, not R9 version but R6, as that is all i could find, pin 5 volts are 0v when tv is off, and 3.28 when on, the problem is with these boards is there are not any volts or markings on them to say what they are or should be
                      I have that diagram also but after looking at you board and the schematic, they are really that close to what you have on the board.
                      But one thing you may be able to do is to look at the LED driver IC to see if it uses the same one as used in your board or not, the schematic show U500 as MP3394, if it is then you can check the VCC pin and the EN (BL_ON/OFF) pin to see what you have.
                        BTW, you need to check those two diodes by the two 56uF 160DC caps that I had you measure the Voltage earlier, check the RESISTANCE of those two diodes to see if they show low resistance readings in both direction or not, if those diodes conduct both ways then you will not get the Boosted Voltage.
                        • sordids999
                          • May 2013
                          • 2161
                          • uk
                          Main caps 47uf 450v reading 327volts
                          CN4 readings
                          Stby =1.94 volts
                          +5stby=0.00 volts
                          12v =12 volts
                          Very strange this one I can't seem to control the tv with remote
                          And voltages on 56uf caps voltages was good but after removing the psu now no reading
                          • sordids999
                            • May 2013
                            • 2161
                            • uk
                            Sorry ignore first reply from me had issues with button and remote to turn on tv which has been resolved
                            Exactly same results as finntricky posts and brief flash of backlight once turned on plus voltages dropping on led pins
                            So I'm 99% sure its a bad led but I'll update this post once I've stripped it down
                            • Andrew F. Ali
                              • Jan 2014
                              • 2450
                              • Trinidad & Tobago
                              With these large screens where once I get in to replace LEDs, I like to replace them all with new ones and so do not have to worry about LED failure in the near future
                              • sordids999
                                • May 2013
                                • 2161
                                • uk
                                Update ##
                                Bad led inside the screen and omg what a nightmare
                                The plastic supports that hold the screen are supposed to just twist but are glued !!!
                                And everyone one of the 66 led lenses fell off maybe too much heat dried the glue up !
                                So here I am now one by one glueing them back on so see you next year
                                • FatLad
                                  • Dec 2018
                                  • 2
                                  Bringing back an old thread because it has the same panel and TV model as I have here.
                                  Just to confirm, PSU is a 17IPS20 - 23253538
                                  TV Model is TX-48CX400B
                                  Initially it had no backlight, I stripped the TV and checked all LED's in the screen illuminated as they should using an external PSU. Both 'groups' of LED's ran fine at around 90 VDC each.
                                  I eventually replaced the U500 (MP3394S) which did seem to cure the fault for a very short while, the backlight fired up and worked for a minute or so them again it went out. I spend a while doing cold checks based on a variation of info I found online but to no avail, I assumed there was some other fault elsewhere on the PSU that took out U500 so I gave up and ordered a replacement PSU.
                                  The replacement PSU arrived, I fitted it and sure enough, the same problem as when I first changed U500 on the original board, it fires up for a minute or so then the backlight dies.
                                  I went on to measure the voltages to the backlight, As the set if starting up (No backlight yet) I get around 80volts to each backlight 'group' this then rises to around 120volts as the backlight fires up. After the backlight dies, again it drops to 80volts.
                                  What I've noticed, while keeping U500 cool with a stream of cool air the backlight stays on, however after doing various tests and measurments eventually without cooling U500 failed again, I was back to no backlight at all. I changed back to the original PSU with the new U500 (MP3394S) and again, the backlight would come on but after a short while (U500 heating up) the backlight would go off again.
                                  Now, I measured the current to each group of LED's in the backlight, at 90volts (Using an external supply) one grouup pulls around 80mA and the other group around 150mA. Raising the voltage up to 120 volts as to match the TV's internal supply both groups pull in excess of 300ma. This I suspect is why the MP3394S is failing? They are rated at 200mA as far as I can see.
                                  Does anyone have any idea where I should look next as this is taking more time and U500's than I can afford to throw at it.
                                  Thanks.
                                  • Duranitron
                                    • Jul 2014
                                    • 544
                                    • Philippines
                                    its not normal for the mp3394s to heat up if you have the schematics try to check all components surrounding the ic. also check the OVP circuit if you have an led backlight tester with current display let it fire up all the LED backlight from 80volts to 120vdc and let it lit for about 30min to an hour to isolate the problem that the LED backlight is not the culprit. my experience is 80vdc to 120 vdc current read out of 300mA max. it can pump up to 48 watts thats ok. there is always a possibility of shorting led when it reach the normal voltage so this test will surely catch it.check also if it has mosfet connected to the IC. hope you fix it just try and don't over see the obvious.
                                    Never stop LEARNING because life never stops TEACHING!
                                    • thuss
                                      • Jul 2012
                                      • 321
                                      • uk
                                      Hi Finntricky
                                      Did you find the fault on the 48cx400b?
                                      • finntricky
                                        • Jan 2014
                                        • 449
                                        • uk
                                        Originally posted by thuss
                                        Hi Finntricky
                                        sorry thuss, can't remember if i fixed it or sold as parts,
                                        • u666sa
                                          HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                                          by u666sa
                                          Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                                          Platform: ipa32 la-m024p rev 1b
                                          Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                                          I found a short on the other side:
                                          10-04-2025, 05:03 PM
                                        • BigPete
                                          Panasonic Heatpump Dryer Repair
                                          by BigPete
                                          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                          Unfortunately the whole machine has to come apart to fix it.
                                          I have...
                                          11-01-2025, 06:40 PM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • supermattch
                                          HP 15dy-2021nr wont power on mystery volts
                                          by supermattch
                                          Hi everyone.
                                          I am diagnosing my personal laptop, because it wont power on and no leds light up.
                                          At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
                                          Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
                                          09-23-2025, 12:13 PM
                                        • AquaMan Ua
                                          Problem with PANASONIC CF53 laptop after changing BIOS settings
                                          by AquaMan Ua
                                          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                          05-17-2025, 09:40 AM
