Panasonic TX-48CX400B low LED volts
  • sintv
    • Feb 2015
    • 37
    • scotland
    Re: Panasonic TX-48CX400B low LED volts
    This seems to be a common problem with no solution. Ive got the same problem and I checked all leds and theyre fine. Just have to wait till I get a working set in so I can swap boards.
    • zwarder
      • Oct 2013
      • 46
      Same problem here IC heating up to 110 degrees C then cuts out
      • jesseharris227
        • Dec 2020
        • uk
        Originally posted by Duranitron
        its not normal for the mp3394s to heat up if you have the schematics try to check all components surrounding the ic. also check the OVP circuit if you have an led backlight tester with current display let it fire up all the LED backlight from 80volts to 120vdc and let it lit for about 30min to an hour to isolate the problem that the LED backlight is not the culprit. my experience is 80vdc to 120 vdc current read out of 300mA max. it can pump up to 48 watts thats ok. there is always a possibility of shorting led when it reach the normal voltage so this test will surely catch it.check also if it has mosfet connected to the IC. hope you fix it just try and don't over see the obvious.
        Do you have schematics or know where I can get them fit this board
        • PanasTC
          • Nov 2023
          I have similar issue where boars states 400V and I am measuring 160.
          • u666sa
            HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
            by u666sa
            Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
            Platform: ipa32 la-m024p rev 1b
            Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
            I found a short on the other side:
            10-04-2025, 05:03 PM
          • BigPete
            Panasonic Heatpump Dryer Repair
            by BigPete
            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
            Unfortunately the whole machine has to come apart to fix it.
            I have...
            11-01-2025, 06:40 PM
          • Andre Gilbert
            by Andre Gilbert
            11-20-2024, 08:52 PM
          • supermattch
            HP 15dy-2021nr wont power on mystery volts
            by supermattch
            Hi everyone.
            I am diagnosing my personal laptop, because it wont power on and no leds light up.
            At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
            Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
            09-23-2025, 12:13 PM
          • AquaMan Ua
            Problem with PANASONIC CF53 laptop after changing BIOS settings
            by AquaMan Ua
            Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
            05-17-2025, 09:40 AM
