How to connect 6 monitors to a PC?
  • buchman
    • Aug 2015
    • 294
    • greece
    I built an AMD PC and I have GTX 1070ti graphics card with only 4 outputs to 4 monitors, I want to connect 2-3 more monitors, what are the cheapest options do I have?
    Thanks in advance.
    • 31300
    Re: How to connect 6 monitors to a PC?
    a video booster/amplifier.
    company's used to use them in conference rooms and large area's
    i used to see them go for beer money at auction all the time.
    • buchman
      • Aug 2015
      • 294
      • greece
      I forgot to mention that I need to see a different picture on all monitors.
      Do you have a link with an example of the video amplifier?
      I googled it and it seems that it's not what I am looking for.
      • R_J
        • Jun 2012
        • 9629
        If you want a different picture on each (all) the monitors, you will need a second video card. I see no other way of doing it.
        • diif
          • Feb 2014
          • 6978
          • England
          Add another graphics card.
            • 31300
            does the 1070 really have 4 independant outputs?
            i thought it only had 2 - not connectors but actual streams.
            • buchman
              • Aug 2015
              • 294
              • greece
              Isn't there another option except adding a second graphics card? Maybe some kind of HUB or a splitter?
              Some one told me that I have to install same graphics card that I currently have. In addition, I need to upgrade the power supply, do I? I have 750W right now
              • buchman
                • Aug 2015
                • 294
                • greece
                I have 5 outputs but 4 are actual streaming. I think it depends on the version for each country.
                • R_J
                  • Jun 2012
                  • 9629
                  If this is what you want to do, You can't take one output and SPLIT it and expect the video to be different on each monitor.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8715
                    USB video "cards"...
                    ...suck...
                      master hoarder
                      • May 2008
                      • 12175
                      NO, unless you want to run the cards in SLI... which is pointless and hence pretty much dead these days.
                      Could you be more specific what you are trying to do when you use the 6 monitors? If it's not related to gaming or rendering in 3D on all 6 monitors at the same time, then you can use any plain low-end garbage PCI-E video card (or PCI if you don't have any more PCI-E slots??) The 2nd (cheap/low-end) card will just be used as a display device. So long as you don't require it to do crazy 3D rendering, you can get away with just that. Just pick a low-end card that has all the outputs you need. It doesn't have to be new... or an nVidia (though it might make sense both cards to be from the same company so you can configure them together with same control panel at once vs. having one for nVidia and one for ATI/AMD, which could be annoying for multi-monitor setup.) Moreover, going with something low-end (low power) and you won't have to worry about your power supply.
                      On that note, though, what kind of "750 Watt" power supply are you running - i.e. brand name and model? If it's a no-name, I'd be worried regardless. But if it's something like an EVGA, Corsair, Thermaltake, Antec, Seasonic, or other known-brand name, then it's more than enough for your current GTX1070 with lots of room to spare for another low-mid-range GPU from just about any era... so no need to upgrade it.
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5045
                        • US
                        I have an EVGA 1070ti with five (DVI, hdmi, 3xDP)
                          • 31300
                          i bet the DVI and HDMI are in parallel.
                          they are afterall the same signals with a different connector.
                          HDMI just adds audio and encryption
                          • buchman
                            • Aug 2015
                            • 294
                            • greece
                            Bought this one, hope it will be OK.
                            I want more monitors for stock trading.
                            My power supply is Corsair TX750M.
                            https://www.ebay.com/itm/Plugable-7-....m46890.l49292
                            • R_J
                              • Jun 2012
                              • 9629
                              How is a USB hub going to get you 7 "separate and unique" video signals from the pc?
                              Maybe something similar to this https://www.matrox.com/en/video/prod...88-lp-pcie-x16
                              • Uranium-235
                                Comrade Glimmer
                                • Aug 2007
                                • 5045
                                • US
                                That could be true. They could be DP+ and just shunt the HDMI source there for passive connector compatibility
                                • Uranium-235
                                  Comrade Glimmer
                                  • Aug 2007
                                  • 5045
                                  • US
                                  I thought he got USB's and display ports confused. Unless he's using separate USB graphics adapters (with what he's using for, which is stock trading, which I don't think takes up much graphics power). Still....that is a lot of bandwidth, even for USB 3.0, especially if they're 4k. I think there is a maximum for something like that
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8715
                                    Yeah he'll still need USB to video adapters for each monitor. I was playing with a USB2 video adapter, these are miserable if you want to do graphics on it, but just to display a mostly static display it's just fine. Update rate is noticeably slower than a regular video card.
                                    I've never/had tried USB3 video adapter. For the most part I think it's a last resort option...
                                    • Uranium-235
                                      Comrade Glimmer
                                      • Aug 2007
                                      • 5045
                                      • US
                                      USB video for 2.0 was ages ago, they're more powerful, but x3, Or get a USB PCI-E card so it's hot hubbed
                                      Still, a cheap video card instead of 3x USB gpu's would be best option. I think the USB graphics adapters combined would be too slow, and to expensive
                                      • dragos2009
                                        • Mar 2013
                                        • 110
                                        you can try get a nvidia quadro nvs810 it has 8 display port outputs that is the only video card i know which has that many outputs
                                        • KYBOSH
                                          Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                                          by KYBOSH
                                          I picked this one up today.
                                          Previous owner says no signs of life.
                                          TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                                          Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                                          The TV model is QN65LS03BAFXZA - version: CB06
                                          The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                                          I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                                          Will keep you all...
                                          04-05-2025, 08:32 PM
                                        • An-klamm
                                          Samsung 55HU8590 UE55HU8590 maybe one connect box ocb
                                          by An-klamm
                                          Hello!
                                          I have a TV that I can't get any further with.
                                          It is a Samsung UE 55HU8590 with one connect box.
                                          When I turn on the TV without the one connect box, the animation on the TV tells me to connect the ocb.
                                          As soon as I connect it, the TV restarts (panel goes dark) and the TV tries to start continuously (relay on the SMPS clicks about every 3 seconds).
                                          Since the TV works without ocb, I assume that it can't be the PSU?!
                                          I have measured all contacts of the one connect cable against GND on the ocb board and there is no short circuit anywhere.
                                          Is there...
                                          12-04-2023, 01:35 AM
                                        • MrCommunistGen
                                          Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                                          by MrCommunistGen
                                          My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                                          I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                                          07-12-2021, 05:11 PM
                                        • jinu_j
                                          How to test Subwoofer Amplifier with only a multimeter
                                          by jinu_j
                                          Hi Folks
                                          Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                                          Problem
                                          I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                                          Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                                          Any advice would be appreciated...
                                          08-29-2024, 02:05 AM
                                        • EazyBone
                                          Samsung The Frame TV no power indicator issues diagnosing the one connect box
                                          by EazyBone
                                          I got a qn65ls03ta from someone who stated shows no power at all. They said they bought a fully new tv (same one) and tested the one connect box from the old one onto the new one and said it worked.
                                          I have no reason not to believe them, so I crack open the TV and test for voltages on the main board. There are none. I can't get any voltage at all. (Power comes from one connect to Main board then sends power to additional power board for backlights I believe)
                                          While doing some digging I found the connection to the one connect cable ON the main board seems to be missing small...
                                          07-28-2024, 04:46 PM
