My uncle has an ABS computer, it has been turning itself off after about an hour of use since he had it. He brought it to me this weekend, after checking power supply I noticed it had high cpu temp in the bios. I removed the heatsink and found it had the cheap foil pad on the heatsink, the plastic remove me before use cover over the pad, and a silvery paste on the plastic pad. Someone must of had a few to many the night before :P
I'm laughing at ABS Computer
Re: I'm laughing at ABS Computer
had one a few days ago that would post and die.
kid who owned it said it started when mom dropped it from the van.
found the hsf laying in the case.the socket lugs had broken off.
found a fancy amd hsf that used the other wide lugs on this socket 370.
told the kid that he was lucky since it was an intel.an amd would have went up in smoke! -
a bit of advice. dont leave the side panel open. got home one day and found an open baby bottle leaking and the power supply shorted, the mobo blew, the GFX blew, the NIC isnt the same(only got 2.1mbps transfer rate instead of 100.0mbps)and i still am using that busted NIC(now 612 KBPS) and i plan to use the other one that is sitting and collecting dust on top of the rig some day. The HDD FDD and CDD are gone.
Well anyway nice to see another person with that responsibility dont let that crying make you insane. babys cry ALOTComment
My 3 year old stores his toys and tools in my open comp cases, even when running!Comment
Originally posted by Fatal0EThanks, 26 damn its going to fast. Just found out my wife is pregnant, so its a pretty big birthday present.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
by KemerHello, the LED status indicators on my Lenovo Z580 are not working. Actually the motherboard LEDs are working but the light doesn''t coming to the front view. The plastic part is which you can see in photo must transfer the light to the frontview but just half of the plastic is illuminating.
There are three status indicators on the front (power, battery, caps lock), and none of them are illuminated.
The plastic piece doesn't appear to be broken.
1. What are your suggestions for resolving this issue?
2. Is the plastic piece made of special ma... -
by harpI have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
by VenHello everyone,
I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...1 Photo -
by piernovMy turn to post a build I guess, wasted way too much time on this one…
First proper SLI board I get so wanted to play around a little bit since I got a couple 8800 GTS.
Everything done with random parts I had lying around.
Specs :- CPU: Core 2 Quad Q9450
- RAM: 2x2GB KHX6400D2K2
- GPUs: 2x Nvidia GeForce 8800 GTS G80 320MB
- MB: P5N-E SLI
- PSU: Antec Basiq Power 550 Plus
- HDD: Hitachi Ultrastar A7K2000 1TB
- ODDs: DVD ROM, DVD RW
- Case: not sure
Cooling:- 92mm rear fan
- 120mm front fan
- Additional heatsink on southbridge
by harpI have RX26PG2 graphic card with incomplete original heatsink, only aluminium plate... but in original solution it look like such bad termal design that I asking if is proper fanless heatsink be adequate replacement ot better... what you think? Till powering on, it is propper hot......
- Loading...
