Led status indicator light transfer plastic
This topic has been answered.
  • Kemer
    • Apr 2023
    • 42
    • Turkey
    Hello, the LED status indicators on my Lenovo Z580 are not working. Actually the motherboard LEDs are working but the light doesn''t coming to the front view. The plastic part is which you can see in photo must transfer the light to the frontview but just half of the plastic is illuminating.
    There are three status indicators on the front (power, battery, caps lock), and none of them are illuminated.
    The plastic piece doesn't appear to be broken.
    1. What are your suggestions for resolving this issue?
    2. Is the plastic piece made of special material?
  • Answer selected by Kemer at 08-19-2025, 07:16 PM.
    mon2
    • Dec 2019
    • 14803
    These are called 'light pipes' and they are used to deflect the direction of the original LED so it is visible to the viewer. You can try to google / check Aliexpress for 'Lenovo light pipe' to see if there is a hit. Someone in mainland China is making these. I have met with many manufacturers of the same for our enclosures we use in production but hard to say who owns the tooling for your exact Lenovo model.
    • mon2
      • Dec 2019
      • 14803
      • Kemer
        • Apr 2023
        • 42
        • Turkey
        Thank you so much. Looks like I'm pretty lucky. I came across someone who was very knowledgeable about the subject. But it's a shame that it's such a special product. I realized that it was a completely broken part. Thanks again. Have a great day.
        • mon2
          • Dec 2019
          • 14803
          I am baffled as to why the LED does not travel through to be visible. If you indeed can see the led ON on the board, it should be ok to lift out these tiny clear plastic 'lense' like units. Perhaps a bit polarized and someone before you already messed around with the orientation? Personally have a fetish for ultra bright leds and we place them on everything. Buying them in 100,000 pc lots and the manufacturers in Asia always ask - do you want to buy Grade A or grade B? In the led world there is also 'binning' where the vendor will make sure the led from one batch will match the appearance of another for the color, intensity, etc. This is a must if making LED signs. Cannot have off colors on such devices.
          Can you post a better pic of these light pipes? You may be able to cross them to other companies and buy from Mouser or Digikey. For this, you must measure with a micrometer for the length x width x height.
          Unless something is blocking the led light, it should be visible through these tiny plastic parts.
          • Kemer
            • Apr 2023
            • 42
            • Turkey
            Sorry just noticed your message. I attached the photos of my own laptop.
            Hoping it would fit closer, I placed a piece of paper underneath the motherboard side of the light tube. Then, I lowered the same end as far as it would go without forcing it. As you know, the other end needs to fit through the tiny holes in the front panel. Meanwhile, I'm noticing a very faint light on the front panel.
            I considered removing that piece and replacing it with three improvised plexiglass rods, but the results are uncertain and laborious.
            I couldn't understand why it wasn't working. It's not a major issue, but I didn't want to give up just because I couldn't figure it out. Still, thanks to you, I quickly found more information than I expected. Thanks again.​
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • roy.zhero
              Sharp LC50LE752E no picture and backlight, indicator light is lit
              by roy.zhero
              I acquired a free 50” TV. IT is a Sharp LC50LE752E. It does not show a picture and has no backlight, although the indicator light turns blue meaning it has turned on.
              When power is plugged in, the indicator light will turn on blue, the backlight stays off and nothing is visible, even with a flashlight. When pressing the touch buttons on the tv nothing happens. When pressing buttons on the remote control the indicator light will blink indicating the IRsignal was received, but nothing happens.
              When I hold the force-on-combination it will turn on. It then shows a perfect...
              09-20-2020, 01:57 PM
              Lithonia Lighting versus Light of America Compact Fluorescent product quality
              by sam_sam_sam
              I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
              I also have back when Light of America had these light bulbs available for yard lights
              The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
              While the Lithonia lighting fixture has all most certain bulb failure
              So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
              I have only had this light fixture for not more than a year if it...
              07-02-2023, 03:45 PM
              LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
              This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-06-2024, 09:10 PM
              09-06-2024, 08:40 PM
