The dust thread
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Re: The dust thread
    The dust I hate is the kind that seems to have a coating of glue on it that compressed air can't budge. You wind up going in with a lint-free cloth and some q-tips and attempt to work around all the parts.
      master hoarder
      • May 2008
      • 12175
      #42
      Re: The dust thread
      Originally posted by Krankshaft
      ALWAYS flip the CPU fans on those comps to blow out from the factory they actually blow in.
      On that particular model (Dell Dimension 3000), the 92mm CPU/system fan blows air out of the case by default. Problem is that the front intake hole is really small so the CPU/system fan starts to suck air from the vents on the back of the computer, which pretty much has the same effect that you described. Keeping one of the sides slightly open eliminates this problem and keeps the fans dead silent, even when CPU is under 100% load. Of course your method with the 120mm fan on the front is definitely a more neat alternative.
        • 31283
        Re: The dust thread
        i fit a 92 or 120 on the front,
        i put it in front of the floppy/3.5" bays and cut the metal out so it cools the drives.
        fit the fan on the outside of the metal, and cut the plastic front so it sit's flush - almost.
        then fit a filter.
        here is one i did for a friend - not filtered.
        double 80mm bb fan's going direct to the drives & mobo.
        no metal behind them.
        • c_hegge
          • Sep 2009
          • 5219
          Re: The dust thread
          Originally posted by kc8adu
          looks like that one was in a bad environment.rust on the case.
          had a neighbor with a unit with a dead mobo.turns out it failed due to mouse pee.
          I get lots of computers with rusty cases. One that I had in a few weeks ago looked 10 times worse than that. Some look so bad that I reckon I could just push the grills out.
          Just before the motherboard died on this dell, my boss was getting data off it for the owner. He said that the fans would labour hard even under very light load. There was a coat of dust about 5mm thick over the CPU Heatsink.
          • pentium
            • Mar 2006
            • 2778
            Re: The dust thread
            I wonder when this last saw a good cleaning?
            It was in a dustbin of a case so nasty I tossed it outside. It was so dead the sparkle PSU in it wouldn't even power on.
            Find Nedry!
            Check the Vending machines!!
            • Wizard
              • Mar 2008
              • 2296
              #46
              Re: The dust thread
              Looks like this decent heatsink was from a AM2 or AM3 AMD cpu, wouldn't this CPU be saved and put on different board?
              Cheers, Wizard
              • sofTest
                • Aug 2008
                • 361
                #47
                Re: The dust thread
                I don't have any pictures, but back in the mid 90s, the company I worked for was in a merger. In the other company, only the accounting department was networked. So, when the time came to co-locate to new offices, I had to find out what was needed to get rest of the PCs networked. Most of their PCs was standard stuff, like HPs. One of the exceptions was an engineer with an IBM in a desktop case. This case was placed flat on the floor, under the desks drawer section. Since IBM was IBM (read MCA) in those days, I had to open it up to verify what kind of card slots it had. When I opened, it was fully packed with dust. Visually, there was absolutely no free space in the case. Had to scope the dust out by the handfulls, to get to the slots. I was surprised it worked, as there must have been very little or no air circulation in that case. Fortunately that particular PC was so old, that it was decided to be one of about 20 to be replaced with the then new Pentiums, so I didn't need to clean it out properly, before fitting a network card.
                Be a mensch
                • pentium
                  • Mar 2006
                  • 2778
                  Re: The dust thread
                  Cheers, Wizard
                  It's for a socket 478 P4 actually and I'll put it aside for later once I figure out how to separate the CPU from the heatsink. It feels like it's glued in place.
                  Find Nedry!
                  • Wizard
                    • Mar 2008
                    • 2296
                    #49
                    Re: The dust thread
                    Clean off dust and warm the heatsink with your hair dryer or heat gun. The heatsink grease will soften. The OEM heatsink often is heat-melt termal pad that reharden when cooled.
                    Cheers, Wizard
                    • shadow
                      • Feb 2007
                      • 732
                      Re: The dust thread
                      That is what happens to the 478 socket cpu's with stock Intel thermal paste. It dries bloddy hard and is very difficult to separate the cpu from the heatsink.
                      What I did with mine was gently heat up the heatsink with a hair dryer..and slowly twist the cpu and heatsink and eventually I was able to separate the cpu from the heatsink.
                      • weirdlookinguy
                        • Sep 2007
                        • 1638
                        #51
                        Re: The dust thread
                        If heat doesn't work, try popping the thing in the freezer for a few hours and then trying your luck again.
                        That's what I had to do to get a 478 P4 off an aftermarket heatsink in an old home-built computer someone gave me that their uncle had put together for them a few years back.
                        The reason it was stuck? The idiot who put the thing together put the heatsink on without taking off that plastic tab that all heatsinks come with to keep the copper surface unmarred during shipping. He must have assumed it was some sort of pre-applied thermal paste.
                        • EGuevarae
                          • Nov 2008
                          • 1336
                          Re: The dust thread
                          There are 10 kind of people in this world: those that understand binary, and those who don't.
                          • ASUS ROG Maximus IX Code
                          • Intel Core i5-7600K 3.8GHz
                          • 16gb GSKILL TridentZ RGB DDR4-3200
                          • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
                          • Windows 10 Pro x64
                          • GeForce GT1050
                            2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            #53
                            Re: The dust thread
                            thats a close contender for the cruddiest hsf ever.
                            and i use my heatgun to warm it up then gently pry the chip off if stuck .if the board runs you can also run it a short while with the fan unplugged and when warm gently twist the hsf to break the cpu loose.yanking it out without releasing the lever probably isnt good for the very thin gold plating on the contacts and pins.
                            • Krankshaft
                              • Jan 2007
                              • 2328
                              Re: The dust thread
                              Dang if you didn't say it was dust I would say it was penicillin .
                              • c_hegge
                                • Sep 2009
                                • 5219
                                Re: The dust thread
                                This looked brand new after I gave it the leaf blower treatment, but here are the before pics. There was so much dust on the CPU cooler that the fan could not spin
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  #56
                                  Re: The dust thread
                                  It's like there's a carpet at the bottom of the case .
                                  By the way, one of the Teapo caps next to the CPU heatsink looks bulged in that last pic.
                                  • dood
                                    Deputy dood
                                    • Mar 2004
                                    • 2462
                                    Re: The dust thread
                                    Probably every one of those caps is cooked to death... whether they show it or not. Sandwiched between the CPU HSF and the PSU. That CPU HS was probably hot enough to take your finger prints off.
                                    Ludicrous gibs!
                                    • c_hegge
                                      • Sep 2009
                                      • 5219
                                      Re: The dust thread
                                      The cheapo teapo caps are indeed bulged. I will be recapping it.
                                      • AudioCraZ
                                        • Sep 2009
                                        • 147
                                        #59
                                        Re: The dust thread
                                        Just a few shots of some of the computers I got pictures of. We nicknamed the Dell the "Dell Planter". Ugh, how can anybody let a computer get this bad...
                                        • EGuevarae
                                          • Nov 2008
                                          • 1336
                                          Re: The dust thread
                                          Go to Mexico and you will see this almost on a daily basis. And do you want to know the best part? You'll see it in Government units ....
                                          • GeForce GT1050
                                          • emil_t
                                            RTX3090 working fine but fans not spinning
                                            by emil_t
                                            Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                                            04-12-2024, 06:54 AM
                                          • b-slayer
                                            Asus Strix-G15-G513RM fans don't work
                                            by b-slayer
                                            I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
                                            The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
                                            (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
                                            (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
                                            ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
                                            09-04-2025, 04:58 AM
                                          • RetroComputingGrotto
                                            IBM LTO 7 Tape Drive - Dust Sensors??
                                            by RetroComputingGrotto
                                            I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                                            I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                                            09-19-2024, 01:54 AM
                                          • JayPoorJay
                                            Hot Water Rad - A Few ECU Fans and a Timer Switch
                                            by JayPoorJay
                                            Good Afternoon, Good People.
                                            I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
                                            I REALLY would appreciate y'alls help.
                                            This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
                                            10-29-2024, 12:54 PM
                                          • howardc64
                                            Macbook Dust-Gate Preventive Cleaning
                                            by howardc64
                                            Just did this on my 2021 13" MBP M1. Dust-Gate design flaw still present. Depending on cleanliness of the operation environment (often eating while using MB is probably the worst). Periodic cleaning is probably warranted.
                                            Note this is quite challenging effort. One misstep will damage the LCD flex and render it useless. So take it to someone more experienced if uncertain.
                                            https://www.ifixit.com/Guide/MacBook...leaning/177920
                                            10-09-2024, 10:10 AM
