The dust thread
+ More Options
Posts
  • c_hegge
    • Sep 2009
    • 5219
    The dust thread
    You've probably guessed from the title what this thread is for. Posting dust. Let's start with some case fans I removed from a customers PC a few days ago
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: The dust thread
    id recommend this vid: http://www.youtube.com/watch?v=D2
    worst i have seen.
    sigpic
    (Insert witty quote here)
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Re: The dust thread
      bad link.
      try this
      http://www.youtube.com/watch?v=D2riqZvXXUE#
      sigpic
        master hoarder
        • May 2008
        • 12175
        Re: The dust thread
        Most of the freebee computers I get are usually well packed with dust.
        Worst one I got was a HP Pavilion 8756C. Grill on back was just a wall of dust, most likely because the intake fan on that was a 0.3A Delta screamer. There was also coffee drops on the dust, so it was sticky too. To top it off, there was some food chunks as well.
        After clean up, though, it made a nice secondary computer. Came with hard drive and everything loaded on it, so I shouldn't really complain.
        My computers, on the other hand, barely get any dust. Of course that's partly due to the fact that I also regularly vaccum the house and clean the AC/furnace air filter.
        • c_hegge
          • Sep 2009
          • 5219
          Re: The dust thread
          The PC that the two fans in my pic came out of was pretty bad, although not quite as bad as the one in ratdude's youtube video. The CPU heatsink was completely sealed (ie. you couldn't see the fins at all from the top) and because the CPU was a P4 Prescott the heatsink would get too hot to touch when it was running. It looks much better now with the dust gone.
          My computer doesn't get very dusty internals as the Antec 1200 case has filters on all of the intake fans.
          • NxB
            • Feb 2009
            • 1595
            Re: The dust thread
            I've seen that same dust before. I wonder where it comes from. A newer gateway I worked on was caked with it. The front fan was completely filled with it, as was the HSF and the power supply. We just vacuumed it out. Bug bits are worse though.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Re: The dust thread
              i remember finding a bunch of dead ants in my compaq once after i opened it to change cards. normally id have the side panel off more often, but i didnt and nasty surprise.
              fyi the youtube vid aint mine... i just remember seeing it and thinking it was a perfect fit for the thread.
              ps-dont forget to clean the filters!
              sigpic
              • 370forlife
                Large Marge
                • Aug 2008
                • 3112
                Re: The dust thread
                Whenever I see that, it's air compressor time. Gotta hold the blades so they don't spin way up and destroy the bearings though. Done that to a cheap fan, got it screaming with 185psi, fan blades eventually flew off.
                • c_hegge
                  • Sep 2009
                  • 5219
                  Re: The dust thread
                  Originally posted by 370forlife
                  ...got it screaming with 185psi, fan blades eventually flew off.
                  Had that happen to a Skt. A stock cooler once. Tried to clean dust out and lost a blade
                  OK then, "The youtube video suggested by ratdude". And you're right about it being perfect for this thread.
                  Oh, and I just remembered, I have come across one that would have to be as bad as if not worse that that one in the vid. The dust in the CPU cooler wasn't just a layer on top, it had gotten stuck in between all the fins (It was so bad I didn't even try to clean it, I just replaced it). The small space in between the bezel and front of the chasis was totally filled.
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    Re: The dust thread
                    i need to find the pics of a computer from a mangotech truss saw i service for a local truss plant.it was full of sawdust and the caps were burning the dust they were so hot.if it hadnt popped and bsod'd it would have been left on overnight and started a nasty fire.their mitek cybersaw often looks the same.i could shovel it out if i wanted to!couldnt even see the plc rack or motor drives the last time i was there.and they wonder why it would run 5 minutes and die with a motor overheat alarm!
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      Re: The dust thread
                      almost forgot the ford/rotunda analyser from a local ford dealer.
                      i bet there was 100 lbs of brake dust and other shit in this thing.even the flight recorder was full!
                      you know its bad when you roll it out on the shop loading dock and the harrison twp fire dept shows up while you are blowing it out!they saw the black cloud on their lunch run and stopped to check it out.
                      • dood
                        Deputy dood
                        • Mar 2004
                        • 2462
                        Re: The dust thread
                        I see crap like this every day, so I don't bother taking pictures anymore.
                        Ludicrous gibs!
                        • Junk Parts
                          Court Jester
                          • Jun 2006
                          • 8953
                          Re: The dust thread
                          My wife PC always looks like that and worse. Its on the floor with the 5 dogs and four cats. She's not real prone to running the vac ether. Mine on the other hand is up on my desk, and get opened and blown out monthly. Now I did trash out a Gateway lappy and it turned out to be full of beach sand. Nothing like a well salted, and sanded Laptop!
                          Mark Twain
                          John Paul Jones
                          Rod Serling
                          • golemmaster
                            • Jul 2009
                            • 100
                            Re: The dust thread
                            I've got a small collections of filthy 'puter pics. heh.
                            • kc8adu
                              • Nov 2003
                              • 8832
                              • U.S.A!
                              Re: The dust thread
                              it takes a really nasty one to get me to reach for the camera anymore too.
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Re: The dust thread
                                I had a question on EE where the guy asked how to clean mouse pee off of motherboards.
                                Mann-Made Global Warming.
                                - Dr Seuss
                                • NxB
                                  • Feb 2009
                                  • 1595
                                  Re: The dust thread
                                  Getting major deja vu with that dell.
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    Re: The dust thread
                                    Just cleaned out an Acer where the RAM slots were full of dust and it wasn't posting as a result. Works fine with the dust gone
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      Re: The dust thread
                                      i had to clean some old macs today. powerpc units from 94 or 95, filled with tons of dust
                                      since it was in shop class, i had the luxury of shopvac'ing it out. still nasty.
                                      sigpic
                                      • NxB
                                        • Feb 2009
                                        • 1595
                                        Re: The dust thread
                                        A shop vac is better than a compressor for these things. Once you vac it out THEN you spray it.
                                        • emil_t
                                          RTX3090 working fine but fans not spinning
                                          by emil_t
                                          Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                                          04-12-2024, 06:54 AM
                                        • b-slayer
                                          Asus Strix-G15-G513RM fans don't work
                                          by b-slayer
                                          I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
                                          The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
                                          (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
                                          (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
                                          ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
                                          09-04-2025, 04:58 AM
                                        • RetroComputingGrotto
                                          IBM LTO 7 Tape Drive - Dust Sensors??
                                          by RetroComputingGrotto
                                          I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                                          I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                                          09-19-2024, 01:54 AM
                                        • JayPoorJay
                                          Hot Water Rad - A Few ECU Fans and a Timer Switch
                                          by JayPoorJay
                                          Good Afternoon, Good People.
                                          I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
                                          I REALLY would appreciate y'alls help.
                                          This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
                                          10-29-2024, 12:54 PM
                                        • howardc64
                                          Macbook Dust-Gate Preventive Cleaning
                                          by howardc64
                                          Just did this on my 2021 13" MBP M1. Dust-Gate design flaw still present. Depending on cleanliness of the operation environment (often eating while using MB is probably the worst). Periodic cleaning is probably warranted.
                                          Note this is quite challenging effort. One misstep will damage the LCD flex and render it useless. So take it to someone more experienced if uncertain.
                                          https://www.ifixit.com/Guide/MacBook...leaning/177920
                                          10-09-2024, 10:10 AM
