How are Hitachi HD's for reliability these days?
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    The title is the question. Have they improved from the Deathstar (deskstar) days?
    Not that the WD drives I've been using have gone wrong in any way, but if there's something faster and just as reliable, I'll use that instead.
    A man convinced against his will is of the same opinion still.
  • gg1978
    • Dec 2004
    • 431
    Re: How are Hitachi HD's for reliability these days?
    They've been alright for me, though I don't have many of them..
    I've got a couple of used 120GXPs i picked up recently, a pair of 7K80's, a 90G 180GXP, a 120G 7K250, and a pair of 1TB 7K1000.B's, that i've picked up recently..
    • KeriJane
      Mac Enthusiast
      • Sep 2008
      • 681
      Hello
      Hitachi desktop hard drives have been doing great over here.
      Only one failure and that was caused by a Fuhjyyu'd Antec with like 750mv + of Ripple.
      You can't reasonably blame that on Hitachi.... getting Antec'd. It took out the motherboard too.
      Hitachi has a nice Acoustic mode that can be adjusted to limit seek noise (at the expense of seek time).
      Samsung and Hitachi have been the most trouble-free brands for me.
      Good luck,
      Keri
      The More You Learn The Less You Know!
      • everell
        • Jan 2009
        • 1514
        Antec'd????? What happened to Bestec'd??? Didn't think I would see the day!
        Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
        • washu
          • Jul 2009
          • 310
          The last big batch of computers (300+) we got in at work had about 40/40/20 split of Hitachi/Seagate/WD drives. So far the Hitachis have failed at about the same rate as the others. When the Hitachis go they usually seem to get bad sectors where the Seagates and WDs just die.
          We also got a few laptops with Hitachis which are mostly fine. The ones back from the IBM changeover however are crap.
          The one Hitachi I have at home is a 1 TB drive and so far it's been fine.
          • acstech
            GrumpyModerator
            • Jul 2007
            • 1432
            I find that a bit disconcerting, since I used Samsung before I switched to WD. Their 250GB P series and OEM drives always developed bad sectors. Every one of them. Even with Intel chipsets. Their 1TB F1 series drives would get the occasional bad sector, but worse, lock the computer until +5vsb was removed (PSU unplugged). That's the whole reason I switched to WD.
            Samsung's T series drives have worked ok for me though, as did their PATA drives. I'm glad they work for you...
            I don't see anyone screaming "no don't do it," with regard to Hitachi so I might try one out.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              i have had shit luck with ibm/hitachi notebook drives. years 99-02. old. but i see ones made by other out living them. i have left a 20gb ibm, 2 6gb ibm, and possibly a 20gb hitachi (needs to be re-tested). my maxtor one touch III 50gb still runs geat, other than the enclosure has seen some abuse.
              i had a thicker ibm 6gb notebook drive go south and recently a 30gb one as well.
              where can i find a bigger cheap pata lqaptop drive? say 15gb+?
              sigpic
              (Insert witty quote here)
              • 370forlife
                Large Marge
                • Aug 2008
                • 3112
                Hello
                Good luck,
                Keri
                750mv of ripple! Wow! That is even worse than the Topower with bad secondary and primary viva caps on the JG basement roundup. That could even take out a cheap fan or two.
                • crocodile2009
                  • Sep 2009
                  • 5
                  They run cold, fairly quicky and deadly quiet.
                  Only issues I have found with them is that they vibrate a lot more than other drives, so make sure it's screwed in well.
                  • KeriJane
                    Mac Enthusiast
                    • Sep 2008
                    • 681
                    Not to hijack the thread but I had an old H.E.C in here with apparently over a VOLT (1,000+mv) of Ripple. Smoke, too. Fuhjyyu, too.
                    I'm PRETTY SURE I was reading the scope right both times, but remember, I'm still learning! (both were done using a properly capped lead/PSU tester)
                    Back to Hitachi:
                    I'd rather have it grow some bad sectors than just quit. The WD's around here and the one Fuhjyyu'd Hitachi just died.
                    A Seagate 7200.11 grew bad sectors and now that I think really hard, I did have a Hitachi around 2004 or 2005 get some bad sectors. Oops. Didn't cause data loss though.
                    I also like the Caviar Black WD drives.... great so far.
                    Good Luck,
                    Keri
                    • bgavin
                      • Jan 2007
                      • 1355
                      I've nothing but bad luck with Hitachi/IBM drives.
                      Only one instance comes to mind with an IBM Deskstar that lasted years longer than it should have.
                      All the dead laptop drives I see are Hitachi.
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        Hitachi desktop drives are great IMO, but I don't really have much against any of the makers
                        Once in a while they might release a dud, but that's just life and can happen to anyone...
                        But if I'd have to rate the HDD manufacturers I'd put Hitachi close to top spot, what sets it for me is performance / noise etc
                        I.e. a pick a drive that is suitable for what I need, I don't really care about the make...
                        You will need backups in any case so the reliability factor in the sum of things does not really matter IMO...
                        • NxB
                          • Feb 2009
                          • 1595
                          When I was picking TB drives recently I settled on the Hitachi newegg special. It was the cheapest and had the least complaints of failure vs the other drives. It has not had any problems yet. Their laptop drives were hit or miss. Some ran for a long time, some got clicks of death.
                          • i4004
                            • Oct 2006
                            • 2029
                            to resurrect this a bit
                            what rate would that be, roughly?
                            10, 20, 30 per 100 drives?
                            • c_hegge
                              • Sep 2009
                              • 5219
                              Interesting you mention Samaung as being trouble free. For me, they are the most troublesome brand. Out of all the Samsumg drives I come across, about 60-70% either get bad sectors or just die after a few years.
                              I haven't had much experience with Hitachi lately. The little I have had suggests they're extremely unreliable. My boss sold a few and some only lasted about a month. The connectors are too loose as well and the one in his computer drops out every time the desk gets bumped
                              I prefer Seagate and WD as they have so far been OK. Sure, I've seen the odd one fail, but compared to samsung, the failure rates are low.
                              • i4004
                                • Oct 2006
                                • 2029
                                that suggests you were not using 7200.11 seagate's, right?
                                <wink>
                                • washu
                                  • Jul 2009
                                  • 310
                                  I don't have any "hard" numbers, as I haven't kept track that accurately. I'd say about 30 have gone in the 4 years we have had them, so about 10 per 100. About 10 went in the first couple weeks and the rest at random times after that. This is all in GX520s.
                                  About 3 or 4 of the seagates in those 520s failed in an interesting way: They shorted the power connector. The power supply would turn on then immediately turn off again if those drives were connected. Hooking them up to a beefy 600 W supply caused the wires to start melting, so we stopped that fast.
                                  We had a disastrous batch a few years before which were all Maxtor slimline drives. We just decommissioned the last of the 200 of those PCs (GX260s) after about 7 years in service. There was 1 Maxtor slimline left and it had bad sectors when we tried to DBAN it. So that's a 100% failure rate over 7 years.
                                  The middle batch were the bad cap machines (GX270 and GX280s) but their drives were remarkably reliable, despite having the crappy clam-shell cases that overheated them. I'd guesstimate that less than 5 in 100 of those drives died. They were about 50/50 Seagate/WD.
                                  The latest batch of PCs (replacing the GX260s) are a mix of HP DC5800s and Dell 360s. The HPs all have WD caviar blue and have had 2 out of 80 fail so far. The 360s all have seagates an so far none have gone, but they are about two months newer then the DC5800s.
                                  • i4004
                                    • Oct 2006
                                    • 2029
                                    yeah, i was also bitten by slimline maxtors...
                                    ok, thanks for reply.
                                    • weirdlookinguy
                                      • Sep 2007
                                      • 1638
                                      No protection circuit on those PSUs?
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        Originally posted by c_hegge
                                        The connectors are too loose as well and the one in his computer drops out every time the desk gets bumped.
                                        I don't know about the new ones, but the old (and problematic) Deskstars such as the 75GXP definitely had really crappy power connectors. I just fixed the power connector on my 307020 last week.
                                        The pins in the power connector are really thin near the PCB, so everytime I plugged the drive in to the PSU, they would all bend and crumble near the PCB. A little bit of Super Glue fixed the problem (at least temporarily). I'm sure, though, that with enough connections/disconnections, the pins would just eventaully break off, given the crappy design.
                                        But again, that's for the old Deskstars of the early 2000s. I haven't had any newer ones, but for my next computer build (which probably won't happen very soon), I might actually try one.
                                        • massimomax
                                          Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                                          by massimomax
                                          Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                                          spero che qualcuno può averlo per riprogrammare eprom. grazie
                                          Post in English !!!
                                          I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                                          02-28-2025, 07:27 AM
                                        • dragometin
                                          Hitachi 40HYC42
                                          by dragometin
                                          TV Model: Hitachi 40HYC42
                                          Power Supply: 17IPS71
                                          MainBoard: 17MB95M
                                          Panel: VES400UNDS-2D-NO3
                                          When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                                          I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                                          Is there any variants on 17IPS71 power supply's?
                                          UART output pins 10 and 12 on scart connector:
                                          Code:
                                          12:24:04.595
                                          08-08-2024, 05:53 AM
                                        • sotodefonk
                                          Help finding the correct model of a T-Con board on my Hitachi TV
                                          by sotodefonk
                                          Hi, I have a Hitachi tv model L47V651, there is no image, but sound and backlights turn on, so I believe the issue is the tcon board.
                                          I opened the tv to access the board and took the shared pictures of the T-Con board.
                                          I saw a video from shopjimmy on how to detect the model number on tcon boards, but this doesn't have a sticker like how that video showed all boards.
                                          I searched the P/N number and got results with the same marking name and P/N my board has but they list other specific tv models like Vizio and Philips brand but not Hitachi.
                                          Inspecting...
                                          06-28-2024, 04:39 PM
                                        • dicky96
                                          Hitachi V19B01922 Channel Tune problem
                                          by dicky96
                                          Hi Guys
                                          I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                                          He also has an LG TV, so three screens in the bar
                                          I installed three Satlink ST-6503 DVB-T Modulators
                                          This model https://www.aliexpress.com/item/32916553905.html
                                          These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                                          02-09-2023, 09:20 AM
                                        • navagator
                                          Hitachi Power Supply Unit Interchangeability
                                          by navagator
                                          I have a Hitachi 57F710E rear projection set with a bad power supply board. I've tried to fix it with help from this forum as well as another one, but without success. Today I found a Hitachi rear projection set for sale on Facebook that looked just like mine. After contacting the seller I found out it was a 51F510. According to the service manuals my set uses a HA01312, POWER UNIT DP4X-DM_24W and the 51F510 uses a HA01313, U901, POWER UNIT DP4X_24W.
                                          Does anyone know if these 2 power supply boards are interchangeable?
                                          Thanks.
                                          01-08-2024, 07:53 PM
