Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
  • massimomax
    • Feb 2025
    • modugno
    Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
    spero che qualcuno può averlo per riprogrammare eprom. grazie
    Post in English !!!
    I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
  • massimomax
    • Feb 2025
    • modugno
    I ask for help with a problem with a Hitachi 32HE4500 television that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have to reprogram the eprom. Thank you
    • Bazilwrc164
      Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
      by Bazilwrc164
      I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
      The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
      I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
      If anyone can provide:
      • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
      • Or a compatible EEPROM dump
      Yesterday, 12:15 PM
    • Askic
      Hitachi (Vestel) TV is not turning on
      by Askic
      Hello guys,
      I have 32 inch Hitachi TV with Vestel PSU board 17IPS71. Tv was working normally and I shut it down normally via remote control.
      The next morning it couldn't turn ON neither with remote controller or via button on the logic board.
      There is a red standby LED ON, so it is not dead totally.
      I have examined the PSU board and I cannot find find any traces of blown components or bulged caps. Electrolytic caps are manufactured by Elite.
      I also check diodes and big MOSFET (with cooler/heatsink). It seems OK.
      Can you tell me based on...
      01-11-2023, 12:34 PM
    • EnricoS92
      Hitachi 43HAE4251 - Vestel 17MB171 - Displays logo and reboots
      by EnricoS92
      I have a problem with this tv Hitachi with vestel 17MB171 board.
      I turned off a couple days ago and the next morning when I turned on it had the issue, i tried to left the power unplugged for several hours but nothing.
      The tv turns on shows the logo picture and after a few seconds reboots, and start over again.
      I was able to connect via uart to the tv and grab the log I attached, it has logged 3 reboots.
      I believe it is a corrupted software, but I could not find any online, does anyone has it, or where to download....
      12-08-2021, 05:59 AM
    • France_53
      Vestel tv, how to flip the image?
      by France_53
      Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
      05-12-2024, 05:22 AM
    • Ruptor
      Hitachi 55" TV dead after 18 months (Vestel 17MB100)
      by Ruptor
      I couldn't find any other thread that matches my TV problem but have been told it is a common fault. The fault is a flashing LED as if it is in upgrade mode that happens after a few seconds and stays forever. I can't remember all the tricks that have been tried like holding the select button when powering on but nothing worked. The shop sent me a flash drive to plug in a USB port but that did nothing either and they said it was dead which is disgusting for a piece of solid state electronics. I took the back off eventually after removing 34 screws to check for blown caps but everything looks new...
      09-27-2021, 10:19 AM
