Burning issues. No idea what is up.
  • pentium
    • Mar 2006
    • 2778
    I have a NEC ND-2500A DVD burner (which can also support burning dual layer dvds with a firmware flash) and I was burning some images (that were made using MagicISO) I made today when things went funky.
    I first burned a cd full of pdf files and photos and it burned fine. I then did a dvd full of avi video clips and it too burned fine too (even plays on my PS3).
    Then I proceeded to burn several more dvds that were full of just videos and while the burn was successful and I can see that teh disc has been burned, no drive (or the PS3) I own can read it. The drive just spins up and down and eventually stops and tells me that there is no disc in the drive.
    I can't further test either as I am completely out of blank DVDs now.
    What would something like this be associated with? The drive has worked trouble free ever since I bought it last spring.
    Find Nedry!
    Check the Vending machines!!
  • jpdoe
    • May 2007
    • 237
    Re: Burning issues. No idea what is up.
    Possible causes
    - dirty or worn out laser head
    - underpowered or worn out ATX PSU
    - bad batch of DVD blanks
    - incompatible dvd blanks (some DVD recorders are picky regarding blanks)
    • i4004
      • Oct 2006
      • 2029
      it seems that some models don't like too many burns in succesion...
      (where "too many" can be few...hehe)
      so try letting it cool for a short time, and burn at 4x....
      offcourse, it's also good idea to get another burner....
      • gdement
        • Jan 2007
        • 690
        I agree with i4004 - overheating is a possibility.
        My brother had this happen with his laptop about 6 months ago. He was burning several DVDs in succession, then it started getting really slow. Even after it cooled off it didn't get any better. He had to replace the drive.
        I haven't seen this happen with a desktop drive, but I wouldn't be surprised. I suspect that consumer drives aren't designed for much of a duty cycle. The designers probably assume they'll have time to rest between burns.
        Some drives have a small fan on the back of them. They seem too small to do anything, but apparently heat must be an issue or they wouldn't be there.
        • Scenic
          o.O
          • Sep 2007
          • 2642
          i've had exactly the same drive.
          burned 3 discs in a row some day... first one was ok, 2nd one had slight reading problems... 3rd one completely unreadable (allthough i had no problems burning it (no error messages or something)).
          since the 3rd disc, the drive doesnt recognize any disc anymore.. no CDs and no DVDs... dead.
          went over to LG and never had any problems since then..
          i've only seen this on Pioneer drives (DVD burners) until now..
          • pentium
            • Mar 2006
            • 2778
            You want me to buy another burner? I got this one just to replace another one I have. You can't be serious.
            Well I have absolutely no idea what is up until I get a new spindle of dvds so in the mean time, please give a recommended "cool down" time for the drive between burns.
            Find Nedry!
            • jpdoe
              • May 2007
              • 237
              After losing a CDRW drive a couple of years ago, I started thinking possible reasons. I left the PC on most of the day, and summers down here are quite hot. So I bought an used full tower case, which happens to have two 8cm fans situated over the PSU. That is, viewed from the back it looks like this:
              top of the case
              FAN FAN
              PSU
              M
              O
              T
              H
              E
              R
              B
              O
              A
              R
              D
              So I decided to create an airflow around my brand new DVD recorder. The case has six 5 1/4 bays, situated from top to middle of the case. I left the upper four ones empty, but covered with their plastic plates. I put the DVD drive on the fifth one, and left the one in the bottom (in the middle of the case) empty, but uncovered (with its plastic plate removed). There's a metal sheet dividing the case in two: upper side for 5 1/4 devices and bottom side for motherboard and hard disks. Leaving the bottom 5 1/4 drive bay open, the fans on the upper back of the case take air from the opening below the dvd drive, creating an air flow that mantains the drive cool all the time.
              • pentium
                • Mar 2006
                • 2778
                My case is pretty well ventilated and the POS plexiglass panel on the side has long since been removed. Shoot, right now the drive is cool to the touch.
                Find Nedry!
                • i4004
                  • Oct 2006
                  • 2029
                  dunno...try 1hr, 30min 20min....
                  i have such lite-on burner, and i'm not using it that much because of the reasons i stated.
                  when i do use it and burn at 4x, it's ok.
                  i don't do successive burns on it at all.
                  about buying? come on, are burners really that expensive?
                  buy lg and use that one as backup.
                  you probably have a free ide or sata place on mobo.
                  you cannot possibly be that cheap.
                  (i primarilly bought lite-on to be able to do media (ie burn) quality scans, and for that it's still ok....)
                  • pentium
                    • Mar 2006
                    • 2778
                    Nope, all my IDE and SATA ports are taken. All that is left is scsi.
                    I do have a Benq external USB dvd burner however even after I resoldered the rear power connector (the joint was cold), any bumps and the thing loses power until I jiggle the cord again.
                    Find Nedry!
                    • gdement
                      • Jan 2007
                      • 690
                      A slower burn speed might help, but I've never really used the higher speeds so I don't know what difference it makes. I've always burned at 4x just because I don't care about going any faster, and I figure higher speeds just beat up the drive and might not burn as accurately. I hate hearing an optical drive spin at insane speeds.
                      i've only seen this [fan] on Pioneer drives (DVD burners) until now..
                      I've seen it on a Pioneer (my current drive) and also a Plextor CDRW.
                      The fan was one of the differences between the SCSI and ATA versions of a Plextor 12X CDRW I bought a few years ago. I was disgusted with problems on my prior burner so I bought the expensive one (foolishly perhaps). The SCSI version had a fan, better version of burnproof, and a larger buffer. All things apparently intended to make it more robust than the ATA version, and indeed it's always worked perfect but being CD-only makes it not so useful nowadays.
                      Not sure if they make SCSI burners anymore, but if they do they're probably built better just because they're not seen as consumer products.
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        looks like the laser has worn out.
                        they have a limited lifespan which is why i wont use lightscribe.
                        why waste its short life?
                        • pentium
                          • Mar 2006
                          • 2778
                          *sigh*
                          Well it is looking more like I will need to get a new drive then (even though I got this one pretty much brand new)
                          Find Nedry!
                          • i4004
                            • Oct 2006
                            • 2029
                            worn out laser?
                            well, yeah, i have a feeling they're using industrial byproducts(junk that can't pass quality control) to make many of these....
                            • zandrax
                              Hit and miss
                              • Dec 2007
                              • 1157
                              • Italy
                              @ Pentium: did your burning app show hardware errors like "Power calibration error" and such? If it does, the laser is dead because calibration errors are due to a too weak laser or a bad batch of blanc media; if successfully burned dvds were from the same batch, the dead laser due to overheating seems the most plausible explanation. Since it's abviously out of warranty, buy a new drive: desktop ones are so cheap (around 20 euro here, $25-30 or less) and you can keep the Nec as a dvd player (reading uses only a small fraction of the laser power) on another machine.
                              Another advice: use always good media from reputable manifacturers because cheap ones requires a stronger beam to be burned (so wear the laser quicklier than good ones) and are unreliable (they last from months to barely some days instead of years). I write manifacturers and not brands because brands may change suppliers: good manifacturers are Tayo Yuden, Ritek (in past sold under the Ridata brand), Mitsubishi Chemical (some Verbaitm) and a few others.
                              Zandrax
                              Have an happy life.
                              • pentium
                                • Mar 2006
                                • 2778
                                I have never had an error pop up with this drive. It's been absolutely flawless up until this (then again I rarely burned stuff) and has already successfully burned another two spindles of dvds (Don't ask). My last spindle was Maxell.
                                Find Nedry!
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Heat issue is in the laser itself.
                                  Not the entire drive.
                                  Laser beam -> Hot
                                  Mann-Made Global Warming.
                                  - Dr Seuss
                                  • pentium
                                    • Mar 2006
                                    • 2778
                                    Hmmm. I would of expected the laser assembly would be built to last a little longer than a few months.
                                    Wait, what am I thinking?
                                    This is 2008. Quantity sold is now better than quality of product.
                                    Find Nedry!
                                    • linuxguru
                                      • Apr 2005
                                      • 1564
                                      Swap the drive to a system with a known good PSU with ample power on +5v and +12v rails and check again. I'll second the recommendation of an LG DVD burner - I've never had a coaster due to a bad burn on an LG. Media that works well on LGs is just about everything, but I've had very good results with Imation (probably Moser-Baer OEM), Moser-Baer Pro, and TDK (probably CMC Magnetics). Everything plays back flawlessly on DVD players as well.
                                      Sony (Liteon) as well as Samsung DVD burners have overheated when doing full-speed burns in quick succession, after which they drop back to 1x or 2x, which is irritating as hell. LG drops back to 8x even after occasionally overheating, which I can live with.
                                      • pentium
                                        • Mar 2006
                                        • 2778
                                        I have never done a full speed burn and speaking of LG drives, I have never liked them.
                                        The last two were horrible as one would coaster every disc I tried to burn and the other would burn every odd disc but they were both CD-RW drives.
                                        Find Nedry!
                                        • Mike_Ho
                                          Any Idea for repair L13 Gen2 LAR-2 PD Charger Mosfet CSD87501L always Burned
                                          by Mike_Ho
                                          Dear All
                                          Anybody have experience to repair L13 Gen2 Board Number : LAR-2 PD charger problem?
                                          I have one board the U4201 CSD87501L are burned and the 20V_VBUS_USB2 can't switch to 20V_VINT_IN, after replace this Mosfet it's still very HOT and just use few hours will burned again. i have repeat replace this Mosfet 3 times and all dead.
                                          After that i try to shorted Mosfet Source 1 to Source 2 to bypass the 20V, and found the Control Gate 1 and Gate 2 voltage both are 20v same with 20V_VBUS_USB2.🤨
                                          So did anybody know this case will need to replace...
                                          03-15-2024, 02:02 AM
                                        • mikey5791
                                          by mikey5791
                                          Hi to all forum members,
                                          12-26-2024, 04:55 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • coinwizx
                                          Burned out PSU Corsiar HX1200 and NZXT C850, connected to wrong Molex/Sata cable from EVGA.
                                          by coinwizx
                                          Anybody has experience repair PSU burned out due to connect to EVGA molex/sata cables. I know the cable is not compatible (i got them mixed up), but I though i can connect it and use a PSU tested to find out which is the wrong sata/molex cables. As soo as I pluged in the powered molex cable to the PSU tester, the power supply short out, and will not turn on anymore. After the incident, the PSUs (both HX1200 and C850) try to power on and shut itself off immediately. The ATX PSU tester survice the short circult, still working perfectly. Anybody know if it's an easy fix or know which parts...
                                          09-09-2025, 03:11 PM
