Any Idea for repair L13 Gen2 LAR-2 PD Charger Mosfet CSD87501L always Burned
  • Mike_Ho
    • Sep 2022
    • 25
    • Hong Kong
    Dear All
    Anybody have experience to repair L13 Gen2 Board Number : LAR-2 PD charger problem?
    I have one board the U4201 CSD87501L are burned and the 20V_VBUS_USB2 can't switch to 20V_VINT_IN, after replace this Mosfet it's still very HOT and just use few hours will burned again. i have repeat replace this Mosfet 3 times and all dead.
    After that i try to shorted Mosfet Source 1 to Source 2 to bypass the 20V, and found the Control Gate 1 and Gate 2 voltage both are 20v same with 20V_VBUS_USB2.🤨
    So did anybody know this case will need to replace the PD Controller IC TPS65994AD ( it have Black epoxy under chip can't reuse after remove ) or it have another parts fail.?
    P.S. The Bios are updated to last version.
    Thank's a lot.
    Best Rgds.
    Mike.
Name:	螢幕擷取畫面 2024-03-15 155123.jpg
Name:	螢幕擷取畫面 2024-03-15 155232.jpg
  • mon2
    • 14677
    Remove all power. Meter in resistance mode. Measure the resistance to ground of 20V_VINT_IN. Post the measurement.
    Is the replacement mosfet from a reliable source? It may be to not the same specs. Good sources are Digikey, Arrow and Mouser. Texas Instruments has good and better rated mosfets as well.
    • hoeralu
      • Mar 2023
      • Austria
      I'm currently having the exact same issue - TPS65994 replacement didn't solve it.
      The laptop is currently back with the owner with new FETs (mine are from Mouser) because I didn't have time for more detailed analysis.
      I expect to get it back in about a week with the same issue for the third time, then I can investigate further.
      What's weird is that the gate voltages don't reach high enough to fully switch the FETs on, so there's always about 1V VDS which can produce 2.5W on an empty battery.
      No wonder the FETs almost desolder themselves.
      According to the Datasheet the TPS has internal charge pump for the gate voltages so I can't really measure anything other than gate voltage.
      I will keep you posted next time I have the device, please let me know if you find something.
      EDIT:
      Now that I think about it: The charge pump apparently delivers only 10µA of current, does anyone have experience if excess flux from manual soldering could pull the gate voltage down a lot with that low source current? Might be worth a try to work a lot cleaner, I tend to go generous on the flux...
      • MAREBELE
        • Jan 2023
        • 41
        • Indonesia
        EDIT:
        Hi.
        I have this same problem on lenovo yoga 9 do you find the solution?
        My pd chip tps65994bf need to be program so I can't replace the pd but I've changed the mosfet 2 time but still hot
        • Wolf1977
          general question when a mosfet on primary of transformer is burned
          by Wolf1977
          hi
          in a welding machine i had a mosfet and four components wich connect with it burned
          i ordered all the damaged components and replace it but when i put the device on the plug all the components burned again i had tested before and i had not shunts
          i dont understand whats happen wrong
          more particular on the schematic q11p01 mosfet q11p02 tranzistor
          three paralel resistors had burned q11p07 zener shunt q11p08 open
          when i changed all these shunts q11po7 mosfet and tranzistors
          maby the transformer has problem on your opinion or something on...
          08-19-2023, 01:27 PM
        • Jane
          How do you test MOSFET in laptops ?
          by Jane
          I tried to use this method:
          Testing an N-channel MOSFET:
          Step 1: Discharge the Gate (turn off the MOSFET)
          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
          Step 2: Charge the Gate (turn on the MOSFET)
          Now, place the red probe on the Gate (G) and the black probe on the
          09-27-2024, 03:31 AM
        • Grafnus
          Lenovo ThinkPad P15 Gen2 Battery Mosfet Replacement
          by Grafnus
          Hey there,
          first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
          So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
          Specs:
          • Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
          • CPU, GPU, RAM work fine (not involved in the Problem)
          So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
          Now I noticed...
          08-06-2025, 11:54 AM
        • Roll
          HP Pavilion X360 burned mosfet
          by Roll
          Hi, I have a HP Pavilion x360 - 15-dq0007nc (just about 26 months old) with burned mosfet. Sadly I didn't found any boardview or schematic for this model, so I need your help with this.
          The mosfet right next to it is probably SM3319NSQA N-channel.
          The burned one is connected to a Sic634 pin 8-11 "Power stage input voltage. Drain of high-side MOSFET" So it should be a P-channel? Can you help me with finding the right replacement?
          Also I measured about 15 ohms to the ground on the coil. But I didn't remove the burned stuff yet - it will wait until...
          05-28-2022, 05:12 AM
        • Caly411
          burned mosfet wich has written on top "I6 GUE 8v1507"
          by Caly411
          Hi, Im having a similar problem with my Acer Nitro 5 AN517 52, took it to repair and they said that the problem was a burned mosfet wich has written on top "I6 GUE 8v1507".
          There is written PQB12 on the motherboard right next to it.
          Does anyone know if there is soemthing similar I can buy to replace it with?
          Seems impossible to find theidentical mosfet online.
          08-30-2023, 10:48 AM
