Windows loses an hour on clock on boot every time
    I'm having an issue with my Windows 7 desktop. I dual boot Ubuntu on this PC and Ubuntu does not have this bug, only Windows.
    Every time I boot from cold, the clock goes back by exactly 1 hour. This started happening after daylight savings. I can adjust it forwards, or re-sync with the time server, and that fixes it until rebooting... switching to non DST timezone didn't work either (so I'm not sure if it's DST related or not)
    Has anyone heard of this before? It's driving me nuts.
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Windows loses an hour on clock on boot every time
    Is your bios clock reading the correct time?
      • 30977
      windows is doing the clock-forward/backward thing and writing it back - disable BST correction.
      • diif
        • Feb 2014
        • 6978
        • England
        You have the correct time zone set ? (UTC) Dublin, Edinburgh, Lisbon, London
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          Yup, make sure the BIOS clock matches the time its showing.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • SteveNielsen
            Retired Tech
            • 2327
            Ubuntu wants the BIOS clock set to UTC. Windows wants it set to local time zone.
              I think you're right, Steve. It only seems to happen when Ubuntu runs. I followed these steps which should resync the time on every boot, hopefully resolving this issue:
              http://crazy4tips.blogspot.co.uk/201...7-startup.html
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                Linux and Unix wants UTC, windows wants local time. some parts of the UK are +/- (cant remember which) 1hr from UTC. it gets worse when you are 7 hours behind UTC.
                Follow the white rabbit.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  Yeah, you need to manually add an entry to the registry to force windows into UTC mode. Archwiki has instructions on how.
                  sigpic
                  (Insert witty quote here)
                  • lti
                    • May 2011
                    • 2547
                    I thought it was fairly easy to make Ubuntu set the BIOS clock to the local time zone instead of UTC. I've definitely seen that option in other distributions, including some that are based on Ubuntu.
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      Yes, you can, but IIRC it's not a "good idea" as this functionality isn't guaranteed to last forever.
                      https://wiki.archlinux.org/index.php/Time#Time_standard
                      Windows registry editing:
                      https://wiki.archlinux.org/index.php...UTC_in_Windows (I reccommend using regedit; making a registry file and double clicking didn't work for me)
                      sigpic
                      • SteveNielsen
                        Retired Tech
                        • 2327
                        That's good info ratdude.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          @tom66,
                          Saw this while reading lxer.com
                          How To Fix Time Difference Between Ubuntu And Windows
                          http://www.linuxandubuntu.com/home/h...tu-and-windows
                          --- begin sig file ---
                          --- end sig file ---
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            This is *not* new to Windows 10, Windows 8x, Windows 7 or Windows Vista.
                            Windows XP likes to randomly change the time without my permission! (During the forth quarter and the first quarter of the year.)
                            And later versions may too, if Microsoft didn't get their act together! So, the original clock thing can't be anything to do with Satya Nadella.
                            But, what is new, even though not to Windows 10, is Microsoft making it difficult for the eastern US and any non-Pacific US or Canada region,
                            I have a hard time finding the time zone selection and seems as if Microsoft is trying to hide it from me! (Since at least Windows 8x)
                            So at least with Windows 8x and later, prepare for the clock to be behind by 3 hours or 2 hours for eastern US folks.
                            ASRock B550 PG Velocita
                            Ryzen 9 "Vermeer" 5900X
                            Arc A770 16 GB
                            eVGA Supernova G3 750W
                            Alienware AW3423DWF OLED
                            • RJARRRPCGP
                              • Jul 2004
                              • 6304
                              Originally posted by retiredcaps
                              @tom66,
                              The clock thing regarding Linux, is a different breed, it's because Linux bases the clock on UMT, which is the same thing as western Europe time, IIRC! And FYI, it's not just an Ubuntu thing...
                              Arc A770 16 GB
                              • SteveNielsen
                                Retired Tech
                                • 2327
                                I think the issue was addressed and resolved.
                                • DynaxSC
                                  ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                                  by DynaxSC
                                  I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                                  Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                                  Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                                  The behaviour is also really very strange, i.e.:
                                  • The disk shows always up in BIOS - so it is recognized, so far so good
                                  • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                                  02-23-2025, 01:33 PM
                                • mr.malcom
                                  HP 17-cd0606ng no Windows or Linux Boot, exept idle=poll Boot-Parameter
                                  by mr.malcom
                                  this is a very strange Problem:
                                  Notebook hang instantly on Boot. BIOS is accesable.
                                  Windows: instant after showing "loading circle", even Windows Boot Stick hang instant (even without installed SSD/NVME )
                                  Linux: instantly (if Linux Boot in leagacy Mode with log messages: Machine Check exception after 0.25 sec)
                                  i have tried:
                                  - only one RAM Stick, another working RAM, both RAM channel
                                  - BIOS Flash to newest Version F.50, BIOS Reset
                                  - Memtest86 hang instant at Test 2
                                  - HP UEFI Diagnostic wont find...
                                  02-26-2022, 05:19 AM
                                • flat-earther
                                  Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
                                  by flat-earther
                                  I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
                                  To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
                                  I have opened the camera and I think there is enough room to add something inside to accomplish this:
                                  The camera is powered by a 3.7V nominal single cell lithium ion battery.
                                  So I need to connect another battery in...
                                  06-08-2025, 02:00 AM
                                • eltano4i20
                                  [HELP] SAMSUNG NP270E4E-K01AR
                                  by eltano4i20
                                  1) Error trying to enter the BIOS
                                  --> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
                                  Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
                                  BOOT PRIORITY ORDER (img-05)
                                  1- Windows Boot Manager
                                  2- SATA HDD
                                  3- NETWORK
                                  4- Debian
                                  2) Error trying to access the BOOT MENU
                                  --> I restarted the notebook and pressed [F10] but the BOOT...
                                  07-04-2025, 12:39 AM
                                • claws77
                                  FX553VE-DM318T(FX553v) not POSTING
                                  by claws77
                                  Cpu i7-7700hq Ram - 8gb samsung, 32 gb sk hynix
                                  Gpu - nvidia geforce 1050ti
                                  Ssd orion o700
                                  Hdd hgst721010A9e630
                                  See images
                                  What's not working right?
                                  The system does not even POST, display is black,
                                  LEDs on - power led, aiplane mode, capslock fpr few seconds in the start(when connected to ac power) only.
                                  When did the problem happen?
                                  My laptop had dual boot setup, ubuntu and windows 10.
                                  It already had a moklist error, that would occur when i tried to boot ubuntu.
                                  05-17-2025, 04:09 PM
