Win xp ?
  • desert-rat
    • Mar 2014
    • 4103
    Re: Win xp ?
    I have W7 / dream studio set up rite now . For some reason the vlc player and Opera browser did not want to set up on dream studio , so I use W7 part of the time .
    http://distrowatch.com/table.php?dis...on=dreamstudio
    p.s. For any one hear that does not know what Xubuntu is
    http://distrowatch.com/table.php?distribution=xubuntu
    • ivtec
      • Dec 2008
      • 1967
      Re: Win xp ?
      Originally posted by lti
      He's already dual-booting with Xubuntu.
      I stated:{ i have Installed Xubuntu 12.04 along side win xp which works great.}
      Thanks iti; for reeding well my post for help about win xp,cause some people start to judge without reeding well posts threads ,and come up with the weirdest answers,better keep quit and not butt in.
      • SteveNielsen
        Retired Tech
        • 2327
        Re: Win xp ?
        I have only seen SP3 cause problems on problematic machines. On a healthy PC that runs XP it does fine. It can reset some default behaviors that effect performance and if that's the case do the required tweaking to set them back. SP3 can also slow boot times for a couple of restarts while it reconfigures whatever you or it has changed after initial install.
        • desert-rat
          • Mar 2014
          • 4103
          Re: Win xp ?
          Not my intention to hijack or derail your thread , just let know you are not stuck using one operating system .
          • ivtec
            • Dec 2008
            • 1967
            Re: Win xp ?
            Thanks guys ,i was able to go in microsoft and downloaded winXp SP3 from this link.
            and install went good, also downloaded firefox30.
            But the pc some times still shutts off when in facebook or some other sites.
            I tried to install AVG but it will not install.
            http://www.microsoft.com/en-us/downl...ils.aspx?id=24
            • Sparkey55
              • Jan 2010
              • 1523
              Re: Win xp ?
              That link does not work. Usually when an AV suite will not install, ( you are not giving enough info why or error messages ) means you could have a malware virii or rootkit on the machine. Does the computer just shut off or restart automatically? More detailed and accurate info would help.
              • R_J
                • 9611
                Re: Win xp ?
                Try this link for Windows Xp (sp3) http://www.microsoft.com/en-us/downl...ils.aspx?id=24
                Click on Download, next page, click on the "Proceed with this download", then click "Next".
                On the next page you can click on "No thanks and continue"
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Re: Win xp ?
                  Check the CPU heatsink.
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • ivtec
                    • Dec 2008
                    • 1967
                    Re: Win xp ?
                    Thanks R_J: that one works, sorry for mine not working it was exactly where i did download Win Xp sps3
                    • SteveNielsen
                      Retired Tech
                      • 2327
                      Re: Win xp ?
                      I have recently run into a problem installing AVG on XP from the stub downloader too. Try to find the full, offline installer and use that instead, if that doesn't work then try a previous version of AVG and after installation you can update it to the current version. The offline and previous versions are a little hard to find but they are out there.
                      • R_J
                        • 9611
                        Re: Win xp ?
                        You may want to do scan on the hard drive with something like seagate seatools, sometimes one bad sector can cause problems (usually happens in the page file area)
                        Then I would do a virus scan with something like Kaspersky rescue disk from a cd/dvd or usb drive. (hirens boot cd/dvd), It does'nt hurt to check.
                        • ivtec
                          • Dec 2008
                          • 1967
                          Re: Win xp ?
                          Hi guys after instal reinstall i think i finlely got it running with win SP2 only,and installed google chrome and so far i only have encoutered a small issue is that some times wireless fails and the only way i can connect is by going in firewall and switch it on and off,Well hope it holds on.
                          I only going to use it for a Music Notation program and download my piano gigs to Utube.
                          most times i will boot with Xubuntu,
                          • 999999999
                            • Sep 2006
                            • 774
                            Re: Win xp ?
                            SP3 has slowed down every computer I have installed it on, including one with 2GB of RAM. I haven't seen a computer running XP with more RAM than that.
                            I ran systems with ~3.3GB (out of 4GB installed, minus overhead from 32bit limitation) and saw no difference from SP3, but with heavy multitasking the extra 1.3GB really sped the systems up. IMO at 3.3GB you want XP SP3 for a good computing experience, it's not enough memory for the same performance with Vista or later, forcing purchase of a SSD to counter having too little memory available for caching.
                            Web review benchmarks of clean systems doing nothing but the benchmark state differently but of course they would, having a smaller memory footprint than everyday use systems that load a lot at boot time, and rebooting to flush the cache which is the exact opposite of what you want to do for the memory to benefit with caching.
                            • japlytic
                              DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                              by japlytic
                              In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                              Tried (only with keyboard/mouse connected):
                              • BIOS + database update
                              • Using latest Windows 11 image built with official image creation tool
                              • Previous setup version for Windows 11 installer
                              • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                              • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                              • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                              06-19-2025, 04:59 PM
                            • Hondaman
                              Firefox is now SATANIC
                              by Hondaman
                              Now that I have your attention:
                              In the last few days, it looks like Firefox has changed their software terms so they are now evil and WILL sell your data.
                              I already use Palemoon for Win7 sometimes. Looks like I'll be switching to librewolf as well, as Youtuber Louis Rossman suggests. Palemoon still supports Win7, but sometimes pages don't work properly. The Google Chrome browser might also still work for Win7.
                              I will have no choice but to upgrade my Firefox, so that I can copy dozens of tabs into a document or spreadsheet, or go through the history to...
                              03-05-2025, 04:41 PM
                            • 24gsm
                              MacBook Pro A1708 install macos fail
                              by 24gsm
                              hi to all
                              i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
                              after enter to recovery and format hdd 1to .
                              after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
                              can help please
                              Serial Number: FVFXP0U0HV2J
                              Config Code: HV2J
                              Find My Mac: OFF
                              04-16-2025, 03:57 AM
                            • duwane
                              A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
                              by duwane
                              Hi All.
                              Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
                              The issue:
                              Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
                              10-26-2022, 07:02 AM
                            • tommy97
                              ASUS FA507R - BLOD, cannot install windows
                              by tommy97
                              I have an ASUS FA507R in for repair where I’m unable to install any operating system. The laptop works fine when booted from an external Windows or Linux drive, but any attempt to install on an NVMe SSD fails.
                              I’ve already tested with three different SSDs (Gen 3 and older), and the issue persists. The laptop originally came in with a faulty SSD showing 0% health....
                              08-22-2025, 07:55 AM
