MacBook Pro A1708 install macos fail
  • 24gsm
    • Mar 2017
    • 38
    • algeria
    hi to all
    i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
    after enter to recovery and format hdd 1to .
    after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
    can help please
    Serial Number: FVFXP0U0HV2J
    Config Code: HV2J
    Find My Mac: OFF
  • mon2
    • 16215
    Open up the backside lid and inspect for liquid spill / red stickers that will be red from liquid damage. Perhaps board is slow due to a sensor fault or spill on the trackpad. Need to inspect the board or know the full history of this unit.
    • Simplebeans
      Macbook Pro A1708 820-00840-a not completing MacOS install
      by Simplebeans
      As some of you may be aware i had recently acquired a liquid damaged Macbook Pro A1708 820-00840-a which was not powering on, power issues sorted and it was down to a shorted capacitor, please see my original thread on this if you would like to find out more (https://www.badcaps.net/forum/showthread.php?t=103060)
      Now that i have the Macbook Pro powering on i am experiencing a multitude of other suspected problems. Ha.
      Firstly I’m attempting to install MacOS Monterey using a bootable USB installer. I have formatted the SSD(128GB) as Mac OS Extended (Journaled). Whichever...
      02-20-2022, 10:52 AM
    • Simplebeans
      MacBook Pro A2338 keeps restarting when attempting to install macOS
      by Simplebeans
      I have just got in a MacBook Pro A2338 which was initially displaying the Apple logo followed by an explanation mark in a circle as described here:- https://support.apple.com/en-gb/102164.
      After some error messages attempting to revive and restore the machine via DFU mode i have finally got the machine revived however now the issue seems to be when attempting to install macOS Sequoia via a bootable USB installer or via macOS recovery the machine just keeps freezing and restarting before the installation is complete, usually the installation has just started or is mid way trough before...
      08-10-2025, 11:04 AM
    • mnciks11
      MacBook Pro A1708 won’t install the MacOS Sierra
      by mnciks11
      Hello guys
      I'm struggling to install MacOS Sierra on the MacBook Pro A1708 , type -c .
      It giving me an error massage saying “you must plug in and connect your macOS Sierra power adapter before installing”.
      The battery is installed, brand new battery but doesn't charge, i was using an adapter. Im stuck I can't use this MacBook now anymore , I formatted the Ssd , can't do a thing. Is there a way to skip battery checkup or ac check up using Terminal or something please help guys…
      I did the Smc reset and Pram and all other things
      12-03-2021, 09:34 PM
    • Sus256
      HISENSE 65E7KQ PRO - no boot
      by Sus256
      Hi all!
      HISENSE 65E7KQ PRO
      RSAG7.820.13512 - chassis
      MT9618BAATAB - cpu
      RSAG7.820.12059 - power
      HD650Y3U77 - panel
      KLM8G1GETF - emmc
      Replaced emmc.
      Terminal log
      UART
      AC_ON
      E-B
      FDE enabled
      06-01-2025, 02:11 AM
    • duwane
      A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
      by duwane
      Hi All.
      Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
      The issue:
      Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
      10-26-2022, 07:02 AM
