A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
  • duwane
    • Mar 2022
    • 57
    • New Zealand
    Hi All.
    Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
    The issue:
    Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD, DFU revives/restores, and fails regardless of method used for installation. Install process dies with different errors at different stages (depending on macOS version being installed and installation method).
    Background of the machine:
    An A2141 16” 2019 MacBook Pro (820-01700 logic board with 1TB onboard SSD) that is having issues with installing macOS (any of the supported versions for this model) onto its internal (onboard) SSD. The client tried to do an upgrade to Monterey (not sure what it was running before that), and the upgrade process apparently died part way through, and the machine has been unable to successfully install any macOS since. The board is pristine, runs well, and without any noticeable issues. No signs of liquid damage or corrosion, and not even a speck of dust to be seen. It came to me as a hardware fault with suspected failed onboard SSD (NAND chips) I know that this model is renowned for failing NAND chips, however after inspecting the board and doing some measurements and software related tests I am not convinced that the issue is hardware related. I still think that it looks more like firmware, disk encryption, or possibly even network related? I could be wrong of course, and it could very well still be NAND chips, but it doesn’t seem to behave in the same way as others I have worked on with failed NAND chips.
    What I have tried so far:
    - At first it sounded like corrupt firmware to me, so ran several revives and restores in DFU mode. All complete successfully, however the issue persists when attempting to reinstall macOS.
    - Have tried installing Catalina, Big Sur, Monterey, and Ventura and all fail with similar errors (will attach installation logs for some to this post).
    - Have tried installing from external USB installer to internal SSD using all macOS versions mentioned above. All error out at different stages but all do error out.
    - Have tried installing from external USB installer to external HDD/SSD (which should bypass internal SSD completely?) using all macOS versions mentioned above which also all error out with the same messages.
    - Have tried installing using internet recovery (+Shift +Option +Command +R) which installs Catalina, and installation fails with similar errors.
    - Have tried installing using internet recovery (+Option +Command +R) which installs Ventura, and installation fails with similar errors.
    - Have tried cloning above macOS versions from previously installed ext. disks to int. SSD using Carbon Copy Cloner. Only Catalina boots and runs properly afterwards from the internal SSD. (Monterey onwards isn't supported anymore by CCC as far as I know when cloning a boot drive?)
    - Can boot and run perfectly fine and stable from any external disks that are preinstalled with any of the macOS versions mentioned above, including Monterey (haven't tested Ventura yet on external disk).
    - Internal SSD seems to work perfectly well and is not reporting any errors when formatting or being accessed from other instances of macOS. SMART status of internal SSD is listed as "verified" so looks to be fine SMART wise.
    - I have made sure that SIP is enabled, and also set the start-up security "Secure Boot" option to "Full Security" - have also tried "No Security" option though to no avail as well.
    - I have zeroed the first part of the internal SSD using dd and writing /dev/zero to it to destroy all partitions. This didn't help.
    - Have run diagnostics (Holding “D” key), and no issues found.
    The errors being seen:
    I will upload the Ventura installation log, as well as the Catalina installation log. All were done from Internet Recovery. Sorry for it being zipped, but had no choice seeing as both were way over the maximum size allowed for txt files. Ventura and Monterey both show an exceptionally useful message when they fail: "An error occurred loading the update.". Catalina installation dies with a message saying “An error occurred installing macOS” then wants me to run diagnostics.
    There also seems to be a lot of DHCP errors in the install logs. Not sure if that is normal. I did manage to get 2 Catalina installations to actually complete successfully. I changed the DNS servers in my DHCP scope to 1.1.1.1 during testing at one point, and then when I tried an Internet Recovery I had successful installations (twice only), however this only worked twice, so could have been total coincidence. Fact remains though that it does seem to intermittently install successfully.
    The only other thing I plan to try to attempt to eliminate the network side of things as a cause, is I have ordered a Thunderbolt 3 to Gigabit adapter which should arrive on Friday. With this I plan to try to do an Internet Recovery over the wire rather than over the air in case the machine has some sort of wifi related logic board fault causing all of this weirdness.
    I am stumped and have tried just about everything I can think of. If anyone can see anything in the logs that might point me in the right direction to get this fixed, I would be eternally grateful!
  • duwane
    • Mar 2022
    • 57
    • New Zealand
    Re: A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
    To me the 2 most important lines in the Ventura log are:
    Oct 26 12:33:45 MacBook-Pro osinstallersetupd[478]: **** /Volumes/Macintosh SSD/macOS Install Data/UpdateBundle/AssetData/./boot/Firmware/018-26018-570.dmg.x86.mtree != ./boot/Firmware/018-26018-570.dmg.x86.mtree ****
    Oct 26 12:33:45 MacBook-Pro osinstallersetupd[478]: Operation queue failed with error: Error Domain=com.apple.OSInstallerSetup.error Code=1004 "An error occurred loading the update." UserInfo={NSLocalizedDescription=An error occurred loading the update.}
    Does that not imply that it was unable to update some firmware? The installation seems to halt right after that.
    And the most important lines in my opinion from the Catalina logs:
    Oct 26 05:26:08 MacBook-Pro OSInstaller[637]: Failed to get disk for UUID specified for rebless.
    Oct 26 05:26:08 MacBook-Pro OSInstaller[637]: ------- Install Failed -------
    Oct 26 05:26:08 MacBook-Pro OSInstaller[637]: Operation: Install packages failed, Failure Reason: Error Domain=PKInstallErrorDomain Code=110 "An error occurred installing macOS. To use Apple Diagnostics to check your Mac hardware, shut down, press the power button, and immediately hold the ‘D’ key until diagnostics
    • moderator
      • May 2020
      • 33
      • India
      Did you find any solution.??
      i m somehow struggling with something like this...
      macOS tries to install..and at some point stops or with high speed fan it macbook shuts down and restart..and then it goes to loop..
      • smzlwan223
        • Mar 2022
        • 20
        • 中国
        • 跑步
        Tell you a very bad news, you this kind of fault, there are two kinds of hardware damage caused, first CPU, second, graphics card, in the past maintenance experience, encountered more graphics card problems, replacement graphics card, the problem is generally resolved
        • anik0101010
          [REQ] RCF M18 Digital Mixer - NAND Recovery files (uImage / ubi.img) or Dump
          by anik0101010
          I'm working on a bricked RCF M18 digital mixer. The unit was completely dead, but I managed to resurrect the hardware doing a low-level recovery via the internal UART header and the Debug Jumper method (as per RCF Service Note 1903B).
          I successfully booted from the SD card, wiped the NAND, and flashed U-Boot. The CPU is alive and I now have a working serial console at the RCF-M18# prompt.
          The Problem:
          The recovery script halted because the official firmware update provided by RCF on their website (.mpk format, ~1.5MB) is just an application...
          04-07-2026, 02:34 PM
        • 24gsm
          MacBook Pro A1708 install macos fail
          by 24gsm
          hi to all
          i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
          after enter to recovery and format hdd 1to .
          after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
          can help please
          Serial Number: FVFXP0U0HV2J
          Config Code: HV2J
          Find My Mac: OFF
          04-16-2025, 03:57 AM
        • PITERPENY
          Macbook pro 16" A2141 not updated
          by PITERPENY
          Hi. I've encountered this problem for the first time. I need help. Has anyone encountered it before and how did you solve it? Only MacOS Catalina can be installed on a MacBook via online recovery, and the Mac works fine (although it's also running slowly). But when I try to update the MacBook, it constantly crashes, and nothing else works except Catalina. Attempts to install Venture or Monterey Jack from an external drive are also impossible. I tried DFU recovery, but I can still only install Catalina and can't update, even though the system offers to update to Tahoe. It's impossible to run any...
          04-19-2026, 12:41 PM
        • misc
          A2141 Macbook 2019 16" - MacOS installation impossible
          by misc
          Hi, maybe someone is able to help.
          My macbook pro 16" 2019 is not installing Mac-OS correctly. I erased the disk and gone into recovery and installed Catalina. It ended with an error. Same with internet recovery with Catalina and Tahoe.I can't install another Mac-OS install via USB stick because the T2 blocks it. I erased the disk and don't have an admin user, so disabling is impossible. Setting the correct time via terminal didn’t help. First aid shows no error at all. Sometimes while installing catalina it restarts and loads the update screen with the apple logo and remaining time...
          04-11-2026, 01:50 AM
        • sajidmirza
          A1990 cant install OS after SSD nand repalced
          by sajidmirza
          Got A1990 with ssd nand ic shorted.Repalced all the nand ic from same donor board.Restored in apple configurator successfuly and booted to recovery.Its high siera recovery.But when i try to insatll OS from internet recovery it gives error "Recovery server could not be contacted".tried at different places thinking of low internet but still getting same error.Tried date adjustment from terminal also.
          i have heard that we cant install OS from high siera recovery at the moment.Is it true.If yes how to update recovery to latest one.tried to restore several times from...
          07-06-2023, 07:53 AM
