Lattitude D531...65w or 90w?
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    I have this D531 I plan to upgrade to win7, and upgrade its sempron to a turion X2 (highest processor it can take)
    it has a 65w brick, as I tested windows 7 last night I had it plugged into a 95w brick and it ran fairly hot.
    everywhere I search for a power brick for it, its 65w, dell site has it's replacemment listed as 90w
    should I get a 90w for the added processor?
    battery has a 30% wear, but I don't that should be a big problem
  • atsio
    • Oct 2013
    • 819
    • Greece
    Re: Lattitude D531...65w or 90w?
    If the 65w is not enough it will just auto switch off (laptop draws - needs more current than the brick can supply).
    • diif
      • Feb 2014
      • 6978
      • England
      The original Dell chargers for the D531 are 65w.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        if a 65w brick cant run it, Id hate to see its batt life (or lack thereof)!!
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          65 will work but will charge slower while running. 90W will chargeat the same rate regardless of load
          D8xx requires 90W btw...
          sigpic
          (Insert witty quote here)
            • 31204
            probably.
            on one lap i had,
            the 65w pa12 would run the lap OR charge the battery.
            the larger pa10 charger would do both at the same time.
            D830 comes with a 65w pa12 as standard btw.
            • Compgeke
              • Feb 2014
              • 524
              The official is a PA12 (PA-2E) 65W from when I worked with them in the past. The PA10 (PA-3E) will also work fine it just won't have any real advantage.
              Using a PA12 on a laptop designed for a PA10 will just result in insanely slow performance and insanely slow battery charging set by the BIOS.
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                actually, I just did a experience index with both the 65w and 90w. The CPU rating was the same. Brick ran pretty hot, but it didn't shut down. With the AS-5 it runs a hell of a lot cooler than with the sempron (even though the sempron is 25w and the turion is 35w tdp). Struggles at 720p flash, where a T5800 recent upgrade recently with the same memory timings and it ran 720p flash at about ~70% on an intel GMA /w areo
                This gpu is an ATI x1200 series chip. Funny, looking inside, I actually saw a hynix memory chip next to this gpu. Why is it sharing memory? Its 32M, cause when I set shared memory to 64M it shows up 96M. No way to get this fucker to just use the memory chip. All this person is going to do is use it for browsing, so 32M is fine for windows areo
                • c_hegge
                  • Sep 2009
                  • 5219
                  I used to have a D531. It came with a 65W adapter, so I'm sure it was fine. If the laptop wants more than 65W, it will nag you in the BIOS when you first power it on.
                  • ant3202
                    • Jun 2006
                    • 275
                    • Singapore
                    seems dell have alot of revision on those power adapters.....
                    some older models 65W...
                    while most now 90W....
                    higher watt imo is ok...
                    • clearchris
                      • Dec 2013
                      • 687
                      Higher watt adapters are required if you are using a docking station. I havent noticed a difference otherwise, though I tend to get the higher wattage ps.
                      • spleenharvester
                        • Mar 2010
                        • 919
                        Just get a Dell PA-10. They can be had for near to postage costs used if you look in the right places, and they're absolutely bulletproof.
                        For the record, I had a Dell D531 for a while. Quite a nicely built piece of kit. Ran extremely hot though - the upgrade to an E5500 was more than worth it.
                        Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                        • BigTroll
                          • Sep 2010
                          • 1317
                          • LAMBDA SOND
                          I have a D520 seems to be the same heat with the 90 or 65 watt but since most my outlets are two prong i use the 65 watter more often, gotta love the timeless 4:3 screen design of these.
                          My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            90w (pa-10). 65w (pa-12) will work but it will only charge at full capacity with the laptop shutdown. This is true for all d series minus d8xx units (pa-10 only).
                            sigpic
                            • brethin
                              • Dec 2008
                              • 1907
                              The adapter you use has a side effect on the heat the laptop generates and it is due to ExpressCharge only and nothing to do with the CPU or other factors of the laptop.
                              As far as which adapter to use read this.
                              65 Watt or 90 Watt AC adapter with cord wrapping; 65 Dell Slim Auto/Air/AC Adapter (Battery optimized mode only)
                              Primary 4-cell/32 WHr "Smart" Lithium Ion battery featuring ExpressCharge™; Primary 6-cell/56 WHr "Smart" Lithium Ion battery featuring
                              ExpressCharge; Primary 9-cell/85 WHr "Smart" Lithium Ion battery, supports ExpressCharge with 90 watt AC adapter; Secondary 6-cell/48WHr
                              "Smart" Lithium Ion battery featuring ExpressCharge.
                              You should use a 90W adapter for this laptop to provide the widest options (ExpressCharge for all battery sizes, Port and Docking Station use and the brick runs cooler and lasts longer than the 65W).
                              PA-12 is the 65w adapter.
                              PA-10 or PA-3E (newer version) are the 90w adapters.
                              If you do not use 9 cell batteries, Port Replicator or Docking Station then stay with the 65W adapter you have now unless you want to spend the $10 or so on Ebay for the 90w one for no reason.
                              • spleenharvester
                                GRT60-145410 brick PSU, how much of a fire hazard is this thing exactly?
                                by spleenharvester
                                I bought an Alpicool C20 fridge, which is a 60W compressor fridge that runs on 12V or 24V, which can come from either an AC/DC adapter from mains (240V here in UK) or a car battery. The fridge itself is really good quality, so I was surprised to find the power supply (DC14.5V, 4.1A) pretty questionable. Despite being 240V/1.5A the plug was fitted with a 13A fuse - concerning, but not all that uncommon for imported chinese electronics here. But when I felt how light the brick was I immediately said hell no and transferred the proprietary connector to a MeanWell GS90A12-P1M brick (this supply is...
                                07-08-2025, 06:02 PM
                              • UADmytro
                                Lenovo T14 Gen1 i7 10  nm-C931 (brick)
                                by UADmytro
                                Hey! I bought a Lenovo T14 Gen1 i7 10 nm-C931 (a brick). The previous owner said he got it on eBay as a password-locked device and took it to a repair service, where they tried flashing something. The result: it doesn't turn on.
                                When I plug in the charger, the charging LED lights up, and the power button indicator blinks three times.
                                I downloaded the firmware from the official website, but it's incomplete. However, there is a firmware for the embedded controller (MEC1663). I did a mass erase via OpenOCD, wiped MEC1663 along with the EEPROM, and flashed an image from the...
                                03-23-2025, 03:45 AM
                              • raizenn27
                                schematic and boardview for dell lattitude 5490
                                by raizenn27
                                good day guys i'm looking for schematic and boardview for dell lattitude 5490
                                DDP70 LA-F701P REV: 1.0 (A00) does any one have thanks..
                                08-16-2025, 09:51 PM
                              • Calum McConnell
                                Dell Lattitude 7424 Broken USB-C Port
                                by Calum McConnell
                                Hello!
                                I run a dell rugged extreme as my main computer, and have linux installed. All is well! However, after plugging in a friends power adapter to test it (it turned out to be broken), my USB-C port has stopped working. This isn't the end of the world, since I can still charge with a good old-fashoned 19V barrel power, but I'd like to fix it.
                                The port shows up to the operating system, but does not provide power to devices plugged into it, nor can it receive power. I have tried cleaning it.
                                I strongly suspect that the physical port itself is damaged, and would...
                                12-02-2024, 05:24 PM
                              • adin
                                dell lattitude 5310 2 in1 , short on 3d3v_S5
                                by adin
                                dell lattitude 5310 3d3v_S5 short to ground and power vcore cpu inductors short to ground what is my shorted component
                                i dont have bench power supply to injject
                                i attached the boardview for motherboard
                                [Mod. Edit] Do not attach schematics/BV here at Tech section please.
                                If you want to add a schematic/BV, find an existing thread at Schematics requests sub-section to do it, or if such doesn't exist create a new one.
                                Boardview -> https://www.badcaps.net/forum/troubl...shooting-lapto...
                                02-02-2024, 10:42 PM
