Dell Lattitude 7424 Broken USB-C Port
  • Calum McConnell
    • Dec 2024
    Hello!
    I run a dell rugged extreme as my main computer, and have linux installed. All is well! However, after plugging in a friends power adapter to test it (it turned out to be broken), my USB-C port has stopped working. This isn't the end of the world, since I can still charge with a good old-fashoned 19V barrel power, but I'd like to fix it.
    The port shows up to the operating system, but does not provide power to devices plugged into it, nor can it receive power. I have tried cleaning it.
    I strongly suspect that the physical port itself is damaged, and would like to replace it. I'm comfortable (ish) with taking things apart and soldering them, but I would like to have the right part before I get started. I've found a few posts on here about this laptop:
    https://www.badcaps.net/forum/troubl...me#post3313457
    https://www.badcaps.net/forum/troubl...d-extreme-help
    However, there are two problems with the boardview posted. First, while I was able to hunt down a viewer capable of opening the file (Allegro Viewer 16.6), I can't easily figure out how to show the details of components. Second, and more importantly, the board linked in the above posts doesn't actually seem to be the mainboard of a lattitude 7424: if you look at the images in the service manual, you'll see it looks quite different.
    https://www.dell.com/support/manuals...6a5&lang=en-us
    TLDR: What part number should I buy to replace the physical USB-C connector on a Dell 7424?
    Thank you!
  • Calum McConnell
    • Dec 2024
    Bump! Open to any ideas on how to ID the port, even.
    • mon2
      • 14707
      Do you have clear pics of the original connector? I think Alex at Northridge repair sells them but you should be able to find them on Aliexpress with some hunting.
      • Calum McConnell
        • Dec 2024
        Without fully removing the motherboard (which i'd like to avoid until its time to repair, as the laptop still works and motherboard removal also requires heat sink removal), the best I can do is picture of the shield that goes over the connector. Obviously, it's a little bit tricky to spot the pinout from this position. I've attached pictures from Dell's service manual, which shows the part zoomed-in and with the shield, as well as cropped from an ebay-listing, which shows it blurry but without the shield.
        I went looking on Northridge Repairs website, but found nothing that looked quite right. I'll reach out to them with the "contact us" button.
        Courtesy of the the Dell service manual:
        Click image for larger version  Name:	image.png Views:	4 Size:	617.7 KB ID:	3529791
        Ebay image:
        Click image for larger version  Name:	image.png Views:	0 Size:	175.2 KB ID:	3529797
        • mon2
          • 14707
          Is this top shield on the USB C connector removable for your live unit? That is, to allow you to take closer and clean pics of the USB C connector and mounting tabs. Have not seen a connector with the side wings like yours but we should be able to find a proper replacement for the pins. Assuming for now, that the USB connector pins are through hole type.
          Check this one out:
          https://www.aliexpress.com/item/1005...800004603919_6
          or
          https://www.aliexpress.com/item/1005...Cquery_from%3A
          • Calum McConnell
            • Dec 2024
            Neither of those look quite right; but I realized that the EBay motherboard was actually fairly cheap (which makes sense, since its somewhat defective); so I just went ahead and ordered it. I'll keep this post updated with any more details I get, but I think this is the easiest way to replace the port; and I'll have spare parts for if another component goes bad.
            • R_J
              • Jun 2012
              • 9613
              How many pins does it have?
              1PC Type C USB 24 Pin Connector Female Jack Charge Port SMD PCB Solder Repair Connector for Xiaomi HP Lenovo JBL Taipu SamSung - AliExpress
              Maybe MC-642
                DELL Latitude 7424 Notebook Rugged Specification for Upgrade or Repair
                This specification for the DELL Latitude 7424 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7424 boardview and 7424 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7424...
                09-06-2024, 12:36 PM
                09-06-2024, 09:23 AM
                09-06-2024, 08:44 AM
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
