Ratdude's Main rig V3.5
  • mariushm
    • May 2011
    • 3799
    #81
    Re: Ratdude's Main rig V3.5
    Please do, because that's news to me.
    Even if you directly port 32bit programs to 64bit executables, you don't get twice the memory usage.... and it's the first time I hear about memory addressing making applications use twice the memory.
    For example, let's say an application holds a bitmap or an icon in memory, using 4 bytes (32bits) for each pixel (red,green,blue, alphablending/transparency).. when you port the application to 64bits, you won't suddenly have 8 bytes per pixel, only the one variable holding the location in memory of the bitmap changes from 4 bytes to 8 ... so you get 4 bytes extra per pointer.
    Sure, the OS would use a bit more memory as well to keep track of each app's memory pool but there's things like binary trees and so on on, the os doesn't just double the ram it uses and blocks it, that's silly... and even if it does we're talking a few hundred mb at best from 8-16 gigs.
    Anyway, I'm gonna stop, like i said it's off topic.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Moving this thread back on topic...
      Anyway, it looks like it's gonna be 8gb @400... 16gb @266 with all the cards installed and all did the same crap 400 did a few minutes ago. Took out 8gb, (one DIMM per channel) and bumped it back to 400 and all is well (so far).
      Kinda sucky... but at least I have Spare RAM modules now.
      edit- I looked things up, I'm very wrong. (shovenose, you may virtually kick me in the face). My understanding was that x86-64/EMT64 used both 64 bit words and addresses... now that I look, words (or operands specfically) are still 32 bit. Instructions are indeed 64 bit though.
      My apologies. Please, if you do hang me, use the long drop (the short drop is far more brutal).
      sigpic
      (Insert witty quote here)
      • RJARRRPCGP
        • Jul 2004
        • 6301
        May need more VDIMM. Or time to clean the slots.
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          I just get the satisfaction of being right. It's all good I'm not going to kick you in the face or hang you ... injured/dead people can't buy stuff from me
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Hdd came in, smart says it has 15 Bad sectors. Wish me luck.
            sigpic
            • Ami Sapphire
              Extreme Lurker
              • Sep 2010
              • 180
              May be fine, may not be. I have two HDDs with >400 bad sectors and they still work properly. They're both Seagate drives, too.
              Recovering a BEFSR41 v1 and v2 router from solid red DIAG Light
              I have two v2s and one v1.
              I am still looking at these boards nearly every day.
              What I'm doing: Planning an upgrade of my mining setup from Block Erupters to Red Furys. Though, if the Block Erupters don't sell, I will keep using them for a while.
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                #87
                they will ether get marked bad and you'll be fine
                or its the beginning of some worse problem and its only the tip of the iceberg
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  I'm not worried. the drive it's replacing had 27... and given that what killed it wasn't a platter issue, it should be fine.
                  sigpic
                  • grss1982
                    • Mar 2007
                    • 225
                    • Philippines
                    #89
                    The former- I'm working on that, I know.
                    The latter- they're legit upgrade discs, since I have a valid student ID (I am a student at the college) I can get win 7 upgrade discs for $20 a pop. The reason I don't just use another disc and skip activation till I find it is since it's an upgrade, the COA key won't work (you have to have had xp/vista on the hdd used for the install when windows setup begins). Not like XP and 2K, when the upgrade disc was a different image and one could be prompted to insert a previous windows disc to prove the upgrade.
                    Take a look at method 2 from here: http://winsupersite.com/article/wind...e-media-128512
                    That's all you need to do to get Windows 7 upgrade disks activated. A frend of mine worked for MS back in 2009 (when 7 was released) and they pretty much helped everyone who called in for this sort of activation issue. They even used the registry fix found in the link above.
                    CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
                    GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti / GTS 450
                    Main Driver: Intel i7 3770 | Asus P8H61-MX | MSI GTS 450 | 8GB of NO NAME DDR3 RAM (2x4GB) | 1TB SATA HDD (W.D. Blue) | ASUS DVD-RW | 22" HP Compaq LE2202x (1920x1080) | Seasonic S12II-620 PSU | Antec 300 | Windows 7 Ultimate with SP1
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      No biggie, since I need to reinstall it anyway (moving from a 3 disk to a 4 disk RAID 0), I'll get the disc TM (if I can) and go from there. As for activation, I always do a xp install first, as that works all the time.
                      sigpic
                      • RJARRRPCGP
                        • Jul 2004
                        • 6301
                        You only need that existing Windows install thing when using the retail upgrade versions, AFAIK.
                        Typical of folks getting Windows from Walmart.....
                        That's why it was a PITA when I was trying out Vista back in early 2008.
                        And for the retail version, also be prepared to get treated like a criminal for upgrading your hardware, too.....
                        Arc A770 16 GB
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Nope, I tried it w/o once, no dice.
                          sigpic
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            Here's some more parts:
                            I made an offer on this:
                            http://www.ebay.com/itm/LG-WH08LS20-...torefresh=true
                            That's like everything I'd want in a drive. Seriously. My eventual goal was to have both blueray and lightscribe, and given that I already have a SATA burner with neither, IMHO it's a better idea to kill two birds with one stone. Yeah, I probably won't be using blueray all the time (I don't own any BD drives or discs), but I figured it may come in handy down the road... And lightscribe, I have a bunch of lightscirbe DVD+R's that I have a use for... V2 has a lightscribe drive, so I figure V3 ought to as well (other wise I'm stuck using my slow external one).
                            Ordering this:
                            http://www.newegg.com/Product/Produc...82E16820176012
                            I've always been an AFT fan... V2's case and final reader was an AFT. I also considered the $16 more kiosk model, but it's too much $ more, too colorful, and has the annoying connector design in the back (V2's has that, didn't like it).
                            Comments/ideas? And if you have a SATA burner with lightscribe and/or Blueray (BD-RW is a plus), let me know.
                            sigpic
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              Bottom outted off at 45 on the drive. Take it?
                              sigpic
                              • Uranium-235
                                Comrade Glimmer
                                • Aug 2007
                                • 5042
                                • US
                                #95
                                I once added a stick of ram to a client desktop. Vista deactivated. The computer shop they brought to previously upgraded them to Ultimate. Not the only time i've seen a computer shop do this. Its not only illegal, it makes things a pain in the ass for people like me
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  The discs are weird... they're student/facualty editions of 7 ultimate... but the COA's are upgrade.
                                  I hate to bump, but bump my last post's Q. I only have 48 hours before my offer expires... so if you know if those drives are any good, speak up.
                                  sigpic
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    Installed the 4th hdd to the 3ware card, it appears dead. Not even the mobo's own controller detects it.
                                    I'm about to test the card by plugging another drive into port 3 of the card... backign up data first. Let's hope it doesn't die... otherwise I have a drive killer card and only two good drives (and a main rig 3.5 that's presumably cursed).
                                    sigpic
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      (drumroll)
                                      The issue is... a faulty drive!
                                      I placed the port 2 drive in port 3, and all was well... I'm going to try for a refund and lok for another drive yet again.
                                      Why does my luck suck so bad?
                                      Edit- Not convinced on the Blu-ray drive... as w/o the software disc, the blu-ray is useless for movies... not even K-lite is any good. Looks like the only way to make it work to buy new (since the used ones with the SW disc are nearly as much $$$) F*ck that, I'll just get a light scribe DVD+RW w/o blu-ray and call it good.
                                      sigpic
                                      • Uranium-235
                                        Comrade Glimmer
                                        • Aug 2007
                                        • 5042
                                        • US
                                        #99
                                        most of the time blue ray drives come with a copy of a full blown player of some sort, cyberlink or whatnot. Mine did
                                        • shovenose
                                          Send Doge Memes
                                          • Aug 2010
                                          • 6575
                                          Damn, you seem to have horrible luck this time around.
                                          Perhaps the drive was banged around during shipping?
                                          • Dobrowol
                                            Dell Latitude 3520 help with bios build/repair
                                            by Dobrowol
                                            Hello. Ive got problem with Dell Latitude 3520. After power on, no display and fan goes crazy. Standard job, I exported a clean bios from update via pfs extract.
                                            Steps i done and results:
                                            I exported a clean bios from update file via pfs extract.
                                            1. Build clean bios with clean ME, PMC, PCH in flash image tool.
                                            Result: Dead
                                            2. Build clean bios with no changes in ME, new PMC, PCH
                                            Result: Dead
                                            3. Build old bios with clean ME, new PMC, PCH
                                            Result: The same
                                            09-22-2023, 02:43 AM
                                            ACER Revo M2-601 Revo Build i3-6100U Specification for Upgrade or Repair
                                            This specification for the ACER Revo M2-601 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Revo M2-601 boardview and Revo M2-601 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER Revo...
                                            09-12-2024, 03:28 PM
                                          • iotaa
                                            How to build this little device please for my campervan security
                                            by iotaa
                                            You will probably find this funny, and it is, but it's also a project I'd like to take seriously.
                                            I have a campervan and I'd like to avoid thieves to break in it when I am inside it or not.
                                            For this purpose I imagined a simple device that can play a sound based on a vibration detection (in case of intrusion attempt) or by pushing a button manually.
                                            The sound wil be a growling dog, which will deter any thief, thinking there is a big dog inside the van
                                            This sound can be manually triggered by me if I'm inside the van, or played automatically...
                                            09-18-2022, 09:52 PM
                                            NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                            by sam_sam_sam
                                            I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                            I bought this from an eBay seller but unfortunately they only had one
                                            I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                            I bought three of from them to also make battery packs with this output power limit in mind
                                            I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                            04-23-2025, 05:50 AM
