Dell Latitude 3520 help with bios build/repair
  • zatara10
    • Nov 2016
    • 25
    • sweden
    #41
    hi,attached bios works but Service tag is empty and pc start manufacturer mode,please edit bios
    dell latitude 3520
    servis etiketi CX5FHG3
    Cyborg -L15 MB
    reg modeli:P108F
    reg type P108F001
    EX 28125892371
    • hoaca388
      Badcaps
      • Jan 2022
      • 12268
      #42
      dell latitude 3520
      Cyborg -L15 MB
      reg modeli:P108F
      reg type P108F001
      EX 28125892371
      Dell latitude 3520
      • zatara10
        • Nov 2016
        • 25
        • sweden
        #43
        Originally posted by hoaca388
        Dell latitude 3520
        The keyboard lights are on as if the device is turning on but there is no display, it draws 0.98A current and turns off after a while, the current is 0.0740A but the on off light remains on,and power key not works
        • AppleLover123
          Mr.Bombastic
          • Dec 2023
          • 64
          Hello guys, i also have this latitude 3520 and it's locked (dump attached).
          Can someone help me unlock it?
          ST: B3Y3CS3
          EX: 24183267699
          Model:P108F
          i5-1135g7
          • LBTT1121
            • Nov 2024
            • 726
            • Việt Nam
            #45
            ST: B3Y3CS3
            EX: 24183267699
            Model:P108F
            i5-1135g7
            try and feedback
            • AppleLover123
              Mr.Bombastic
              • Dec 2023
              • 64
              Originally posted by LBTT1121
              try feedback
              I destroyed my bios Chip.
              Ordered a new one it will arrive tomorrow then i can test.
              • AppleLover123
                Mr.Bombastic
                • Dec 2023
                • 64
                feedback
                Had tried it now.
                Laptop fans run from low to high then shutting off and restarting.
                Sometimes it is giving backlight for 5 seconds and shuts off or showing me red,white,black,green screen and shuts off.
                Any Idea?
                • AppleLover123
                  Mr.Bombastic
                  • Dec 2023
                  • 64
                  I forgot to mentioned that i've got this MB:
                  ​​​​​​Cyborg L 15 TG L New Load SW MB 213277-1
                  • Markus1741
                    • Sep 2020
                    • 922
                    • N/A
                    #49
                    Hello try this one ....
                    • Markus1741
                      • Sep 2020
                      • 922
                      • N/A
                      #50
                      Had tried it now.
                      Any Idea?
                      I had the same yesterday with a Dell 3420 notebook with 8fC8 password after the modifying with 00FDAA 00FCAA didn't want to start anymore.
                      It worked with locked BIOS.
                      I built a new BIOS and there was a very strange behavior with the 3 series again.
                      I also had the same BIOS version with 1.32.1​
                      • AppleLover123
                        Mr.Bombastic
                        • Dec 2023
                        • 64
                        tried the bios works perfectly.
                        You are correct it worked only on locked bios before maybe the System detects that the entries have changed on some important offsets or else.
                        Strange...
                        But thanks it works again!
                        How do you build a new BIOS?
                        Like is there a programm for it or what?
                        • entukecell
                          • Aug 2025
                          • Ecuador
                          #52
                          Originally posted by trepachka
                          This Latitude 3420/3520 computer is so unpredictable. I have a similar situation. Latitude 3520 powers on, fan spins, the cpu warms up but no image to the screen. I have tried many bios files and the best I was able to do is the computer doing the screen test with various colors flashing.
                          What worked for me was the bin from a Latitude 3420 computer with an i7 processor. I am aware it has a different service tag# embedded into it but try it to see if this works for you. By the way, both computers' bios chip is XMC 25RH256CXIQ
                          hi friend sorry im new in this and i have the exact same problem with my dell inspiron 3520 i5 12th gen, how i can install this bios?? i have to unmount the bios chip??
                          • peste
                            • Dec 2016
                            • 13421
                            • ROMANIA
                            #53
                            The bios chip must be unsoldered from the board before writing or reading..
                            do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                            solder wires between the programmer and the bios chip..
                            you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                            • wahabmahmood48
                              • Jan 2023
                              • 13
                              • Pakistan
                              #54
                              HOW TO CHECK TYPE OR BUILD ID I HAVE 3420 2520 LAPTOP I CAN BULID WITH FIT OR OTHER TOOLS BUT WHEN I DOWNLOD FILE FROM DELL SITE AND extract THAY GIVE ME 3 4 TYPE OF DETA HOW CAN FINDE WITCH ONE IS GOOD FOR MY LAPTOP WITCH ONE TO PICK LIKE WE CHEAK IN HP BID NUMBER
                              • gizaha
                                by gizaha
                                02-13-2024, 07:18 AM
                                DELL Latitude 3520 Notebook 3000 Specification for Upgrade or Repair
                                This specification for the DELL Latitude 3520 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3520 boardview and 3520 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 3520...
                                09-07-2024, 01:30 AM
