CheapMemory card readers programmed to fail?
  • selldoor
    Slow Learner
    • 7870
    Wasnt sure where to post this "what Pi**e* me off " seemed appropriate as it really does.
    I keep buying cheap memory card readers - and I mean cheap - off ebay and wonder if anyone has the same problem in that for no apparent reason they just fail. obviously tried different pcs and chips but its just not recognised in xp or 7.
    My question is does anyone else think they are programmed to fail I am sure it would be easy enough to build a power on counter into them so that after say 50 power ups it just stops.
  • Gariarto
    • Jul 2012
    • 151
    Re: CheapMemory card readers programmed to fail?
    You sure as heck would think so with their failure rate. I fit one in just about every build I do unless otherwise requested and after some experimentation even the top priced brands fail. I settled on the cheap Rosewill brand and have mixed results. They last about the same but are much cheaper to replace.
    Look at the early failure rate of the USB 3.0 offerings now too, disgusting. Though the pre programmed failure date theory is compelling, caught out manufacturers would suffer badly if exposed ! I think it's simply cheap sh*t and thats all.
    Like this crap... I watched this where even fakes are faked ?
    http://www.youtube.com/watch?feature...&v=wi-b9k-0KfE
    and here's (reportedly) a real one.
    http://www.righto.com/2012/05/apple-...n-quality.html
    • larrymoencurly
      • Oct 2004
      • 960
      Sloppy construction? Most of the stuff I've bought from Ebay or Meritline had much worse soldering than identical products sold elsewhere for 3x - 5x the price, usually around the connectors.
      Could it be that the hot plug circuitry wasn't built right? I don't know about hot plugging flash cards, but National Semiconductor says for its LM3526 USB port power switch, a really good capacitor from +5V to ground is needed to handle the surge at plug-in time:
      "The USB specification indicates that “no less than 120 μF
      tantalum capacitors” must be used on the output of each
      downstream port. This bulk capacitance provides the shortterm
      transient current needed during a hot plug-in."
      I've seen only regular aluminum 100uF caps there. That may have been why that chip blew in my USB card.
      • mariushm
        • May 2011
        • 3799
        lack of esd protection, cheap controllers, poor connectors that don't make good contact after several insertions, poor voltage regulation for the controller... take your pick
        regarding tantalum in specs.. i assume it's due to low esr, as 'lytics are somewhat higher esr at 6.3-10v sizes.
        But some manufacturers are reluctant to use tantalum due to risk of blowing up and causing fires and higher than 100uF may be too big to use.
        • Kiriakos GR
          Banned
          • May 2012
          • 940
          • Greece
          I have see branded memory sticks to fail and even burn your USB ports, and never had an issue with card readers, other than their supporting bandwidth ( data transfer speed).
          I do own seven card readers, stick size & desktop type.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8698
            I haven't had a memory card reader fry... only had one apparently damage a card but not sure if it was it damaging the card or the card burned out (it was a SSFDC).
            However I had SD cards fail on me, and did not seem to be related to the reader. It failed in a portable device.
            This is different than plastic breaking. Yes I had one card reader whose plastic cracked and the cap no longer holds on. But it still works...
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              I've had zero luck with stick readers... I used to have a few that I used to covert some SDHC cards into high-speed flash drives... both died w/o warning. Shame, if some company made a decent reader in the form factor (not the side-load kind), I'd buy a few for sure, even if it cost a bit more $.
              sigpic
              (Insert witty quote here)
              • tmiha71
                • Apr 2010
                • 130
                What I sometimes do (see pic), and USB-anything during power-on, or power-off is a big NO-NO ( It is 47uF/10V 4x7mm ). Same thing with readers, only it's 100uf/16V 6.3x7mm as near to chip as possible (usualy on solder points of cable on PCB, no special precautions - allways connected)...
                Seems working OK (did not checked with any instrument), can't remember of any USB disconnects...
                • Kiriakos GR
                  Banned
                  • May 2012
                  • 940
                  • Greece
                  The black one in the picture above it costs some real money, but it is faster.
                  But by looking just the reader its like looking the half picture, the condition of the USB plug is the other half.
                  Especially for flash drives, wiring and mounting must be internal (in the case),
                  and special care to be given for protection against vibrations.
                  • selldoor
                    Slow Learner
                    • 7870
                    Just in case anyone has any problems with the word cheap I thought I would post a picture showing ALL the parts.
                    Perhaps I should be asking the ebay sellers how long they should last?
                    These are in the UK not China!!
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      It looks like my SanDisk Cruzer 8 GB USB pen drive just freaking failed!
                      Causes the Microsoft USB tool to bomb out with an error about being unable to copy files, despite full-formatting with Windows Explorer don't fail.
                      Made me suspect my new board had a bad USB controller! WTF!
                      I didn't get this board to have it in $5-dollar-eBay-condition!
                      But it's fine with my SanDisk Cruzer 4 GB USB stick.....
                      ASRock B550 PG Velocita
                      Ryzen 9 "Vermeer" 5900X
                      Arc A770 16 GB
                      eVGA Supernova G3 750W
                      Alienware AW3423DWF OLED
                        Pretty impressive. One chip, two capacitors, and some connectors... hard to get cheaper than that. I'll bet the number one reason for failure is ESD. Looks like it has no protection against any of that.
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          I second that! That was the first thought that came to my mind when I saw that picture
                          Muh-soggy-knee
                          • selldoor
                            Slow Learner
                            • 7870
                            Hmm - so, I think I have more of these - can I make some simple modification that might help prolong their life? I am careful to use the "safely remove hardware" option.
                            Apparently not safe enough
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              There are ESD suppressing chips, you would have to solder one in, which would mean hacking the traces and stuff on the PCB. But I am not familiar with these chips so I don't know how well they will work.
                              Muh-soggy-knee
                              • caminati
                                • Jun 2013
                                • 5
                                • Italy
                                All such cheapo devices I tested stopped working after an usually short time.
                                For the record, I share them here:
                                Last one lasted a little longer (a few months) and is still somehow working, however spitting read errors in dmesg more and more often.
                                • caminati
                                  • Jun 2013
                                  • 5
                                  • Italy
                                  Oh, I forgot to add this to the blacklist (and this even cost roughly twice as much as the others, about 4 euros, and broke down after a month or so):
                                  • Time2Retire
                                    • Aug 2012
                                    • 256
                                    I have a Vivitar Micro SD USB card reader. I've had it for a while, and it works great. I don't have a model number, but it appears to be this one (cheap too!):
                                    http://www.amazon.com/Vivitar-MicroS.../dp/B003DCGN2Q
                                    • caminati
                                      • Jun 2013
                                      • 5
                                      • Italy
                                      Hi, could you specify how long have you been having it? Months?
                                      And do you have any knowledge about the presence/absence of any esd protection device?
                                      TIA
                                      • Time2Retire
                                        • Aug 2012
                                        • 256
                                        Year(s)
                                        No.
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          The TV does not turn on, the standby indicator is on. All voltages are present.
                                          Emms is dead. Not readable, not detected.
                                          Replaced emmc.
                                          But with another dump there is no launch
                                          Terminal log
                                          UART
                                          AC_ON
                                          RPMB key is not yet programmed
                                          HASH1_VERSION=0x00000000 64bit
                                          E-B
                                          FDE enabled
                                          layout pattern onebin by SAR7,0...
                                          06-01-2025, 02:11 AM
                                        • Christos Tsiligiannis
                                          Marian Trace Alpha sound card repair help
                                          by Christos Tsiligiannis
                                          Hello to the forum.
                                          My name is Christos, I am new to the forum here and i am posting from Greece.
                                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                          11-18-2024, 05:26 AM
                                        • Kemer
                                          Graphics Card mounting frame
                                          by Kemer
                                          Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
                                          As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
                                          I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
                                          What worries me right now is the possibility that...
                                          09-14-2024, 08:57 AM
                                          HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
                                          This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
                                          09-06-2024, 08:30 AM
                                        • FZG
                                          EVGA Nu Audio Sound Card - Not Working
                                          by FZG
                                          I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
                                          The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
                                          I found...
                                          03-07-2025, 11:44 AM
