Graphics Card mounting frame
  • Kemer
    • Apr 2023
    • 45
    • Turkey
    Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
    As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
    I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
    What worries me right now is the possibility that the gasket and possibly thermal pad (gray) between the metal and the card will melt while heating or maybe the frame will cause extra heat transfer to the card. But I suppose the second one is a weak possibility.
    Does anyone have experience with applying heat to the card without removing these metal frames? Actually, you know, a similar frame can also be around the CPU.
  • Kemer
    • Apr 2023
    • 45
    • Turkey
    • Kemer
      • Apr 2023
      • 45
      • Turkey
      Nobody tried?
      • piernov
        • Jan 2016
        • 4438
        • France
        People still trying to cook their GPUs in 2024, famine is really an unfortunate thing…
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
          Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
          The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
          Securing a good thermal interface between...
          10-07-2024, 04:35 AM
        • Christos Tsiligiannis
          Marian Trace Alpha sound card repair help
          by Christos Tsiligiannis
          Hello to the forum.
          My name is Christos, I am new to the forum here and i am posting from Greece.
          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
          So i tried asking for a schematic from the company and they would not give me one. Instead they...
          11-18-2024, 05:26 AM
          HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
          This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
          09-06-2024, 08:30 AM
        • benwaterson
          Gigabyte Aorus 1080ti - card not initialising
          by benwaterson
          Hi there.
          Have searched various forums but haven't come across the exact issue I am having.
          Bought the 1080ti with a fault (randomly shutting down, black screen , fans full speed etc). Previous owner had replaced thermal pads but many were too thick on inspection.
          I tested the card in windows, all loaded up ok. Put some load on the card and it crashed. GPU was reporting 92 degrees C at the time.
          Switched the stock cooler out for an AIO water cooler from my 1080 FE, booted the card back up - temps were much better and allowed some load to be applied...
          02-05-2022, 11:42 AM
