Testing computers
+ More Options
Posts
  • stevo1210
    • Oct 2006
    • 4156
    Testing computers
    How do you guys test computers and laptops for stability issues etc? As in what method or burn in software do you use?
    I personally just pop memtest86+ overnight and if it doesn't crash I'll call it a day... Open to suggestions.
  • Koda
    • Aug 2011
    • 317
    • Macedonia
    Re: Testing computers
    If system is suspected to have stability issues or a mobo is recapped I usually run prime95 for 36 hours, if memory is suspected memtest for 36 hours and if gpu is suspected furmark for 6-10 hours. That's only for extreme cases. If other non critical work is being done on the system 5 hours of testing.
    Guns don't solve problems. I'll take 12
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      memtest86.
      sigpic
      (Insert witty quote here)
      • c_hegge
        • Sep 2009
        • 5219
        Memtest86+ for 24 hours, followed by IntelBurnTest for 24 hours.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          a program called 'the troubleshooter' and/or memtest
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • stevo1210
            • Oct 2006
            • 4156
            I use the troubleshooter sometimes. Only issue is that it doesn't work on laptops like IBM Thinkpads? or did I get a screwed up CD?
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              The Troubleshooter is an old piece of software, it won't work with everything nowadays. IntelBurnTest and Furmark, and Victoria (a russian software, from Hiren's Boot CD) for the HDD.
              A working TV? How boring!
              • lti
                • May 2011
                • 2547
                Toshiba tests computers by starting Windows, opening Internet Explorer, and then shutting the computer off as soon as the home page loads.
                • ncovert
                  • Feb 2011
                  • 291
                  LOL. How do you know that, or did you make it up?
                  As for testing, usually Memtest86+ or Prime95. I also test the PSU voltages with a DMM and make sure everything else works.
                  • lti
                    • May 2011
                    • 2547
                    I saw the event logs and browser history on my laptop after it was returned from its first two warranty repairs. They actually do run testing software when they first receive the computer, but I don't think they perform any tests to see if the part they replaced fixed the problem.
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Really? I've had nothing but good experiences with Toshiba support.
                      • larrymoencurly
                        • Oct 2004
                        • 960
                        Was that Toshiba factory service or a local independent authorized repair center? Because I've heard the latter vary widely in quality, but the one in NW Phoenix, AZ is decent. Also Toshiba factory tech support for software seems good, but hardware tech support is among the worst I've experienced:
                        1st level tech: knows nothing about computers (What's the maximum memory capacity of model XYZ? "One-six-zero-G.B."), just types your inquiries into the same Ask Iris search engine that the public has to use.
                        2nd level tech: knows the very basics of computers in general, still has no access to non-public information.
                        3rd level tech: may understand specifics of Toshiba computers, can access non-public information. May be crabby and not let you speak to a supervisor or manager ("I'm the top of the top, baby!").
                        • Krendoshazin
                          • Feb 2012
                          • 14
                          • England
                          1. Memtest86 is good for testing the stability of the CPU, RAM, and any components related to that system.
                          2. I use a DOS version of Hard Disk Sentinel for testing hard drives in a system; this allows me to see if there are any problems with the disk itself, or with communication between the disk and the controller.
                          3. I have a device for testing power supplies that checks all of the voltage rails and tells me if any of them are out of spec. However, this doesn't test the supply under stress and I'll figure out how to test it under a load at some point.
                          4. I have Slax on a USB drive with a few tools loaded on it. One of these is 'System Stability Tester' which makes the system run at 100% by calculating pi to a specified amount of places (the more digits, the more resource intensive). If it can handle a full load for several hours, then I consider it stable.
                          That pretty much covers my toolkit.
                          • lti
                            • May 2011
                            • 2547
                            This computer went to Louisville, Kentucky.
                            • eccerr0r
                              old X58 triple channel board... memtest86 memory speed?
                              by eccerr0r
                              Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                              Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                              Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                              06-28-2025, 09:06 AM
                              I found this video when looking for something else but this is how to use a phone charger for testing LED light bulbs
                              Here is the website link for this project that I plan on making
                              https://www.youtube.com/watch?v=atLERDZx0Q8
                              But I going to use a different enclosure for this project and make it more professional looking and use safety features that was not used in this video
                              I have some 24 volt switching power supply from my battery testing machine that I modified for a different switching power supply that is more suited for my new application and new purpose for testing BMS protection boards
                              If can find one that I can modify the voltage output on I have a...
                              09-09-2024, 04:47 AM
                              Some New Preliminary testing of 21700 Tool battery cells to 2.00
                              I decided to try a new approach to testing unbalanced battery cells with my battery testing machine that has more graph curve information and it looks like if you discharge them to 2.00 volts if the battery voltage does not come back to over 3.something volts you have some kind of issue with that battery cell
                              I going to do more testing and see if is the case or not
                              More to come later
                              05-04-2023, 05:11 AM
                              I just bought a SkyRc MC3000 battery testing machine very interesting device temp
                              I just bought this device that came in the mail today I put a set of 4 brand new 21700 high current battery on the charger
                              The charger has four individual temperature sensors for each battery cell
                              The bar graph for each individual battery cell is very primitive but will give you a good idea of how each battery cell is preforming and I find something odd I put on the individual battery testing machine that gives more details of the charging/discharging curves but it will be quicker to just charge and discharge battery cells that do not have any issues
                              Or test...
                              09-14-2022, 07:12 PM
                            • KYBOSH
                              Creating a Testing Jig for TV Repairs -
                              by KYBOSH
                              I was watching a YT episode from Nick's TV Repair and he literally had a test jig comprised of all the internal components of a TV on a wooden board.
                              I thought that was amazingly smart as I always thought that TV repair businesses had a room of various actual TVs they would use to do testing.
                              My question is how was he able to connect this generic looking external display to the jig? The connectors are intentionally covered up by cardboards so we cant see it but i wonder if its a custom in-house device or something that could be purchased online?
                              04-29-2025, 10:22 PM
