Ratdude's Main rig V2
Re: Ratdude's Main rig V2
UPDATES:
1. I got the coolers home... And I swapped the fans:
One of the old fans:
The new fans:
I am swapping the fans because I needed longer cables and the existing fans are too loud for desktop use. I did do a test with an old fan and a new fan powered up... the airflow was not that much different but the noise was considerably less.
2. I also spun up the case fan for the system and found it to louder than I thought. I decided to undervolt the fan by using resistors... I calculated that the fan itself is about 60 ohms (12V / .2A) and that 3 1/2W 100 ohm resistors in parallel woulf create a 33.3 ohm resitor and would be a good choice. I went ahead and made the mod... the good news is that the fan went from 2500RPM (full blast) to 1800 RPM (about right). The bad news is that the resistors get hotter than I anticipated... after doing the math, I am putting them at just over 1/2W per resistor... Oops!
I guess I will want to look for a quiter fan by design or perhaps a temp controlled fan (like the ones in Dell towers, only with a usable tach output). Anybody have suggestions?
3. I will be getting another ECC DDR 512mb stick soon, which means I can run 2gb of RAM...
4. I also will be getting an ATI Radeon 9800 Pro 256MB for the system...
sigpic
(Insert witty quote here)Comment
Wouldn't somethign like this work?
http://www.newegg.com/Product/Produc...82E16811995073Comment
http://www.newegg.com/Product/Produc...82E16811995073sigpic
Arctic cooling make them, although it doesn't look like RottenEgg have them. They only have the PWM ones.
I have used the temp controlled ones before, and the noise/airflow ratio seems very good.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
I wonder if there is a way to use the sensor output of a dell fan as a tach wire... I have a dell fan that I swapped the connector on... but the signal output apparently is not a standard tach output...it reads 0RPM.sigpic
No, because Hell have a different tachometer signal to normal fans. AFIK, there is no way of reading the Tach signal without modding the fan, but I don't usually go there when I can get Arctic cooling Temperature controlled fas for <$10 ( http://www.ebay.com/itm/Arctic-Cooli...item4cebdf92e5 )I love putting bad caps and flat batteries in fire and watching them explode!!
sigpic
What about this?
http://www.newegg.com/Product/Produc...82E16811999617
or, this?
http://www.newegg.com/Product/Produc...82E16811999603sigpic
some cheaper options for a quiet fan that I found:
http://www.ebay.com/itm/282317-003-3...#ht_500wt_1129
the vantec again (I have the 80mm version btw, its a winner)
http://www.ebay.com/itm/Vantec-SF922...#ht_4268wt_907
either of these two look good?sigpic
I just realized, I'll probably be using all of the money from the parts i'm selling to buy the same two coolers you boughtCap Datasheet Depot: http://www.paullinebarger.net/DS/
^If you have datasheets not listed PM meComment
None of those four fans are all that quiet at all. I've used thos 'stealth' vantecs before ad they are quite noisy. At 29dB at low speed, that thermoflow ain't quiet either. You're looking for 18dB or under. Here in Aus, we have Arctic cooling temperature controlled fans which are standard dimensions.
If you want really good noise/airflow, then you can't beat Noctua, but they are a tad expensive.
try http://www.newegg.com/Product/Produc...82E16835226039I love putting bad caps and flat batteries in fire and watching them explode!!
edit- found them cheaper ($10 shipped) http://www.microbarn.com/details.aspx?rid=103024Last edited by ratdude747; 03-20-2012, 01:54 AM.sigpic
updates:
the board came in today... and I found out that the coolers did not fit... the scews are the wrong thread and the brass studs are too long.
I was able to mod the coolers though:
1. I removed the exisisting springs and scews from the coolers. I then used a hammer, pin punch, and a vise to hammer out the brass studs. I slipped and gave myself a blood blister (ouch).
2. I went to the local hardware store and bought some m3 x22 screws (x8) and some #6 washers (x8).
3. I installed the coolers using the screws; the washers keep the scre heads from slippign through the holes in the cooler. I used the amount of unused thread in the bottom of the backplates as a guide to get the cooler flush with the CPU.
Other notes (after system build):
- the 3ware card didn't like my hdd... my guess is that it has to do with raid and it beign a caviar blue... either that, or the card doesn't like single drives. I moved the hdd to port 3 of the onboard SATA.
- for now, I am usign ATI radeon X1300 256mb from my shuttle box untilt he 9800 pro 256mb comes in... question: which card is a better performer, the x1300 or the 9800 pro?
-I got it booted and got F@H running... 4 virtual cores of it (2 CPUs with HT).
-so far, the cpu temps are about 50-52c (internal CPU readout, mobo sensors say 47-47.5). Not bad, right (for 3.2GHZ gallatins)?Last edited by ratdude747; 03-20-2012, 09:17 PM.sigpic
pictures...............jeez!<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
Very nice! I got close to a decade of 100% rock solid service out of that board!In all that time, it was running 24/7. I only shut it down when it became clogged with dust bunnies and needed a blowjob from the air compressor
Team : 49813
Join in!!
Team StatsComment
(I am happy either way)
some notes:
- it is LOUD... the fan swap helped but even with a dell temp controlled fan, it is kinda noisy... trade off I guess
- for some reason the two SATA DVD+RWs have to be set after the hdd in the boot list for the hdd to boot... the SATA controller must not like optical drives (it treats them like hdds, resulting in a no boot.
some pics:
overall:
Yes, it is a bit cramped.
The cooler area:
the cards (note the gap where the 3ware card used to live)
the back:
Look good?Last edited by ratdude747; 03-20-2012, 10:50 PM.sigpic
Are there supporting backplates behind the CPUs on the board? Are they thick and sturdy?
- If not, your heatsink bolt mod can seriously warp the board over time. At the place I work, we get Xbox 360s all the time, and when people usually apply a similar heatsink bolt mod, the damage is usually worse than from the original X-clamps.
Then again, the Xbox 360s also run a bit hotter than your CPUs, so that contributes to the damage a lot more.
Originally posted by ratdude747I guess I will want to look for a quiter fan by design or perhaps a temp controlled fan (like the ones in Dell towers, only with a usable tach output). Anybody have suggestions?
Originally posted by ratdude747Look good?Last edited by momaka; 03-20-2012, 10:56 PM.Comment
by cheeky2I suppose the real question is whether the existing pinouts from ether a 17IPS71 psu are cross compatible with a 17IPS12 psu? If they are then the exchange of the main boards should have no issues providing the screen is compatible with both main boards. Obviously you can change the screen configurations easily enough (providing you have the correct files) for the main board. Why may you ask would I do this? Well a lot of the smart features are no longer working on a Hitachi 48HBT62U main board I wish to give it a new lease of life!
Obviously the same LVDS connector for the screen connection... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by Asraf AtbHi everyone,
Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....1 Photo -
by JSin21Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
I have Samsung Smart TV UA65MU6100WXXY version DA01
Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...4 Photos -
by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
CN6401
Pin 01 NC
Pin 02 NC
Pin 03 "BL_ON": 0V
Pin 04 "N/C"
Pin 05 "STBY 3.3V": 3.5V
Pin 06 "GND": N/C
Pin 07 "AC_OFF"... - Loading...
