Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
  • Asraf Atb
    • Jan 2025
    • 9
    • Italy
    Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
    Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
    I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue. My initial thought is that it might be a firmware-related problem. I’ve ordered a programmer to try flashing the firmware directly onto the EEPROM without replacing it.
    If anyone has the firmware files and a guide on how to flash them properly, I would really appreciate it. I want to give this a try before considering replacing the main board entirely.
    Thanks in advance for any advice or help!
  • nomoresonys
    • 12323
    • U.S.
    Any update?
    • mrautom8
      Samsung TV UN75H6350AFXZC main board schematics?
      by mrautom8
      Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
      Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
      While relay is on, all voltage rails are present and steady (scoped) on main board.
      I love a good logic puzzle but getting lost without any schematics.
      No shorts on ANY capacitor main board.
      Thermal camera shows 3.3V inductor getting warm instantly but...
      10-19-2025, 06:32 PM
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • alltvrepairs
      Samsung UE65RU7090UXZT main board issue no video out. BN94-14180M
      by alltvrepairs
      I have confirmed that I have a mainboard problem.
      I have tracked no hardware issued on board so might be a software dump required.
      I have searched a bit but wasn't able to find anything for my screen:
      Here are some more details:
      Panel: cy-nn065hgev1h
      Main: BN94-14180M P08F
      Your help much appreciated!
      05-16-2025, 03:03 AM
    • Lee M.
      Samsung UN75RU8000FXZA bad main board?
      by Lee M.
      When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
      11-08-2023, 07:46 PM
    • cheeky2
      by cheeky2
      05-25-2024, 03:27 AM
