Ratdude's Main rig V2
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    #41
    Re: Ratdude's Main rig V2
    shit now i'm worried. I wonder if my Master-2 is the wrong thread too. Well, the right thread, but since those are HP, I am assuming they were probably on a proprietary case that probably had different threads
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      the 7v trick is useless when you are using a 3 pin fan...
      which reminds me, sometime soon I need to find new 80mm 3 pin fans for the PSU... what I installed is crap and the tach sensor is broken on one of them.
      there are backplates... they seem stiff enough to me. not the flimsy POS's that are black and shaped like an X... these are made from a rectangle of thick sheet metal...
      sigpic
      (Insert witty quote here)
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16955
        I thought you sent me the NOS one?
        Nope, I kept the new one.... I actually tossed it in a case and threw it together. You got the original one I bought back in 03 when they first came out. Ohh the thigns that motherboard could tell you if it could talk! FWIW, this forum was actually set up on that very board!
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          I can just imagine it on eBay: get a piece of history with the motherboard that hosting Badcaps.net for many heard
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            I see, cool.
            sigpic
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              looked in the manual, turns out the board DOES have temp control on the rear fan... when enabled via a jumper, it sends 9v until a trip voltage is hit, which from there it sends 12v.
              I put the undervolted fan back in, only with the resistors removed... not a lot of noise change with the twin CPU coolers...that's hot netburst I guess..
              also, under the current Radeon x1300 256mb, the graphics have sucked to say the least... from what I read, the 9800 pro 256mb I have coming soon is a much better gpu... any truth to that?
              sigpic
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16955
                Depends on what you're doing with it....but an x1300 should spank a 9800.......
                Team : 49813
                Join in!!
                Team Stats
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  that's odd, i read that it went the other way around...
                  Last resort: check benchmarks:
                  Passmark only has the 128mb versions of both cards... (I have the 256mb versions of each):
                  9800 pro 128mb: 333
                  x1300 128mb: 136
                  (higher is better).
                  assuming it is a valid benchmark, I'd be inclined to think the 9800 pro is a better card...
                  sigpic
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    Two issues here.
                    1. Graphics cards do not have butts they can not spank each other.
                    2. 9800 is a bigger number. (just kidding on this one)
                    • Scenic
                      o.O
                      • Sep 2007
                      • 2640
                      http://pc-erfahrung.de/grafikkarte/v...rangliste.html
                      rank 169 for the 9800 Pro, rank 187 or 192 for the regular X1300
                      The (for some reason unlisted) X1300 XT on the other hand is about on the same level as the listed X1650 Pro (even uses the same core.. RV535) or a Geforce 6800 (without suffix)
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        made a few major changes:
                        - I got the 3ware card to work... it wiped the hdd; luckily the important files were backed up
                        - I found a way to get around the sata opticals = no boot issue. What I did was I swapped one of the two SATA DVD+RW drives for a fast IDE combo drive out of my HP d530... the idea is that the combo drive is used for booting and the SATA DVD+RW is used for everything else...
                        - due to the hdd wipe, I had to reinstall the OS... right now, I am installing debian testign on it... ubuntu seemed slow (or was that the GPU?)
                        sound good?
                        sigpic
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          I gave up on linux... installing xp pro to it instead (slipstreamed with sp3 and the 3ware driver)
                          sigpic
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16955
                            That board is supposed to be pretty linux friendly too...
                            Team : 49813
                            Join in!!
                            Team Stats
                            • Uranium-235
                              Comrade Glimmer
                              • Aug 2007
                              • 5042
                              • US
                              #54
                              probably linux server friendly, may have an issue with desktop graphics
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                it is... but the sound card is hit/miss (via based, go figure) and getitgn TV stuff to work was a FAIL... TVtime's audio was broken, and making mythtv work was pointless...
                                I found generic drivers for the tuner... I plan to (try to) use mediaPortal to tune (ATI stuff is out due to the QAM driver lockout issue).
                                (posted from the system in question, cpu-z info to come soon).
                                sigpic
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  xp has been a half-bust as well... again, tuner issues.
                                  I hear the media center in 7 supports my card well and i can get a pro copy for $20 at my collge bookstore... except that this coming week is spring break which means thay are probably closed...
                                  IIRC there is a way to get copies for $30 via microsoft and a .edu email (I have 2)... maybe that route? edit- the pigfuckers jacked the price to $65 (for studends)...
                                  (for now, I will try the 90 day enterprise trial... and yes I am an IT manager testing my company's hardware )
                                  sigpic
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    the 7 demo bsods... bad 3ware driver?
                                    (or perhaps a bad disc, re-burning...)
                                    sigpic
                                    • Uranium-235
                                      Comrade Glimmer
                                      • Aug 2007
                                      • 5042
                                      • US
                                      #58
                                      have you ran memtest?
                                      also, want me to include a sound card in what i'm sending you? only $5
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        nope... I special-picked the sound card because it had a AC97 header...
                                        installing cent os on it... with RPMfusion there may be a little hope...
                                        (if not, perhaps debian stable?)
                                        sigpic
                                        • ratdude747
                                          Black Sheep
                                          • Nov 2008
                                          • 17136
                                          found a potential reason.
                                          I was trying to install using the SATA drive since the IDE one wouldn't read it...
                                          turns out that the DVD portion on the IDE drive is hosed... I am disappointed a bit, since I bought the drive NOS about 4 or so years ago (its a lite-on, my first lite-on to die).
                                          I am re-installing xp which I will then try to upgrade to 7 using the 90 day eval copy... (7 booted but even wouldn't see my hdd even after being fed the driver off a flash drive)
                                          sigpic
                                          • cheeky2
                                            by cheeky2
                                            05-25-2024, 03:27 AM
                                          • Dani_2024
                                            by Dani_2024
                                            10-28-2024, 05:06 PM
                                          • Asraf Atb
                                            Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                            by Asraf Atb
                                            Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                            Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                            I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                            01-27-2025, 05:02 PM
                                          • JSin21
                                            Compatibility of main boards between different variations of samsung MU6100
                                            by JSin21
                                            Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                            I have Samsung Smart TV UA65MU6100WXXY version DA01
                                            Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                            11-27-2023, 04:54 AM
                                          • jb_Bak
                                            by jb_Bak
                                            CN6401
                                            Pin 01 NC
                                            Pin 02 NC
                                            Pin 03 "BL_ON": 0V
                                            Pin 04 "N/C"
                                            Pin 05 "STBY 3.3V": 3.5V
                                            Pin 06 "GND": N/C
                                            Pin 07 "AC_OFF"...
                                            09-27-2021, 04:52 PM
