Ratdude's Main rig V2
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Ratdude's Main rig V2
    And she died again, same symptoms. Crash, reboot, RAID array failed. AFAIK the BBU is OK.
    I've tried the following:
    -Re-recapped the PSU
    -Memtest86 passed (so not a RAM issue?)
    -Swapped BBU batteries (Or at least I think I did)
    -Swapped RAID Cards and BBU controllers
    -Swapped HDDs and SATA cables.
    So why do I keep getting corrupted hard drives?
    I'm wondering if changing to an LSI card would have any benefit... as I'm running out of ideas. The issue seems too low-level for the RAMdisk mod to be the cause... and back when I used to run it as a true main rig, it never did this (then again, that was on the 9500 controller, not the 9550).
    sigpic
    (Insert witty quote here)
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      PAE issues? I thought this was the system you had running it. Corrupt HDD other wise screams out write caching corruption which could be a bad HDD itself or a controller issue. I used to have an adaptec SCSI controller that would do this exact thing. I finally got annoyed with it and shitcanned the controller, which fixed it. This was back in the U2W days.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • cheeky2
        by cheeky2
        05-25-2024, 03:27 AM
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        07-28-2025, 08:34 AM
      • Asraf Atb
        Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
        by Asraf Atb
        Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
        Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
        I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
        01-27-2025, 05:02 PM
      • Genghis_Khan
        ThinkPad T470p – CMOS Checksum Error Persists After Main Battery Removal (even with new CMOS)
        by Genghis_Khan
        I’m currently troubleshooting an issue on my Lenovo ThinkPad T470p (Type 20J6) and would really appreciate any insights or solutions.
        Issue summary:
        Whenever I remove the main laptop battery and AC adaptor, then place them back, the system gives a “CMOS checksum error” at next boot, and the BIOS clock resets to its default time/date.
        However, the RTC works fine as long as the main battery remains attached — even if the laptop is unplugged for hours. Same as I remove the battery while the AC is attached, RTC remains. Obviously,...
        11-11-2025, 11:51 AM
